    Modified Pop Up Menu
    r21python
    7 Posts 4 Posters 1.5k Views 2 Watching
    • B Offline
      bentraje
      I'm trying to create a pop-up menu with a modified layout. Currently, the default layout of c4d.gui.ShowPopupDialog is vertical. I was looking forward to a columnar layout where its easier to see everything.
      You can see an illustration of what I am after here:
      https://www.dropbox.com/s/8dhs505yz34lap3/c4d140_modified_popup_menu.mp4?dl=0
      A few notable behaviors are that
      1. modified columnar layout
      2. it disappears once you click a command (pop-up)
      I initially thought the DLG_TYPE_ASYNC_POPUPEDIT or DLG_TYPE_ASYNC_POPUP_RESIZEABLE would do the trick but unfortunately, when you click a command, the dialog does not disappear.
      You can see an illustration code below:
      import os
      from c4d import gui, plugins, bitmaps, utils, documents
      PLUGIN_ID   = 1011325
      MAIN_TAB    = 10001
      MY_BUTTON   = 11002
      class MyDialog(gui.GeDialog):
          def get_all_objects(op):
            output = []
            while op:
                output.append(op)
                get_all_objects(op.GetDown())
                op = op.GetNext()
            return output
          def CreateLayout(self):
            self.GroupBegin(id=1013, flags=c4d.BFH_SCALEFIT, cols=5, rows=4)
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Button1")
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Button2")
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Button3")
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Button4")
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Button5")
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Button6")
            self.GroupEnd()
          def Command(self, id, msg):
              if (id == MY_BUTTON):
                  print "Button is clicked"
      class MyMenuPlugin(plugins.CommandData):
          dialog = None
          def Execute(self, doc):
          # create the dialog
             if self.dialog is None:
                self.dialog = MyDialog()
             return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC_POPUPEDIT, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
          def RestoreLayout(self, sec_ref):
          # manage the dialog
             return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
          okyn = plugins.RegisterCommandPlugin(PLUGIN_ID, "BT Popup",0, None, "Python Menu", MyMenuPlugin())
          if (okyn):
              print "Utilities Pop Up"
      Thank you for looking at my problem
        ferdinand @bentraje
        @bentraje said in Modified Pop Up Menu:
        To programmatically close a dialog you have to invoke GeDialog.Close(). So if you want to mimic a popup menu, you should do that after the button event handling.
        all_button_ids = [ID_BUTTON_1, ID_BUTTON_2, ...]
            if id == ID_BUTTON_1:
                # your button logic ...
            if id in all_button_ids:
                self.Close()
        zipit
        • B Offline
          bentraje
          @zipit said in Modified Pop Up Menu:
          Thanks for the response. I tried adding it. It didn't error out but it also didn't close.
          You can see the current code here:
          import os
          PLUGIN_ID   = 1011325
          MAIN_TAB    = 10001
          MY_BUTTON   = 11002
          all_button_ids = [MY_BUTTON]
                output = []
                while op:
                    output.append(op)
                    op = op.GetNext()
                return output
                self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Changed")
                self.GroupEnd()
                      self.Close()
              dialog = None
              # create the dialog
              # manage the dialog
              if (okyn):
          CairynC ferdinandF 2 Replies Last reply Reply Quote 0
          • CairynC Offline
            Cairyn @bentraje
            Unreached code. You return true when MY_BUTTON is clicked, and never get to the self.Close() part.
            (You can remove two of the three returns from that method.)
              ferdinand @bentraje
              as @Cairyn said the problem is unreachable code. I also just saw now that you did assign the same ID to all your buttons in your CreateLayout(). Ressource and dialog element IDs should be unique. I would generally recommend to define your dialogs using a resource, but here is an example on how to do it in code.
              BUTTON_BASE_ID = 1000
              BUTTON_NAMES = ["Button1", "Button2", "Button3", "Button4", "Button5"]
              BUTTON_DATA = {BUTTON_BASE_ID + i: name for i, name in enumerate(BUTTON_NAMES)}
                      for element_id, element_name in BUTTON_DATA.items():
                          self.AddButton(element_id, c4d.BFV_MASK, initw=100,
                                         name=element_name)
                      self.GroupEnd()
                      if id == BUTTON_BASE_ID:
                          print "First button has been clicked"
                      elif id == BUTTON_BASE_ID + 1:
                          print "Second button has been clicked"
                      if id in BUTTON_DATA.keys(): # or just if id in BUTTON_DATA
                          self.Close()
              • B Offline
                bentraje
                @Cairyn and @zipit
                Thanks for the clarification. Your solution works as expected.
                  Thanks for sharing your answer @zipit and @Cairyn
