    Set the "DrawCircle" orientation to face camera
    5 Posts 3 Posters 637 Views 2 Watching
    • mfersaouiM Offline
      mfersaoui
      How to set the orientation of "DrawCircle" to face the camera like in Orientation Property of Null Object.
      info = c4d.HandleInfo()
      # Defines the position and the size of the circle
      circleSettings = bh.GetMg()
      circleSettings.off = info.position
      circleSettings.v1 *= 20
      circleSettings.v2 *= 20
      circleSettings.v3 *= 20
      # Draw the Circle
      bd.DrawCircle(circleSettings)
      Thank you.
      • S Offline
        s_bach
        as always, please mark your post as a question.
        Can you share a little more information about what you are actually doing? What is the context of the code you provided?
        If you want to draw a circle in screen space, the easiest thing would be to just draw a 2D circle using DrawCircle2D().
        # This example draws a 2D line, circle and point.
        bd.SetMatrix_Screen()
        center = c4d.Vector(100.0, 100.0, 0)
        tangentPoint = c4d.Vector(150.0, 100.0, 0)
        # draw line and circle
        bd.SetPen(c4d.Vector(0.8))
        bd.DrawLine2D(center, tangentPoint)
        bd.DrawCircle2D(center.x, center.y, tangentPoint.x - center.x)
        # draw point
        bd.SetPen(c4d.Vector(1.0))
        bd.DrawPoint2D(center)
        bd.SetMatrix_Matrix(None, c4d.Matrix())
        mfersaouiM 1 Reply Last reply Reply Quote 0
          mfersaoui @s_bach
          @s_bach
          I want use it on the ObjectData.Draw() function.
          Here is the full code:
          def Draw(self, op, drawpass, bd, bh):
              if drawpass != c4d.DRAWPASS_HANDLES:
                  return c4d.DRAWRESULT_SKIP
              bd.SetMatrix_Matrix(op, bh.GetMg())
              hitid = op.GetHighlightHandle(bd)
              for i in xrange(self.GetHandleCount(op)):
                  color = c4d.GetViewColor(c4d.VIEWCOLOR_SELECTION_PREVIEW) if i == hitid else c4d.GetViewColor(c4d.VIEWCOLOR_ACTIVEPOINT)
                  bd.SetPen(color)
                  self.GetHandle(op, i, info)
                  bd.DrawHandle(info.position, c4d.DRAWHANDLE_BIG, 0)
                  return c4d.DRAWRESULT_OK
          Thank you.
            hello,
            using this to draw a circle at op position. You can use your handle position instead.
            The main point is retrieving the view matrix with bd.GetMg() to have you Y and X vectors lined with the view.
                   if drawpass == c4d.DRAWPASS_OBJECT:
                        rad = 20.0
                        bd.SetMatrix_Matrix(op, c4d.Matrix());
                        m = bd.GetMg();
                        m.off = bh.GetMg().off;
                        m.v3 = c4d.Vector(0.0);
                        m.v1 *= rad;
                        m.v2 *= rad;
                        bd.DrawCircle(m);
            mfersaouiM 1 Reply Last reply Reply Quote 2
              mfersaoui @Manuel
              @m_magalhaes
              Thank you. I made some changes but its work!
              Mustapha
