    DeformCache Update
    r19python
    3 Posts 2 Posters 634 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      I used a cube object as a test and found that the DeformeCache obtained during script execution was the same. The cube object contains the pose morph tag (point type) and a deformer sub-object. The script does it to get the current DeformCache, then modify the intensity of the posemorph, and update to get the DeformCache again. I found that they are the same
      Is there a problem with my code, or is it logically impossible to do this?
      This is the script code:
          tag = op.GetTag(c4d.Tposemorph)
          one = op.GetDeformCache().GetAllPoints()
          print one[3]
          tag[4000,1101] = 0
          two = op.GetDeformCache().GetAllPoints()
          print two[3]
      Thanks for any help
      相信我,可以的!
        Hi @chuanzhen the deformed cache is only a representation of the current frame deformation state.
        That means, if you change the data, frame or whatever you need to rebuild the cache, this can be done with BaseDocument.ExecutePasses.
        chuanzhenC 1 Reply Last reply Reply Quote 1
          chuanzhen @m_adam
          @m_adam Thanks👍
          相信我,可以的!
