    Set Tracers "trace link" (inExclude) field from python tag
    r20python
    3 Posts 2 Posters 970 Views
    • B Offline
      bonsak
      Hi
      Im trying to set the Tracer objects "Trace link" inExclude list from a python tag.
      I dont get any errors and the GetObjectCount method returns the correct number of objects, but none are visible in the list itself. Any help appreciated. See attached file for example.
          # Get userdata from parent
          root = op.GetObject().GetUp()[c4d.ID_USERDATA,1]
          # Get first joint
          hipJoint = root.GetDown()
          # Get second joint
          kneeJoint = hipJoint.GetDown()
          # Get the tracers inExclude field
          tracerList = op.GetObject()[c4d.MGTRACEROBJECT_OBJECTLIST]
          # Insert hip
          tracerList.InsertObject(hipJoint, 1)
          # Insert knee
          tracerList.InsertObject(kneeJoint, 1)
          # Returns 2 but none are visible in the tracers inExclude field
          print tracerList.GetObjectCount()
      Regards
      Bonsak
      0_1542205877232_inexclude-python-update.c4d
      • S Offline
        s_bach
        when you "get" the InExclude list in Python, you get a copy of the value, not a reference.
        After editing the copy you have to store the new value again in the original object:
        # get data
        # modify data
        #store data
        op.GetObject()[c4d.MGTRACEROBJECT_OBJECTLIST] = tracerList
        But remember: a tag is executed every time the scene is evaluated. So the objects are added to the list again and again. You could maybe check if the list is empty and return if that is not the case:
        if tracerList.GetObjectCount() > 0:
        Please also use the Q&A system to mark your threads as questions.
        • B Offline
          bonsak
          Awesome! Thanks.
          Regards
          Bonsak
