    Object materials won't show up in final render
    c++sdk
    4 Posts 3 Posters 1.1k Views 3 Watching
    • mfersaouiM Offline
      mfersaoui
      Object materials won't show up in final render even though it shows up in the render view. bellow is my code:
      BaseObject* MyObject::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh)
      	if (!op)
      		return BaseObject::Alloc(Onull);
      	Bool bIsDirty = op->CheckCache(hh) || op->IsDirty(DIRTYFLAGS_DATA);
      	if (!bIsDirty)
      		return op->GetCache(hh);
      	BaseObject* container = BaseObject::Alloc(Onull);
      	if (!container)
      	BaseObject* cube = BaseObject::Alloc(Ocube);
      	if (!cube)
      		return container;
      	// create the texture tag
      	TextureTag* const textureTag = static_cast<TextureTag*>(cube->MakeTag(Ttexture));
      	if (textureTag == nullptr)
      		return container;
      	// apply material
      	BaseMaterial* material = doc->SearchMaterial("mat_name");
      	if (!material)
      		return container;
      	textureTag->SetMaterial(material);
      	cube->InsertUnder(container);
      	container->Message(MSG_UPDATE);
      	return domeContainer;
      Bool MyObject::Message(GeListNode* node, Int32 type, void* data)
      	switch (type)
      	case (MSG_MENUPREPARE):
      		Material* const material = Material::Alloc();
      		if (material == nullptr)
      			return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
      		const Vector  color(0.85, 0.85, 0.85);
      		material->SetParameter(DescID(MATERIAL_COLOR_COLOR), color, DESCFLAGS_SET_0);
      		material->SetParameter(DescID(MATERIAL_USE_REFLECTION), Bool(false), DESCFLAGS_SET_0);
      		material->SetName("mat_name");
      		doc->InsertMaterial(material);
      		break;
      	return SUPER::Message(node, type, data);
        you use GetActiveDocument() in a NodeData environment. You cannot do this, since nodes are also executed when their document is not the active document (while rendering for example - documents get cloned for rendering).
        zipit
        mfersaouiM 1 Reply Last reply Reply Quote 3
          mfersaoui @ferdinand
          @zipit
          I used the following and it is working.
          BaseDocument* doc = op->GetDocument();
          Thank you.
            For more information about it, please read the BaseDocument Manual.
