    How ObjectData add PRIORITY and execute
    c++r20
    3 Posts 2 Posters 933 Views
      mike
      i am confuse about how to add PRIORITY in ObjectData like Skin and Hair object ? show in basic tab?
      and how to connect PRIORITY to ObjectData::Execute()? i try to use ObjectData::AddToExecute(), it work but not same as ExpressionTag, it will execute when i move cursor or other action, even execute after i closed objectplugin. it is strange. if any way execute ObjectData::Execute() like ExpressionTag do ?
      hope your help!
      • S Offline
        s_bach
        Objects and tags are two different things, so I would not expect them to work similarly.
        In the case of the Skin object, the priority parameter is simply added in the resource file. Take a look at the ocaskin.res file.
        GROUP Obaselist
          SEPARATOR { LINE; }
          PRIORITY ID_CA_SKIN_OBJECT_PRIORITY { ANIM OFF; NOCAMERA; }
        Within AddToExecution() the value of that parameter is read, converted to EXECUTIONPRIORITY and used to set the priority value of PriorityList::Add().
          mike @s_bach
          @s_bach Thank you!
