    How can I change the order of Reflection layers
    r21classic apipython
    6 Posts 4 Posters 919 Views 3 Watching
    • fwilleke80F Offline
      fwilleke80
      is there a way to change the order of reflection layers in a material?
      Or to create a new reflection layer at the end of the list, instead of always having it as first element?
      Thanks & greetings,
      Frank
      www.frankwilleke.de
        I think the short answer is: No. The longer answer is: Yes, but it is incredibly cumbersome (and dicey). The following script will reverse the order of the reflectance layers for the selected material.
        # Main function
            # Just get the first active material and check if it is a reflection layer
            # supporting material.
            material_selection = doc.GetActiveMaterials()
            if (material_selection == [] or
                not material_selection[0].CheckType(c4d.Mmaterial)):
            mat = material_selection[0]
            # Get all reflection layers and their data offset ids for that material
            reflection_layers = [mat.GetReflectionLayerIndex(lid)
                                 for lid in range(mat.GetReflectionLayerCount())]
            data_ids = [layer.GetDataID() for layer in reflection_layers]
            # Get a copy of the materials data container
            mat_data = mat.GetData()
            # I will just reverse the order of the reflection layers (or more precisely
            # the order of the data) to show the principle. Some sort of insertation
            # logic should be trivial to implement for you.
            for old_id, new_id in zip(data_ids, reversed(data_ids)):
                # The reflection layer data is stored in the container of the material
                # with a stride of 512, so for example reflection layer X goes from
                # SOME_ID to SOME_ID + 511. There are symbols for the stride IDs, check
                # https://tinyurl.com/yxvgmtmt for details.
                # A more safe approach would be to compile a list of that symbols,
                # rather than using that stride approach I use here.
                for i in range(512):
                    # We just copy all data from our data container copy to the new
                    # location, but there are data types we cannot handle in Python
                    # within that stride, so we need this rather ugly construction.
                    # I have no clue what that data is, things might break horribly.
                    # !!! THIS MEANS WE EFFECTIVELY WON'T COPY ALL DATA AND MIGHT
                    # GENERATE A CORRUPTED MATERIAL !!!
                    try:
                        mat[new_id + i] = mat_data[old_id + i]
                    except:
                        pass
        # Execute main()
        zipit
          fwilleke80
          Thanks, that idea crossed my mind, too. And thank you for even providing code! I was hoping there was a clean way to do that.
          SDK team, any further insight about this? Is this possible in a clean way, or maybe in C++ ?
          Frank
          www.frankwilleke.de
            from our point of view there's nothing to move things around. We have only this manual
            I have to check to see if there's something hidden but got doubt about it.
            I'll be back with information if i find something 🙂
              hello,
              can we change this to solved ?
                mogh
                Oh my, this is horrible 😉
                cheers mogh
