    AddUndo() for MergeDocument() ?
    16 Posts 3 Posters 3.5k Views 3 Watching
    • A Offline
      arsen
      Hi.
      Is it possible to add UNDO for documents.MergeDocument() operation?
      I tried this code but it does not work:
      doc.StartUndo()
      c4d.documents.MergeDocument(doc, obj_path,
                                  c4d.SCENEFILTER_OBJECTS |
                                  c4d.SCENEFILTER_MATERIALS |
                                  c4d.SCENEFILTER_MERGESCENE, None)
      c4d.StatusClear()
      obj = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN)[0]
      while obj:
          obj = get_next_object(obj)
          doc.AddUndo(c4d.UNDOTYPE_NEW, obj)
      doc.EndUndo()
      Thanks!
        hello,
        you can simply add the document with c4d.UNDOTYPE_CHANGE
        I did tried with a simple scene and it remove the object and the material. Let me know if it doesn't work for you.
            filePath = "C:\\myfile.c4d"
            doc.StartUndo()
            doc.AddUndo(c4d.UNDOTYPE_CHANGE, doc)
            c4d.documents.MergeDocument(doc, filePath,
                                    , None)
            doc.EndUndo()
        • A Offline
          arsen @Manuel
          @m_magalhaes
          No, this solution does not work for me. I am trying to add UNDO when importing an OBJ file.
            Getting the example from our github repository and adding the undo part for the document.
            if it's not working, could you provide the scene ? Or maybe your code ?
            Copyright: MAXON Computer GmbH
            Author: Joey Gaspe
            Description:
                - Imports Obj with custom settings.
            Class/method highlighted:
                - c4d.plugins.FindPlugin()
                - MSG_RETRIEVEPRIVATEDATA
                - c4d.documents.MergeDocument()
            Compatible:
                - Win / Mac
                - R13, R14, R15, R16, R17, R18, R19, R20, R21
                # Retrieves a path to load the imported file
                selectedFile = c4d.storage.LoadDialog(title="Load File for OBJ Import", type=c4d.FILESELECTTYPE_ANYTHING, force_suffix="obj")
                if not selectedFile:
                # Retrieves Obj import plugin, defined in R17 as FORMAT_OBJ2IMPORT and below R17 as FORMAT_OBJIMPORT
                objExportId = c4d.FORMAT_OBJIMPORT if c4d.GetC4DVersion() < 17000 else c4d.FORMAT_OBJ2IMPORT
                plug = c4d.plugins.FindPlugin(objExportId, c4d.PLUGINTYPE_SCENELOADER)
                if plug is None:
                    raise RuntimeError("Failed to retrieve the obj importer.")
                data = dict()
                # Sends MSG_RETRIEVEPRIVATEDATA to OBJ import plugin
                if not plug.Message(c4d.MSG_RETRIEVEPRIVATEDATA, data):
                    raise RuntimeError("Failed to retrieve private data.")
                # BaseList2D object stored in "imexporter" key hold the settings
                objImport = data.get("imexporter", None)
                if objImport is None:
                    raise RuntimeError("Failed to retrieve BaseContainer private data.")
                # Defines the settings
                objImport[c4d.OBJIMPORTOPTIONS_PHONG_ANGLE_DEFAULT] = 22.5
                objImport[c4d.OBJIMPORTOPTIONS_TEXTURECOORDINATES] = True
                objImport[c4d.OBJIMPORTOPTIONS_SPLITBY] = c4d.OBJIMPORTOPTIONS_SPLITBY_OBJECT
                objImport[c4d.OBJIMPORTOPTIONS_MATERIAL] = c4d.OBJIMPORTOPTIONS_MATERIAL_MTLFILE
                objImport[c4d.OBJIMPORTOPTIONS_POINTTRANSFORM_FLIPZ] = True
                # Finally imports without dialogs
                # Start undo for the document
                doc.StartUndo()
                # Add the document to the stack
                if not c4d.documents.MergeDocument(doc, selectedFile, c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS, None):
                    raise RuntimeError("Failed to load the document.")
                # Finish the building of undo
                doc.EndUndo()
                # Pushes an update event to Cinema 4D
              @m_magalhaes solution should work just fine with obj files too. If you are getting no output you probably haven't escaped special characters in your file path properly. Alternatively you could also pass a raw string (then you don't have to escape special characters).
              file_path = r"C:\myfile.c4d
              The reason why your script is not working as expected is probably because you are only adding Undos for the selected objects. However only the last object that has been merged into the document will be selected after the merge operation.
              zipit
              • A Offline
                arsen @Manuel
                @m_magalhaes
                here is my code
                from c4d import utils, documents, plugins
                import time
                from threading import Thread
                class WatchThread(Thread):
                    def __init__(self, name, doc):
                        Thread.__init__(self, name=name)
                        self.doc = doc
                    def run(self):
                        while True:
                            time.sleep(2.5)
                            obj_importer(self.doc, r'f:\01.obj')
                            print 'Loaded.',
                            break
                def obj_importer(doc, obj_path):
                    if obj_path is None:
                    plug = plugins.FindPlugin(1030177, c4d.PLUGINTYPE_SCENELOADER)
                    if plug is None:
                    op = {}
                    if plug.Message(c4d.MSG_RETRIEVEPRIVATEDATA, op):
                        if "imexporter" not in op:
                        obj_import = op["imexporter"]
                        if obj_import is None:
                        # Parameters
                        obj_import[c4d.OBJIMPORTOPTIONS_POINTTRANSFORM_SWAPXY] = False
                        obj_import[c4d.OBJIMPORTOPTIONS_POINTTRANSFORM_SWAPXZ] = False
                        obj_import[c4d.OBJIMPORTOPTIONS_POINTTRANSFORM_SWAPYZ] = True
                        doc.StartUndo()
                        doc.EndUndo()
                        obj_import[c4d.OBJIMPORTOPTIONS_PRESETS] = 0
                    c4d.StatusClear()
                    wt = WatchThread('ht', doc)
                    wt.start()
                  first of all: If you want to use threads, you should use c4d.threading.C4DThread and not Pythons builtin thread type or weird things might happen. Also note that threading comes with certain limitations:
                  For all threaded functions it is forbidden to:
                  • Add an event.
                  • Change the structure of objects attached to the document.
                  • Create undos.
                  I am also not quite sure what the purpose of your thread is, since you are loading into the active document. If you want to "load in the background" you will have to use a temporary document. But for loading just one file I do not see any performance benefits, since you have to merge that temporary document into the active document at the end.
                  zipit
                    hello,
                    well as @zipit said it's forbidden to change the structure of a document outside the main thread.
                    watch this page and the warning about threading
                    I did checked the StartUndo and it's using GeIsMainThreadAndNoDrawThread and just get out.
                    So it's pretty clear that you can't add undo on a thread.
                    why are you using thread here ?
                    • A Offline
                      arsen @Manuel
                      This post is deleted!
                      • A Offline
                        arsen
                        @m_magalhaes @zipit
                        I use thread to manipulate external pipes(subprocess etc).
                          ferdinand @arsen
                          @arsen said in AddUndo() for MergeDocument() ?:
                          @m_magalhaes @zipit
                          although I am aware of the concept of pipes, this does not really clear anything up for me 🧐. What do you mean by external and manipulate? Just for clarification: Under pipes I understand a data IO interface to communicate between different processes, provided in Python for example by os.pipe().
                          And I don't really get why this forces you to use a thread to import an obj file 🤔.
                          zipit
                          • A Offline
                            arsen @ferdinand
                            @zipit
                            Hi
                            I use thread to track the external file. When a file is changed, it is imported.
                            When using c4d.threading, subprocess.Popen() / time.sleep() freezes C4D ( until the process is complete )
                              ah, ok, I do understand your problem better now ;). Well as explained in this thread your cannot load files other than from the main thread of c4d.
                              You could do however the following:
                              1. Use processes, threads or whatever you would like to use to monitor the status of your file(s).
                              2. Use some cross-process communication interface like os.pipe() to indicate when your data has changed.
                              3. Implement 1. and 2. within a MessageData plugin.
                              4. Use MessageData.GetTimer and MessageData.CoreMessage to periodically peek into your pipe and then react to its status from the main thread/ the c4d process.
                              zipit
                                hello,
                                @zipit already make another nice answer.
                                I can just add that in c++ you have also a filemonitor manual where you can use the function WatchDirectory
                                • A Offline
                                  arsen
                                  @zipit @m_magalhaes
                                  Thanks for the answers! I figured out how to solve the problem.
                                    nice, feel free to share your solution and mark this thread as solved.
