    MCOMMAND_JOIN issue
    10 Posts 4 Posters 2.7k Views 2 Watching
    • merkvilsonM Offline
      merkvilson
      Hello PluginCafe πŸ™‚
      I need to merge 2 objects in OBJECT_GENERATOR plugin and return the result but it returns only 1 object. my code looks like this. Am I doing something wrong?
      import c4d, os
      from c4d import plugins, utils, Vector as v
      class Otest(c4d.plugins.ObjectData):
          def GetVirtualObjects(self, op, hh):
              virtualDoc = c4d.documents.BaseDocument()
              cube1 = c4d.BaseObject(c4d.Ocube)
              cube1.SetAbsPos(v(0,0,110))
              virtualDoc.InsertObject(cube1)
              cube2 = c4d.BaseObject(c4d.Ocube)
              cube2.SetAbsPos(v(0,0,-110))
              virtualDoc.InsertObject(cube2)
              virtualDoc.ExecutePasses(c4d.threading.GeGetCurrentThread(), True, True, True, c4d.BUILDFLAGS_INTERNALRENDERER)
              output = utils.SendModelingCommand(command = c4d.MCOMMAND_JOIN, doc = virtualDoc, list = [cube1,cube2])[0]
              return output
          plugins.RegisterObjectPlugin(id = 1000000,
                                       str = "Test",
                                       g = Otest,
                                       description = None,
                                       info = c4d.OBJECT_GENERATOR,
                                       icon = None)
        Hi @merkvilson; MCOMAND_JOIN have changed in R18, now objects have to be under the same hierarchy.
        See Behaviour of MCOMMAND_JOIN different in R18 or [Python] SendModelingCommand().
        • mikeudinM Offline
          mikeudin
          You have to combine objects to null, for example:
          from c4d import gui
          def smc(listy):
              null = c4d.BaseObject(c4d.Onull)
              for o in listy:
                  o.InsertUnder(null)
              res = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_JOIN,
                                              list = [null],
                                              mode = c4d.MODELINGCOMMANDMODE_ALL,
                                              bc = c4d.BaseContainer(),
                                              doc = doc)
              return res[0]
              obs = doc.GetActiveObjects(0)
              doc.InsertObject(smc(obs))
          https://mikeudin.net
            merkvilson
            Thanks guys!
            It worked!
            I had to double-check this in SDK 😁
              merkvilson
              btw. is it possible to sort the search results by date? I was getting 8 years old posts when looking for this topic.
                For sure go to https://developers.maxon.net/forum/search (you can also access this page by clicking on the little bolts/nuts which appears after a click on the top search bar.)
                Then on this page, you can define more option to search, and you can decide which kind of sorting you prefer.
                merkvilsonM 1 Reply Last reply Reply Quote 2
                  merkvilson @m_adam
                  Thanks, buddy. Will take this into account πŸ‘Œ
                    Finally please do not forget to mark your topic as solved. See Q&A Functionality πŸ˜‰ .
                    merkvilsonM 1 Reply Last reply Reply Quote 0
                      merkvilson @m_adam
                      @m_adam
                      I was looking for "Solved" option in tags section but could not find it.
                      Finally, I figured this out.
                      Seems like this is because my browser's zoom is set to 150%
                      alt text
                      • a_blockA Offline
                        a_block
                        thanks for pointing out this issue. We'll see if can get a fix for that (not all tags visible, if zooming in with browser).
                        In the end Maxime wasn't referring to tags at all. Instead he was talking about the Q&A Function we have in this forum. I took the freedom to mark this thread as solved (see this shiny green stamp next to the headline ☺ ).
                        Andreas
