    How access to the listview from videopost
    Cinema 4D SDK
    r20 sdk
    1.2k
    • m_tamuraM
      m_tamura
      Cinema4D R20;
      Windows 10;
      C++;
      Hi all,
      I did add the simple listview custom GUI on the my VideoPost plugin.
      Listview is the same as the SDK example.
      Also, I have listview displayed in using GetDDescription in the VideoPost.
      And I'd like to access this list of data from the VideoPost function.
      e.g, GetItem or GetItemCount etc from the listview1 or listvew2.
      But I still do not know how to do it.
      If I want to do get data of the listview from VideoPost, what kind of procedure should I access?
      alt text
      GetDDescription in my VideoPost
      ///// inside My VideoPostPlugin GetDDescription //////////////
      ///// ListView ///////////////////////////////////////////////
      cid = DescLevel(MY_VIDEOPOST_TAB, DTYPE_GROUP, 0);
      if (!singleid || cid.IsPartOf(*singleid, nullptr)) // important to check for speedup c4d!
          BaseContainer secondgroup = GetCustomDataTypeDefault(DTYPE_GROUP);
          secondgroup.SetString(DESC_NAME, "Test Tab"_s);
          if (!description->SetParameter(cid, secondgroup, DescLevel(0)))
              return true;
      DescID cid_Tree = DescLevel(IDS_MY_CUSTOMGUI, ID_MY_CUSTOMGUI_CUSTOMDATATYPE, 0);
          BaseContainer bc = GetCustomDataTypeDefault(ID_MY_CUSTOMGUI_CUSTOMDATATYPE);
          bc.GetCustomDataType(DESC_CUSTOMGUI, ID_MY_CUSTOMGUI_CUSTOMDATATYPE);
          if (!description->SetParameter(cid_Tree, bc, DescLevel(MY_VIDEOPOST_TAB))) return TRUE;
      Any opinion will be helpful.
      Best Regards,
      Makoto,
      • S
        s_bach
        in your code snippet it looks like that you are using a custom data type and a custom GUI. Is that correct?
        So your actual question is how to access the custom data type value?
        You can access a parameter using GetParameter(). From the obtained GeData object you can access the custom data with GetCustomDataType().
        Within your module you can cast that pointer to your iCustomDataType based class.
        In this example the custom data is iMyDataType:
        // get parameter
        GeData data;
        if (!activeObject->GetParameter(parameterID, data, DESCFLAGS_GET::NONE))
        	return maxon::UnexpectedError(MAXON_SOURCE_LOCATION);
        // get custom data
        CustomDataType* const customData = data.GetCustomDataType(MY_CUSTOM_DATA_TYPE);
        if (!customData)
        // cast
        iMyDataType* const myDataTyp = (iMyDataType*)customData;
        ApplicationOutput(myDataTyp->_string);
        Be sure to use the fully constructed DescID including the data type.
        • m_tamuraM
          m_tamura
          Thank you, Sebastian.
          Your reply clearly shows what I should learn.
          I need a little time to understand, but I am working on it and I made a little progress.
          Makoto
