    Asset Manager
    3 Posts 2 Posters 713 Views 1 Watching
    • E Offline
      eldiren
      I'm looking into developing my own content browser of sorts. An interface into a a version control system we have at our studio. I was looking into the Url api, and I remembered that you guys have that whole preset:// thing going with lib4d assets. Is it possible using the C++ that I could resolve my own custom URL/URIs to assets and images in C4D, or is the preset:// thing custom logic internal to only the built in content browser.
      • S Offline
        s_bach
        as always, please use the Q&A system to mark your post as a question.
        You can register a custom URL scheme. This scheme defines how a data connection is created for the given URL.
        The Url schemes is defined by implementing IoHandlerInterface; the connection by implementing IoConnectionInterface.
        This is a simple example of such implementations:
        #include "maxon/ioconnection.h"
        #include "maxon/iohandler.h"
        class MyIOImpl : public maxon::Component<MyIOImpl, maxon::IoConnectionInterface>
          MAXON_COMPONENT(NORMAL, maxon::IoConnectionBaseClass);
          maxon::ResultOk<void> Init(const maxon::Url& name)
            _url = name;
            return maxon::OK;
          maxon::Result<maxon::Url> ResolveMyScheme()
            iferr_scope;
            // resolve custom scheme
            maxon::String resolvedPath { "file:///c:/assets/" };
            resolvedPath.Append(_url.GetPath()) iferr_return;
            return maxon::Url { resolvedPath };
          MAXON_METHOD const maxon::Url& GetUrl() const
            return _url;
          MAXON_METHOD maxon::Result<maxon::OutputStreamRef> OpenOutputStream(maxon::OPENSTREAMFLAGS flags)
            iferr_scope;
            return ResolveMyScheme().OpenOutputStream();
          MAXON_METHOD maxon::Result<maxon::InputStreamRef> OpenInputStream(maxon::OPENSTREAMFLAGS flags)
            iferr_scope;
            return ResolveMyScheme().OpenInputStream();
          MAXON_METHOD maxon::Result<maxon::InOutputStreamRef> OpenInOutputStream(maxon::OPENSTREAMFLAGS flags)
            iferr_scope;
            return ResolveMyScheme().OpenInOutputStream();
          MAXON_METHOD maxon::Result<maxon::IOATTRIBUTES> IoGetAttributes() const
            return maxon::IOATTRIBUTES::GROUP_R | maxon::IOATTRIBUTES::GROUP_W | maxon::IOATTRIBUTES::OWNER_R | maxon::IOATTRIBUTES::OWNER_W | maxon::IOATTRIBUTES::PUBLIC_R | maxon::IOATTRIBUTES::PUBLIC_W;
          MAXON_METHOD maxon::Result<maxon::UniversalDateTime> IoGetTime(maxon::IOTIMEMODE mode) const
            return maxon::UniversalDateTime::GetNow();
        private:
          maxon::Url _url;
        MAXON_COMPONENT_CLASS_REGISTER(MyIOImpl, "net.maxon.class.iocustom");
        static maxon::Id g_myAssetScheme { "myassets" };
        class MyHandlerImpl : public maxon::Component<MyHandlerImpl, maxon::IoHandlerInterface>
          MAXON_COMPONENT(NORMAL, maxon::IoHandlerObjectBaseClass);
          MAXON_METHOD const maxon::Id& GetUrlScheme() const
            return g_myAssetScheme;
          MAXON_METHOD maxon::Result<maxon::IoConnectionRef> OpenConnection(const maxon::Url& name) const
            return MyIOImpl::CreateInit(name);
          MAXON_METHOD maxon::Result<maxon::Url> Normalize(const maxon::Url& url, maxon::NORMALIZEFLAGS flags) const
            return url;
          MAXON_METHOD maxon::Result<maxon::Url> IoNormalize(const maxon::Url& url, maxon::NORMALIZEFLAGS flags) const
            return url;
        MAXON_COMPONENT_OBJECT_REGISTER(MyHandlerImpl, maxon::IoHandlers, "net.maxon.iohandler.custom");
        This is how this scheme would be used:
        const maxon::Url myUrl { "myassets:///test.txt"_s };
        // open input stream and get file size
        const maxon::InputStreamRef inputStream = myUrl.OpenInputStream() iferr_return;
        const maxon::Int length = inputStream.GetStreamLength() iferr_return;
        maxon::BaseArray<maxon::Char> data;
        data.Resize(length) iferr_return;
        inputStream.Read(data) iferr_return;
        // convert to string
        const maxon::String text { data };
        DiagnosticOutput("File Content: @", text);
        • S Offline
          s_bach
          Update: the previous version of the code had some ill-formatted statements. You can actually define the scheme as part of the Url, without setting it using SetScheme():
          Thus, the path is resolved just by adding the path to the target folder:
