    InitRender() with large textures
    c++r19
    21 Posts 5 Posters 17.7k Views 4 Watching
    • r_giganteR Offline
      r_gigante
      Hi Roger, thanks for following up and providing the texture.
      A few notes:
      1. the texture attached actually points to a resized texture (760 x 760): is it wanted?
      2. the texture gets loaded and sampled flawlessly on my test plugins (both ObjectData and TagData)
      3. test were done on macOS/C4DR19.024
      Could you please provide the full high-res picture to grant correct testing?
      Cheers, Riccardo
      rsodreR 1 Reply Last reply Reply Quote 0
      • rsodreR Offline
        rsodre @r_gigante
        @r_gigante I uploaded the texture here on the forums, I think it was reduced. Here's it is.
        But any JPG, 4096x4096, using MIP sampling fails with me.
          r_gigante
          Hi Roger, thanks for providing the test picture.
          Unfortunately I've not being able to reproduce the issue with the test code below.
          Could you kindly check the same code on your side and see how it behaves?
          ObjectData::Modify()
          Bool PC_11085_ObjectData::ModifyObject(BaseObject* mod, BaseDocument* doc, BaseObject* op, const Matrix& op_mg, const Matrix& mod_mg, Float lod, Int32 flags, BaseThread* thread)
          	if (!mod || !op || !doc || !thread)
          		return false;
          	// Retrieve the BaseContainer instance of the modifier.
          	BaseContainer *bcPtr = mod->GetDataInstance();
          //	// Retrieve the Object Manager parameters values.
          	const Bool useXbitmap = bcPtr->GetBool(PC11085_XBITMAP);
          	BaseList2D* const xBitmapBL = bcPtr->GetLink(PC11085_SHADERLINK, doc);
          	const String textureFilename = bcPtr->GetString(PC11085_TEXTURE);
          	// allocate and init the InitRenderStruct
          	InitRenderStruct irs(doc);
          	// check the color space
          	COLORSPACETRANSFORMATION transform = COLORSPACETRANSFORMATION_NONE;
          	// check if linear workflow is enabled
          	if (irs.linear_workflow)
          		transform = COLORSPACETRANSFORMATION_LINEAR_TO_SRGB;
          	if (xBitmapBL)
          		// cast to BaseShader
          		BaseShader* activeMatColorBS = (BaseShader*)xBitmapBL;
          		// define the ChannelData and set the u/v coords for sampling
          		ChannelData chData;
          		// call the InitRender before executing sampling
          		const INITRENDERRESULT res = activeMatColorBS->InitRender(irs);
          		if (res != INITRENDERRESULT_OK)
          			return EXECUTIONRESULT_OK;
          		const Int32 steps = 100;
          		for (Int32 x = 0; x < steps; x++)
          			for (Int32 y = 0; y < steps; y++)
          				chData.p.x = double(x)/double(steps);
          				chData.p.y = double(y)/double(steps);
          				// sample
          				const Vector sampledValue = activeMatColorBS->Sample(&chData);
          				// correct based on the color space transformation
          				const Vector transformedColor = TransformColor(sampledValue, transform).Clamp01();
          				// just print
          				GePrint("Shader sample at ["+String::FloatToString(chData.p.x)+","+String::FloatToString(chData.p.y)+"]: "+String::VectorToString(sampledValue)+" / "+String::VectorToString(transformedColor));
          		// call the FreeRender to release allocated memory used for sampling
          		activeMatColorBS->FreeRender();
          	// Notify Cinema about the internal data update.
          	op->Message(MSG_UPDATE);
          	return true;
          TagData::Execute()
          EXECUTIONRESULT PC_11085_TagData::Execute (BaseTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, Int32 priority, EXECUTIONFLAGS flags)
          	if (!tag || !doc || !op || !bt)
          		return EXECUTIONRESULT_OUTOFMEMORY;
          	// find for the attached TextureTag and the related material
          	TextureTag* opTTag = (TextureTag*)op->GetTag(Ttexture);
          	if (!opTTag)
          	BaseMaterial* opMat = opTTag->GetMaterial();
          	if (!opMat)
          	// look for the material BaseContainer and the BaseList2D associated to the color param
          	BaseContainer* activeMatBC = opMat->GetDataInstance();
          	if (!activeMatBC)
          	BaseList2D* activeMatColorBL = activeMatBC->GetLink(MATERIAL_COLOR_SHADER, doc);
          	if (!activeMatColorBL)
          	BaseShader* activeMatColorBS = (BaseShader*)activeMatColorBL;
          	ChannelData chData;
          			// sample
          			// just print
          			GePrint("Shader "+activeMatColorBL->GetName()+" sample at ["+String::FloatToString(chData.p.x)+","+String::FloatToString(chData.p.y)+"]: "+String::VectorToString(sampledValue)+" / "+String::VectorToString(transformedColor));
          Looking forward hearing from you, give best
          Riccardo
            r_gigante
            Hi @rsodre, any feedback so far?
            Cheers, Riccardo
            • rsodreR Offline
              rsodre @r_gigante
              Hi @r_gigante, I still didn't got a chance to test your sample code and see if it fails here, but it looks like the same workflow I'm using.
              When I first opened the issue, I was using a tag, that now evolved to be a modifier, so there's no need to test the tag.
              But is your object a modifier?
                r_gigante
                @rsodre as said in InitRender() with large textures:
                which indeed is only available in BaseObject for modifier.
                Look forward your feedbacks
                  r_gigante
                  Hi @rsodre, I'm going to mark this thread as solved being passed two weeks from the last post.
                  Feel free to open a new thread if issue persists.
                  Best, Riccardo
                  rsodreR 2 Replies Last reply Reply Quote 0
                  • rsodreR Offline
                    rsodre @r_gigante
                    @r_gigante That's sad, because it's a recurrent issue we have.
                    I'll try to isolate it as soon as I have some time.
                    • rsodreR Offline
                      rsodre @r_gigante
                      Hi @r_gigante,
                      I finally took some time to isolate my shader init and sample code on a simple project, and was unable to reproduce the error I was having. If it works on a separate project, should work on my full plugin too.
                      So I started stripping code from my modifier and generator, always testing if the shader was loading properly, until the objects were barely empty, when the error finally stopped. I traced the culprit down to a single EventAdd() call in some function inside my generator's ModifyObject(). Removing it fixed the problem. Looks like calling it before the first modifier pass somehow causes the shader init error.
                      Just wanted to leave this feedback in case anyone has a similar problem someday.
                      Thanks for the help!
                        hello,
                        Thanks a lot for your feedback and happy to see your issue resolved.
