    DESC_PARENT_COLLAPSE Twirl Down
    r20sdkc++
    5 Posts 3 Posters 831 Views 1 Watching
    • D Offline
      d_schmidt
      Hello!
      I have a pretty simple question about how to create a twirl down group in the Attribute Manager such as this alt text
      I managed to track down that it uses DESC_PARENT_COLLAPSE, but I'm having trouble setting it up in GetDDescription(). The SDK doesn't really help with it and the forums didn't turn up any results so I'm a bit lost. Thanks for any help.
      Dan
        hello,
        You have to set the DESC_PARENT_COLLAPSE of the "parent" to -1 so it act as a parent. For the children, just set the ID to the parent's ID.
        virtual Bool GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags)
        		if (!description->LoadDescription(node->GetType()))
        			return false;
        		const DescID* singleid = description->GetSingleDescID();
        		DescID cid = DescLevel(firstID, DTYPE_REAL, 0);
        		// check if this parameter ID is requested (NOTE: this check is important for speed)
        		if (!singleid || cid.IsPartOf(*singleid, nullptr))
        			// define the new parameter description
        			BaseContainer settings = GetCustomDataTypeDefault(DTYPE_REAL);
        			settings.SetString(DESC_NAME, "A float"_s);
        			settings.SetInt32(DESC_PARENT_COLLAPSE, -1);
        			// set the new parameter
        			if (!description->SetParameter(cid, settings, ID_OBJECTPROPERTIES))
        				return false;
        		cid = DescLevel(secondID, DTYPE_REAL, 0);
        			settings.SetString(DESC_NAME, "Another float"_s);
        			settings.SetInt32(DESC_PARENT_COLLAPSE, firstID);
        				return false;
        		cid = DescLevel(thirdID, DTYPE_BOOL, 0);
        			BaseContainer settings = GetCustomDataTypeDefault(DTYPE_BOOL);
        			settings.SetString(DESC_NAME, "A Bool"_s);
        				return false;
        		flags |= DESCFLAGS_DESC::LOADED;
        		return SUPER::GetDDescription(node, description, flags);
        • S Offline
          s_bach
          just FYI: there is also a short description and an example snippet about DESC_PARENT_COLLAPSE in the Description Settings Manual.
          • D Offline
            d_schmidt
            Thank you both for the answers!
            Sorry about not finding that, Sebastian, it wasn't popping up when I searched the SDK.
            Dan
              hello,
              this thread will be considered as Solved tomorrow is you have nothing to add.
