    How to print in the console ?
    3 Posts 2 Posters 729 Views 1 Watching
    • KantroninK Offline
      Kantronin
      With a simple script python, we can use 'print' to put a message in the console
      But, with a python plugin this command don't work
      I show my code here:
      def Command(self, id, msg):
      	if id == btnID:
      		print 'Hello World!'				#silently fails (no message in the console)
      		print('Hello World!')				#silently fails (no message in the console)
      		gui.MessageDialog('Hello World!')	#opens a dialog box and displays the message
      Thank you for your observations
        you can use the Python 2 keyword print in plugins just fine. Aside from the unusual eight space tab width of your code which could trip Python, you also are missing a return statement. Here is a minimal setup for a CommandData which does print something to the console via a dialog.
        class MyDialog(c4d.gui.GeDialog):
            def CreateLayout(self):
                self.AddButton(1000, c4d.BFH_LEFT, 200, 24, "button")
            def Command(self, cid, msg):
                if cid == 1000:
                    print "Hello"
        class MyCommandData(c4d.plugins.CommandData):
            def Execute(self, doc):
                dlg = MyDialog()
                dlg.Open(c4d.DLG_TYPE_MODAL, -1, -1, 200, 200)
            c4d.plugins.RegisterCommandPlugin(id=10000000,
                                              str="test",
                                              info=0,
                                              icon=c4d.bitmaps.BaseBitmap(),
                                              help="",
                                              dat=MyCommandData())
        zipit
          Kantronin
          I used the frame of your code to make plugins from scripts that I wrote, and now I can send my results to the console.
