    Crash in class SetUsedFrameworks
    c++macos
    5 Posts 2 Posters 1.3k Views 2 Watching
    • fwilleke80F Offline
      fwilleke80
      I have a plugin here. When I run it on OSX in the debugger, I get a breakpoint on C4D startup, in:
      core.framework/source/maxon/register.h, line 38
      module._usedFrameworks = ids.GetFirst();
      Running it without the debugger leads to a crash.
      With the Windows build, this does not happen; only on OSX. How can I fix this?
      Thanks & greetings,
      Frank
      www.frankwilleke.de
      • r_giganteR Offline
        r_gigante
        Good morning Frank!
        I'm lacking a few information here to assess and help:
        • are you using the ProjectTool to assemble the Xcode project?
        • if yes, can you provide the projectdefinition.txt you're using?
        • can you provide the call stack when the breakpoint is hit?
        Best, Riccardo
          fwilleke80
          Hi Ricardo 🙂
          Thanks for the reply!
          1. Yes, I am
          2. Here it is:
            // Supported platforms - can be [Win64;OSX]
            Platform=Win64;OSX
            // Type of project - can be [Lib;DLL;App]
            Type=DLL
            // API dependencies
            APIS=cinema.framework;mesh_misc.framework;math.framework;crypt.framework;python.framework;core.framework;
            // C4D component
            C4D=true
            stylecheck.level=3 // must be set after c4d=true
            stylecheck.enum-registration=false
            stylecheck.enum-class=false
            // Custom ID
            ModuleId=com.mydomain.mymodule
          3. Screenshot of the call stack
          EDIT: And here's the breakpoint:
          EDIT 2: Additional information
          I'm still using OS X 10.11.6 El Capitan, with XCode 8.2.1. Have successfully built other plugins on this machine. C4D version is 20.030 (Build RB257898).
          Frank
          www.frankwilleke.de
            r_gigante
            Hi Frank, thanks for following up with these details.
            As from our Cinema 4D documentation about Development on macOS we only support Xcode 9.x for Cinema R20.x.
            Please try to compile your plugin with a supported development environment and if it fails again we'll look deeper into it.
            Best, Riccardo
              fwilleke80
              Hi Ricardo,
              I can't do that, unfortunately. There are several reasons why I cannot update my machine to a later OSX version than El Capitan, at the moment. I did not encounter any problems so far that could be tracked down to the XCode version.
              Btw, I solved the problem. For some reason, after running the Project Tool again in a fuzzy "F*** it, it has has to work!" moment, things started working. I am stumped, as I don't know the reason, but anyway, the problem's gone.
              Frank
              www.frankwilleke.de
