    Output Current Sound Track Name
    pythonr20
    12 Posts 2 Posters 3.6k Views 1 Watching
    • mrittmanM Offline
      mrittman
      Anyone know if it's possible to output a track name when the playhead is hovering a particular soundwave in the timeline? I'm trying to display the name of the track in my viewport as I hear it play.
      Soundwave:
      Track name example:
      Also, when I'm in a Take other than Main, it doesn't show the soundwave in the timeline. Is it possible to show this somehow?
      Sound tracks with Takes
      • S Offline
        s_bach
        "soundwaves" are organized as animation tracks (CTrack) referencing sound files.
        You can check if the current frame is in the range of a given CTrack. This range is the result of the start position of the track plus the length of the sound file.
        The length of the sound file can be obtained from the track, but the value is stored as a string. So you would have to convert that into a time value (BaseTime).
        Such a check can look like this:
        start = track[c4d.CID_SOUND_START]
        # get length
        # length is stored as a string; need to convert it to int
        length = track[c4d.CID_SOUND_LENGTH]
        length = length[:-2]
        length = int(float(length))
        fps = doc.GetFps()
        end = start + c4d.BaseTime(length, fps)
        # check if the current frame is within the range of the sound clip
        curTime = doc.GetTime()
        if curTime >= start and curTime < end:
            print("Uses Track: " + track.GetName())
            print("no hit")
        Of course, you have to loop over all sound tracks associated with a given object.
        You also find information on CTracks in the C++ documentation: CTrack Manual.
        mrittmanM 1 Reply Last reply Reply Quote 0
        • mrittmanM Offline
          mrittman @s_bach
          Thanks so much @s_bach, this is really helpful!
          • mrittmanM Offline
            mrittman
            @s_bach I'm not super savvy when it comes to programming. If I had 18 or so tracks, what would be the proper way to write this code so it loops through all of them?
            • S Offline
              s_bach
              the tracks of an object are stored in a list. You can access the first track using GetFirstCTrack(). Then you can loop over all tracks with an ordinary while() loop and GetNext().
              track = op.GetFirstCTrack()
              while track is not None:
              		print(track.GetName())
              		track = track.GetNext()
              See also the example in the C++ CTrack documentation.
              • mrittmanM Offline
                mrittman @s_bach
                @s_bach So something like this?
                # get length
                fps = doc.GetFps()
                    print("no hit")
                I'm really struggling with wrapping my head around this šŸ˜ž
                • S Offline
                  s_bach
                  Well, you indentation is off. And you are missing
                  at the end.
                  Besides that, this should work:
                          # get length
                          fps = doc.GetFps()
                              print("no hit")
                  I strongly suggest to get familiar with the basics of Python first.
                  • mrittmanM Offline
                    mrittman @s_bach
                    Thanks @s_bach, I really appreciate your help. I’m more of a motion designer, but wanted to tailor the scene I’m working on to make it easier.
                    HTML/CSS come really easy to me, but my brain just comes to a halt when I try and get my head around python šŸ˜•
                    • mrittmanM Offline
                      mrittman
                      Also, with this code, I am getting the spinning beachball of death šŸ˜•
                      It must be trapped in the loop maybe?
                      • S Offline
                        s_bach
                        are you sure the indentation of your code is correct? Do you call
                        at the end of your loop?
                        What is the context of your code? Are you calling it whining a script or a Python Tag? Please post the full code you are actually using.
                        If a "while" loop is not suitable, you could also use GetCTracks() to get a list of all the tracks.
                        tracks = op.GetCTracks()
                        for track in tracks:
                        • mrittmanM Offline
                          mrittman @s_bach
                          @s_bach Okay it's kind of working now, but is only outputting the last track in the list. I am using this script in a python tag:
                              # find object in scene, store in obj
                              obj = doc.SearchObject('VO')
                              # store some variables
                              track = obj.GetCTracks()
                              obj[c4d.ID_USERDATA,4] = track[0].GetName()
                              track[0][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,6]
                              track[0][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,7]
                              track[0][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,14]
                              obj[c4d.ID_USERDATA,10] = track[1].GetName()
                              track[1][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,11]
                              track[1][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,12]
                              track[1][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,9]
                              obj[c4d.ID_USERDATA,15] = track[2].GetName()
                              track[2][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,16]
                              track[2][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,17]
                              track[2][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,18]
                              obj[c4d.ID_USERDATA,3] = track[3].GetName()
                              track[3][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,20]
                              track[3][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,21]
                              track[3][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,22]
                              obj[c4d.ID_USERDATA,24] = track[4].GetName()
                              track[4][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,25]
                              track[4][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,26]
                              track[4][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,27]
                              obj[c4d.ID_USERDATA,29] = track[5].GetName()
                              track[5][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,30]
                              track[5][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,31]
                              track[5][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,32]
                              obj[c4d.ID_USERDATA,34] = track[6].GetName()
                              track[6][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,35]
                              track[6][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,36]
                              track[6][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,37]
                              obj[c4d.ID_USERDATA,39] = track[7].GetName()
                              track[7][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,40]
                              track[7][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,41]
                              track[7][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,42]
                              obj[c4d.ID_USERDATA,44] = track[8].GetName()
                              track[8][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,45]
                              track[8][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,46]
                              track[8][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,47]
                              obj[c4d.ID_USERDATA,49] = track[9].GetName()
                              track[9][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,50]
                              track[9][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,51]
                              track[9][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,52]
                              obj[c4d.ID_USERDATA,54] = track[10].GetName()
                              track[10][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,55]
                              track[10][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,56]
                              track[10][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,57]
                              obj[c4d.ID_USERDATA,59] = track[11].GetName()
                              track[11][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,60]
                              track[11][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,61]
                              track[11][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,62]
                              obj[c4d.ID_USERDATA,64] = track[12].GetName()
                              track[12][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,65]
                              track[12][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,66]
                              track[12][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,67]
                              obj[c4d.ID_USERDATA,69] = track[13].GetName()
                              track[13][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,70]
                              track[13][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,71]
                              track[13][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,72]
                              obj[c4d.ID_USERDATA,74] = track[14].GetName()
                              track[14][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,75]
                              track[14][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,76]
                              track[14][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,77]
                              obj[c4d.ID_USERDATA,79] = track[15].GetName()
                              track[15][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,80]
                              track[15][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,81]
                              track[15][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,82]
                              obj[c4d.ID_USERDATA,84] = track[16].GetName()
                              track[16][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,85]
                              track[16][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,86]
                              track[16][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,87]
                              obj[c4d.ID_USERDATA,89] = track[17].GetName()
                              track[17][c4d.CID_SOUND_ONOFF] = obj[c4d.ID_USERDATA,90]
                              track[17][c4d.CID_SOUND_START] = obj[c4d.ID_USERDATA,91]
                              track[17][c4d.CID_SOUND_NAME] = obj[c4d.ID_USERDATA,92]
                              # outputs the current track name where playhead is
                              traks = obj.GetCTracks()
                              for trak in traks:
                                  start = trak[c4d.CID_SOUND_START]
                                  # get length
                                  length = trak[c4d.CID_SOUND_LENGTH]
                                  fps = doc.GetFps()
                                      obj[c4d.ID_USERDATA,19] = trak.GetName()
                                      obj[c4d.ID_USERDATA,19] = "No Track"
                                  trak = trak.GetNext()
                          • S Offline
                            s_bach
                            it seems you just write the name of the last track into your user data field:
                            Since you do not extend that string, it can only show one name.
