    Get userdata Button state on object in Python tag
    pythonr20
    7 Posts 2 Posters 3.2k Views 1 Watching
    • B Offline
      bonsak
      Hi
      I have a userdata button on a null and a python tag on that null. In the tag i try to get the state of the button on the object:
      def message(id, data) :
        if id == 17:
            print "UserData-ID: ", data["descid"][1].id
      This only works if the userdata button is on the tag. How can i get the state of the userdata botton on the object from inside the python tag?
      Regards
      Bonsak
        Hi @bonsak, there is a way but is not recommended and pretty experimental, so if a strange behavior occurs, we can't do anything. In the same time, it's the only solution.
        With that said we get AddEventNotification, which allow receiving messages from another object.
        Here is the code of the python tag
        def message(msg_type, data):
            if msg_type == c4d.MSG_NOTIFY_EVENT:
                event_data = data['event_data']
                if event_data['msg_id'] == c4d.MSG_DESCRIPTION_COMMAND:
                    desc_id = event_data['msg_data']['id']
                    if desc_id[1].id == 17: # The ID of the User Data
                        print "Button Pressed"
            obj = op.GetObject()
            # Check if we already listen for message
            if not obj.FindEventNotification(doc, op, c4d.NOTIFY_EVENT_MESSAGE):
                obj.AddEventNotification(op, c4d.NOTIFY_EVENT_MESSAGE, 0, c4d.BaseContainer())
        • B Offline
          bonsak
          Thanks!
          I couldnt get it to work without modifying it like this:
                      #print event_data['msg_id']
                      if event_data['msg_data']['id'][1].id == 18:
                      #desc_id = event_data['msg_data']['id']
                      #if desc_id[1].id == 17: # The ID of the User Data
                      #    print "Button Pressed"
          Regards
          Bonsak
          EDIT m_adam: Fixed your code snippet
            Which version do you use?
            Can you provide a scene?
            • B Offline
              bonsak
              R20 20.0.30
              0_1542379593819_userdata-button.c4d
                Hi @bonsak,
                The code within the file and in the forum is not the same.
                The actual issue in your code posted on the forum is you are checking for if event_data['msg_id'] == 18: instead of if event_data['msg_data']['id'][1].id == 18:
                Moreover, in the scene you attached which use my code, the button ID is set to 2.
                So if you change if event_data['msg_id'] == 18: toif event_data['msg_id'] == 2: make it works.
                • B Offline
                  bonsak
                  Ah! So event_data['msg_data']['id'] is the id of the userdata.
                  Didnt read your code comments 🙂
                  Thanks alot!
                  Regards
                  Bonsak
