    Moving\Deleting nodes with Python
    pythonr20
    3 Posts 2 Posters 966 Views 1 Watching
    • S Offline
      sheilan
      I've got a GvNode that I can rename and control, but I'm not sure how I can delete or move it's position in Xpresso.
      Thanks in advance,
      Sheilan.
        Hi @sheilan,
        Moving Xpresso node have been discussed here, same warning as Andreas did, ID may change in the future and break your stuff since there is no symbols for theses data.
        Regarding how to delete a GvNode, as you may have seen, GvNode inherit from BaseList2D which inherit from GeListNode, so you can use the GeListNode.Remove method.
        Here an example:
            # Checks if selected object is valid
            if op is None:
                raise ValueError("op is none, please select one object.")
            # Retrieves the xpresso Tag
            xpressoTag = op.GetTag(c4d.Texpresso)
            if xpressoTag is None:
                raise ValueError("Make sure the selected object get an Xpresso Tag.")
            # Retrieves the node master
            gvNodeMaster = xpressoTag.GetNodeMaster()
            if gvNodeMaster is None:
                raise RuntimeError("Failed to retrieves the Node Master.")
            # Retrieves the Root node (the Main XGroup) that holds all others nodes
            gvRoot = gvNodeMaster.GetRoot()
            if gvRoot is None:
                raise RuntimeError("Failed to retrieves the Root Node.")
            # Iterates overs all nodes of this root node.
            firstNode = gvRoot.GetDown()
            if firstNode is None:
                raise RuntimeError("Failed to retrieves the First Node.")
            # Defines Y size
            firstNode.GetDataInstance().GetContainerInstance(1001).GetContainerInstance(1000)[109] = 50
            # Defines X size
            firstNode.GetDataInstance().GetContainerInstance(1001).GetContainerInstance(1000)[108] = 100
            # Defines the Y position
            firstNode.GetDataInstance().GetContainerInstance(1001).GetContainerInstance(1000)[101] = -200
            # Defines the X position
            firstNode.GetDataInstance().GetContainerInstance(1001).GetContainerInstance(1000)[100] = -200
            # GvNode is a GeListNode so you can simply use Remove
            firstNode.Remove()
            # Updates Cinema 4D
        If you have any questions, let me know.
        • S Offline
          sheilan
          Works perfectly. Thanks!
          • M m_adam referenced this topic on
