    Reading proper decimal values on lower numbers?
    r20python
    4 Posts 3 Posters 1.7k Views 2 Watching
    • B Offline
      bentraje
      I'm writing a script that exports the position of an object. In the process, I'm truncating them to only four decimals.
      Wrote the a truncate function. It works but not on low numbers.
      For example,
      Actual Position: Vector(0, 139.213, 93.26)
      X-Position: 2.42398958609e-05
      Resulting truncation: 2.4239
      It turns out the script reads the pseudo decimal to an actual decimal. Is there a way to read the numbers as this 0.0000242398958609 so the function works as expected or should I revise the function?
      Here is the current code:
      def truncate(num):
          num_str = str(num)
          num = num_str.split(".")
          num_real = num[0]
          num_dec  = num[1][:4]
          new_num_str = "{}.{}".format(num_real, num_dec)
          new_num = float(new_num_str)
          return new_num
        that your script is not working has not anything to do with pseudo decimals, but the fact that you are treating numbers as strings (which is generally a bad idea) in a not very careful manner. When you truncate the string representation of a number which is represented in scientific notation (with an exponent), then you also truncate that exponent and therefor change the value of the number.
        To truncate a float you can either take the floor of my_float * 10 ** digits and then divide by 10 ** digits again or use the keyword round.
        data = [0.03659665587738824,
                0.00018878623163019122,
                1.1076812650509394e-03,
                1.3882258325566638e-06]
        for n in data:
            rounded = round(n, 4)
            floored = int(n * 10000) / 10000
            print(n, rounded, floored)
        0.03659665587738824 0.0366 0.0365
        0.00018878623163019122 0.0002 0.0001
        0.0011076812650509394 0.0011 0.0011
        1.3882258325566637e-06 0.0 0.0
        [Finished in 0.1s]
        zipit
        • B Offline
          bentraje
          RE: treating numbers as strings (which is generally a bad idea) in a not very careful manner.
          THanks for the reminder. I initially thought I could get away with such a rudimetary approach
          RE: code
          Interesting. Your algorithm is way more useful. Thanks for sharing.
            Thanks again @zipit for the fast and nice reply 👍
            I also move this thread to general programming as it's not related to Cinema 4D 🙂
