    Change an attribute from a dialogue plug-in
    r20python
    12 Posts 3 Posters 1.5k Views 1 Watching
    • B Offline
      bentraje
      I have a plug-in that lists objects along with their attributes. It updates correctly, but I want the update to be mutual.
      Currently, the scene/object manager updates the plug-in but it does not work the other way around.
      You can see the illustration of the problem here:
      https://www.dropbox.com/s/4zm0utiixuqwxez/c4d137_change_name_plug_in.mp4?dl=0
      In the same block, I have this lines:
      # retrieve the data from the scene/object manager
      self.SetString(text_ID, value=object.GetName())
      # retrieve data from the plug-in and apply the changes to the scene/object (This block is not working as seen in the video above)
      newString = self.GetString(text_ID)
      object.SetName(newString)
      Is there a way around this?
      Thank you for looking at my problem.
        have you tried invoking c4d.EventAdd() orobject.Message(c4d.MSG_UPDATE) after you changed the name?
        zipit
        • B Offline
          bentraje
          @zipit
          Thanks for the response.
          Yes, I tried both commands but it does not work as expected (i.e. typing something in the plug-in does not change the object)
          Also I think c4d.EventAdd() is only necessary on script. And the Message I think only works if you are going to modify a parameter specific to an object (say a point). Correct me if I'm wrong.
          • S Offline
            s_bach
            c4d.EventAdd() is always needed when one changes the active document in the context of some user interaction. This includes user interaction in a GeDialog (Core Messages Manual).
            Also, don't forget to call c4d.StopAllThreads() when you edit the document asynchronously (BaseDocument Manual).
            You should react to user interaction in your GeDialog's Command() function. Can you share the complete code of your Command() function?
            • B Offline
              bentraje
              @s_bach
              Sure sure. There is not much in the Command function except the return True.
              Here is the working code so far (it 's the same code as I previously asked in my previous threads.
              Thank you for looking at it.
              import os
              from c4d import gui, plugins, bitmaps, utils, documents
              PLUGIN_ID   = 1811321
              class MyDialog(gui.GeDialog):
                  def __init__(self):
                      # Be sure that we have the object list before building the UI
                      # as InitValues is called after CreateLayout()
                      self.objectsList = []
                      self.GetAllObjects()
                      self.object_count = len(self.objectsList)
                  def InitValues(self):
                      # Use to Init and in Case of an Update needed.
                      self.Update()
                  def GetNextObject(self, op ):
                      # use a non-recursive method to iterate the hierarchy
                      # [URL-REMOVED]
                      # allow to not hit the recursive stack limit.
                      if not op:
                          return None
                      if op.GetDown():
                          return op.GetDown()
                      while not op.GetNext() and op.GetUp():
                          op = op.GetUp()
                      return op.GetNext()
                  def GetAllObjects(self):
                      op = doc.GetFirstObject()
                      while op:
                          self.objectsList.append(op)
                          op = self.GetNextObject(op)
                  def Update(self): # NEW CODE
                      if self.object_count == 0:
                          self.LayoutFlushGroup(1001)
                          self.AddStaticText(0, c4d.BFH_CENTER, name="There are no objects in the scene")
                          self.LayoutChanged(1001)
                      if self.object_count > 0 :
                          self.AddStaticText(0, 1, name="Name")
                          self.AddStaticText(0, 0, name="Enable")
                          self.AddStaticText(0, 0, name="Xray")
                          self.AddSeparatorV(0)
                          for idx, object in enumerate(self.objectsList): # where the glitch happens
                              text_ID = 100000 + idx
                              enable_ID = 200000 + idx
                              xray_ID = 300000 + idx
                              self.AddEditText(text_ID, flags=c4d.BFH_LEFT, initw=200, editflags=c4d.EDITTEXT_HELPTEXT)
                              self.AddCheckbox(enable_ID, flags=c4d.BFH_LEFT, initw=20, inith=10, name="Enable")
                              self.AddCheckbox(xray_ID, flags=c4d.BFH_LEFT, initw=20, inith=10, name="Xray")
                              self.SetInt32(enable_ID, value=object[c4d.ID_BASEOBJECT_GENERATOR_FLAG])
                              self.SetInt32(xray_ID, value=object[c4d.ID_BASEOBJECT_XRAY])
                  def CreateLayout(self):
                      print "nombre d'objet ", self.object_count
                      self.GroupBegin(id=1001, flags=c4d.BFH_FIT, cols=3, rows=20, title="Rigging")
                      self.GroupEnd()
                      self.Update()
                  def Command(self, id, msg):
                  def CoreMessage(self, id, msg):
                      if id == c4d.EVMSG_CHANGE:
                          self.InitValues()
              class MyMenuPlugin(plugins.CommandData):
                  dialog = None
                  def Execute(self, doc):
                      if self.dialog is None:
                          self.dialog = MyDialog()
                      return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
                  plugins.RegisterCommandPlugin(PLUGIN_ID, "test_dynamic_update",0, None, "test_dynamic_update", MyMenuPlugin())
              • S Offline
                s_bach
                as I said above, you have to handle user interaction in the dialog's Command() function. The function if called when the user interacts with the dialog's gadgets. Something like this:
                    if id >= 100000 and id < 200000:
                        idx = id - 100000
                        newString = self.GetString(id)
                        obj = self.objectsList[idx]
                        if obj is not None:
                            obj.SetName(newString)
                    return c4d.gui.GeDialog.Command(self, id, msg)
                • B Offline
                  bentraje
                  @s_bach
                  Thanks for the response. I used the code. It works but I'm unable to type anything other than a single stroke. I think the c4d.EventAdd updates so fast.
                  You can check the illustration of the problem here:
                  https://www.dropbox.com/s/klbljd5w3uvak2t/c4d137_change_name_plug_in_02.mp4?dl=0
                  I tried removing the c4d.EventAdd(). It lets me type something but it only updates when I click outside the plug-in.
                  Is there a possibility of both worlds? Update only when I move to a next field (i.e. tab) perhaps?
                  • S Offline
                    s_bach
                    you have to call EventAdd() to inform Cinema that you have changed something.
                    But in your code, you call your Update() function after a EVMSG_CHANGE message. In your Update() function, you delete and rebuild your UI, thus you loose the focus on the current UI gadget.
                    You must find a way to either not call Update() after you edit the name of the object or to restore the focus on the newly created UI.
                    • S Offline
                      s_bach
                      Alternatively, you can check if the ENTER key way pressed and only update when this is the case (the user finished entering the string, see Interaction with Gadgets).
                      # get state of the "Enter" key.
                      state = c4d.BaseContainer()
                      res = c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_ENTER, state)
                      if res:
                        if state[c4d.BFM_INPUT_VALUE] != 1:
                          return False
                        idx = id - 100000
                        if obj is not None:
                      This way, the dialog would behave similiar to the Attribute Manager.
                      • B Offline
                        bentraje
                        Hi @s_bach
                        Thanks for the response. I change the askChannel to c4d.KEY_TAB.
                        It works as expected, but it doesn't continue to the next line when I hit tab. It goes back to the first line.
                        You can see an illustration of the problem here:
                        https://www.dropbox.com/s/wwf72tkc0pmar96/c4d137_change_name_plug_in_03_move_fifth.mp4?dl=0
                        I was expecting when I hit Tab from the fourth line it would continue to all the parameters until it reaches to the fifth line.
                        Is this possible? Or is this a limitation on the GetInputState?
                        • S Offline
                          s_bach
                          as I said above: you rebuild your UI after each EVMSG_CHANGE. Thus, you loose the focus of your UI elements (since they are destroyed and rebuilt).
                          You have to find a way to avoid that unnecessary rebuild of your layout after user interaction in your dialog.
                          • B Offline
                            bentraje
                            @s_bach
                            RE: You have to find a way to avoid that unnecessary rebuild of your layout after user interaction in your dialog.
                            I'm not really sure how to do that. Since I just butchered the code from a sample plug-in.
                            That will probably a problem for another thread.
                            Anyway, it's functional at the moment. I'll settle for this.
                            Thanks again and sorry for the trouble.
                            Will close the thread now.
                            Have a great day ahead!
