    Instances of Array Objects and co.
    6 Posts 0 Posters 732 Views
      On 29/05/2003 at 10:18, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I tested the first version of my NPR and it is working fine but when I want to render ArrayObjects and co he only render the original object. Is there a command to get the instances of the array objexts.
      thanks
      Cathleen
        On 29/05/2003 at 10:19, xxxxxxxx wrote:
        sorry but I don't changed the language. I have this problem in C++ and not in C.O.F.F.E.E.
        Cathleen
          On 29/05/2003 at 13:49, xxxxxxxx wrote:
          Hi Cathleen,
          You have to dive into the caches. I chose to generate my NPR strokes and fill geometry before the internal rendering began. You can use the geometry from the render document but I found that to be a little tricky.
          darf - cidertank.com
            On 01/06/2003 at 04:49, xxxxxxxx wrote:
            thank you but how can I dive into the cache?
            Cathleen
              On 04/06/2003 at 13:40, xxxxxxxx wrote:
              I have found a much easier solution with BaseDocument->Polygonize. There you get all objects as polygons.
              Cathleen
                On 04/06/2003 at 20:12, xxxxxxxx wrote:
                Quote: Originally posted by Cathleen on 04 June 2003
                > hi,
                > Cathleen
                Well, that is an option. The only problem is that it is not RAM friendly. In large scenes it can use alot of RAM ( remember the scenes have already been polygonalized for rendering, the result of which is available through various volume data functions ).
                bt
