    Output Current Sound Track Name
    pythonr20
    12 Posts 2 Posters 3.6k Views 1 Watching
    • mrittmanM Offline
      mrittman @s_bach
      Thanks so much @s_bach, this is really helpful!
      • mrittmanM Offline
        mrittman
        @s_bach I'm not super savvy when it comes to programming. If I had 18 or so tracks, what would be the proper way to write this code so it loops through all of them?
        • S Offline
          s_bach
          the tracks of an object are stored in a list. You can access the first track using GetFirstCTrack(). Then you can loop over all tracks with an ordinary while() loop and GetNext().
          track = op.GetFirstCTrack()
          while track is not None:
          		print(track.GetName())
          		track = track.GetNext()
          See also the example in the C++ CTrack documentation.
          mrittmanM 1 Reply Last reply Reply Quote 0
          • mrittmanM Offline
            mrittman @s_bach
            @s_bach So something like this?
            start = track[c4d.CID_SOUND_START]
            # get length
            # length is stored as a string; need to convert it to int
            length = track[c4d.CID_SOUND_LENGTH]
            length = length[:-2]
            length = int(float(length))
            fps = doc.GetFps()
            end = start + c4d.BaseTime(length, fps)
            # check if the current frame is within the range of the sound clip
            curTime = doc.GetTime()
            if curTime >= start and curTime < end:
                print("Uses Track: " + track.GetName())
                print("no hit")
            I'm really struggling with wrapping my head around this šŸ˜ž
            • S Offline
              s_bach
              Well, you indentation is off. And you are missing
              at the end.
              Besides that, this should work:
                      # get length
                      fps = doc.GetFps()
                          print("no hit")
              I strongly suggest to get familiar with the basics of Python first.
              • mrittmanM Offline
                mrittman @s_bach
                Thanks @s_bach, I really appreciate your help. I’m more of a motion designer, but wanted to tailor the scene I’m working on to make it easier.
                HTML/CSS come really easy to me, but my brain just comes to a halt when I try and get my head around python šŸ˜•
                • mrittmanM Offline
                  mrittman
                  Also, with this code, I am getting the spinning beachball of death šŸ˜•
                  It must be trapped in the loop maybe?
                  • S Offline
                    s_bach
                    are you sure the indentation of your code is correct? Do you call
                    at the end of your loop?
                    What is the context of your code? Are you calling it whining a script or a Python Tag? Please post the full code you are actually using.
                    If a "while" loop is not suitable, you could also use GetCTracks() to get a list of all the tracks.
                    tracks = op.GetCTracks()
                    for track in tracks:
                    • mrittmanM Offline
                      mrittman @s_bach
                      @s_bach Okay it's kind of working now, but is only outputting the last track in the list. I am using this script in a python tag:
                          # find object in scene, store in obj
                          obj = doc.SearchObject('VO')
                          # store some variables
                          track = obj.GetCTracks()
                          obj[c4d.ID_USERDATA,4] = track[0].GetName()
                          track[0][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,6]
                          track[0][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,7]
                          track[0][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,14]
                          obj[c4d.ID_USERDATA,10] = track[1].GetName()
                          track[1][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,11]
                          track[1][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,12]
                          track[1][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,9]
                          obj[c4d.ID_USERDATA,15] = track[2].GetName()
                          track[2][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,16]
                          track[2][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,17]
                          track[2][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,18]
                          obj[c4d.ID_USERDATA,3] = track[3].GetName()
                          track[3][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,20]
                          track[3][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,21]
                          track[3][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,22]
                          obj[c4d.ID_USERDATA,24] = track[4].GetName()
                          track[4][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,25]
                          track[4][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,26]
                          track[4][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,27]
                          obj[c4d.ID_USERDATA,29] = track[5].GetName()
                          track[5][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,30]
                          track[5][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,31]
                          track[5][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,32]
                          obj[c4d.ID_USERDATA,34] = track[6].GetName()
                          track[6][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,35]
                          track[6][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,36]
                          track[6][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,37]
                          obj[c4d.ID_USERDATA,39] = track[7].GetName()
                          track[7][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,40]
                          track[7][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,41]
                          track[7][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,42]
                          obj[c4d.ID_USERDATA,44] = track[8].GetName()
                          track[8][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,45]
                          track[8][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,46]
                          track[8][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,47]
                          obj[c4d.ID_USERDATA,49] = track[9].GetName()
                          track[9][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,50]
                          track[9][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,51]
                          track[9][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,52]
                          obj[c4d.ID_USERDATA,54] = track[10].GetName()
                          track[10][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,55]
                          track[10][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,56]
                          track[10][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,57]
                          obj[c4d.ID_USERDATA,59] = track[11].GetName()
                          track[11][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,60]
                          track[11][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,61]
                          track[11][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,62]
                          obj[c4d.ID_USERDATA,64] = track[12].GetName()
                          track[12][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,65]
                          track[12][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,66]
                          track[12][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,67]
                          obj[c4d.ID_USERDATA,69] = track[13].GetName()
                          track[13][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,70]
                          track[13][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,71]
                          track[13][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,72]
                          obj[c4d.ID_USERDATA,74] = track[14].GetName()
                          track[14][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,75]
                          track[14][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,76]
                          track[14][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,77]
                          obj[c4d.ID_USERDATA,79] = track[15].GetName()
                          track[15][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,80]
                          track[15][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,81]
                          track[15][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,82]
                          obj[c4d.ID_USERDATA,84] = track[16].GetName()
                          track[16][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,85]
                          track[16][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,86]
                          track[16][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,87]
                          obj[c4d.ID_USERDATA,89] = track[17].GetName()
                          track[17][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,90]
                          track[17][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,91]
                          track[17][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,92]
                          # outputs the current track name where playhead is
                          traks = obj.GetCTracks()
                          for trak in traks:
                              start = trak[c4d.CID_SOUND_START]
                              # get length
                              length = trak[c4d.CID_SOUND_LENGTH]
                              fps = doc.GetFps()
                                  obj[c4d.ID_USERDATA,19] = trak.GetName()
                                  obj[c4d.ID_USERDATA,19] = "No Track"
                              trak = trak.GetNext()
                      • S Offline
                        s_bach
                        it seems you just write the name of the last track into your user data field:
                        Since you do not extend that string, it can only show one name.
