    GeDialog in a Python Script does not work
    r20python
    3 Posts 2 Posters 978 Views 1 Watching
    • fwilleke80F Offline
      fwilleke80
      I'm probably missing something here, but I can't get a GeDialog in a Python Script (not plugin!) to work at all.
      class TestDialog(c4d.gui.GeDialog):
          BUTTON_ID = 1001
          def CreateLayout(self):
              self.SetTitle("A meaningful dialog title")
              self.AddButton(self.BUTTON_ID, c4d.BFH_SCALE|c4d.BFV_SCALE, 100, 25, "Close Dialog")
              #self.AddDlgGroup(c4d.DLG_OK|c4d.DLG_CANCEL)
          def Message(self, msg, result):
          def Command(self, id, msg):
              if id==self.BUTTON_ID:
                self.Close()
      # Main function
          # Test dialog
          diag = TestDialog()
          diag.Open(dlgtype=c4d.DLG_TYPE_MODAL, defaultw=400, defaulth=400)
      # Execute main()
      The only thing that happens when executing this script is that an empty dialog appears (the size is correct, but there is neither a dialog title, nor any gadgets) that can only be closed by force-quitting Cinema.
      • The console does not show any errors or exceptions.
      • I tested the same code in R20 and R19, both with the exact same result.
      • Manually calling diag.CreateLayout() before the diag.Open() call did not change anything.
      What am I doing wrong?
      Frank
      www.frankwilleke.de
        Hi Frank, you actually return True from the Message method while the result of the parent call was expected
            return c4d.gui.GeDialog.Message(self, msg, result)
        For more information please read the documentation about GeDialog.Message.
          fwilleke80
          Aaah, ok, thanks!
          I browsed a couple of examples here in the forum, and always saw them return True. Should've known better 🙂
          Frank
          www.frankwilleke.de
