    Inserting an Image Shader into a Dynamic Slot
    r20python
    6 Posts 4 Posters 1.2k Views 3 Watching
    • ? Offline
      A Former User
      I'm trying to script the creation of an Octane Universal Material. I am able to get most of the channels' shaders connected correctly using BaseList2D's InsertShader method. I am getting hung up, however, when trying to connect the Metallic texture to the Metallic shader.
      The shader starts as a float with a Texture button next to it:
      Step 1
      The button opens a contextual menu allowing the user to choose the type of shader:
      Step 2
      With Image selected, I could then insert the shader into the ImageTexture slot as with the other channels:
      Step 3
      This is my current code:
      ID_OCTANE_BITMAP = 1029508
      ID_OCTANE_SPECULAR_MAP = 1029508
      def addMetallicTexture(id,mat):
          imageTexture = c4d.BaseShader(ID_OCTANE_BITMAP)
          imageTexture[c4d.IMAGETEXTURE_FILE] = "Clear_Plastic_Mat_metallic.png"
          mat[id] = imageTexture
          doc.AddUndo(c4d.UNDOTYPE_CHANGE, mat)
          mat[c4d.OCT_MAT_SPECULAR_MAP_LINK].InsertShader(imageTexture)
          mat.Message(c4d.MSG_UPDATE)
          doc.StartUndo()
          mat = doc.GetActiveMaterial()
          addMetallicTexture(ID_OCTANE_SPECULAR_MAP,mat)
          doc.EndUndo()
      It works in the creation of the node, but doesn't create the Image Texture into the Metallic channel so it can be inserted. No commands appear in the Script Log when I select "Image" nor when I connect the nodes in the Octane Node Editor, so I'm not sure how else to create the Image Texture.
      Octane Node Editor
      I've also tried to call the Button, but it opens the contextual menu without inserting the Image Texture:
      c4d.CallButton(mat(), c4d.OCT_MAT_ADD_SPECULAR_MAP_BTN)
      Can anyone help me script this? Thank you!
        have you tried sending your button id as a message to your material node instead of using c4d.CallButton()?
        zipit
        ? 2 Replies Last reply Reply Quote 0
          Hi, @blastframe your best bet is to directly contact octane developer.
          But from my personal test (around 1 year ago), octane does not offer any API for its c4d node system.
          Meaning you can't link shader together, same for the popup is up to the GUI developer to send a message.
          • ? Offline
            A Former User @ferdinand
            @zipit said in Inserting an Image Shader into a Dynamic Slot:
            zipit
            Hi @zipit , that sounds very interesting. Could you please explain how I'd do that?
            • ? Offline
              @m_adam Thank you for the reply. I did reach out to the developer here.
              I found the solution. This is the C++ code of the shader:
                  GROUP ID_MATERIAL_SPECULAR_MAP_GROUP
                      COLUMNS 1;
                      GROUP ID_MATERIAL_SPECULAR_MAP_FLOAT_GROUP
                          COLUMNS 2;
                          REAL OCT_MAT_SPECULAR_MAP_FLOAT { SCALE_H; MIN 0.0; STEP 0.01; MAX 1.0; MAXSLIDER 1.0;  CUSTOMGUI OCTNSLIDER;; }
                          BUTTON OCT_MAT_ADD_SPECULAR_MAP_BTN   { ANIM OFF; }
                      SHADERLINK OCT_MAT_SPECULAR_MAP_LINK { OPEN; INPORT;}
              I didn't know the Specular Map link was there as it isn't visible without pressing the button. I got it working with the following code:
              mat[c4d.OCT_MAT_SPECULAR_MAP_LINK ] = imageTexture
              mat.InsertShader(imageTexture)
              Thanks for the help!
              • S Offline
                s_bach
                @blastframe said in Inserting an Image Shader into a Dynamic Slot:
                just to make things clear: the above snippet is NOT the "C++ code of the shader".
                It is the resource parameter description, that defines the parameter types and layout. See Description Resource.
