    Multi paragraph text in .str files
    13 Posts 0 Posters 1.5k Views
      On 10/08/2017 at 18:53, xxxxxxxx wrote:
      Hi all,
      Andreas, is still valid the pipe symbol for the newline?
      Thanks in advance
      Renato
        On 11/08/2017 at 02:17, xxxxxxxx wrote:
        Hi Renato,
        I'm not aware of any changes on our end. But as you are asking, you are probably having problems with it?
          On 11/08/2017 at 09:21, xxxxxxxx wrote:
          Hi Andreas,
          yes, i'm trying to output some lines to:
          STRING MY_TEXT_INFO { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }
          adding the Pipe Symbol.. but the output is with pipe instead a newline:
          here the example:
          Grid Name: density - Grid Class: unknown | Grid Name: temperature - Grid Class: unknown | Grid Name: v - Grid Class: unknown |
          would be good to have:
            On 11/08/2017 at 18:07, xxxxxxxx wrote:
            If you create the string in your code, you need to use
            actual newlines.
              On 11/08/2017 at 19:49, xxxxxxxx wrote:
              Hi Niklas, what do you mean with "actual newline" ?
              I tried to construct my string with '\n' without luck.
                On 12/08/2017 at 17:59, xxxxxxxx wrote:
                I'm sorry... but maybe too hot in the brain.
                Thanks all for your time 🙂
                  On 14/08/2017 at 08:49, xxxxxxxx wrote:
                  just for future readers, as it might not be completely clear: When setting a multi-line string parameter via code, one needs to use newline '\n' to add additional lines. While in the string file it is the pipe symbol '|'.
                  I will add this information also to one of the code examples.
                    On 14/08/2017 at 09:57, xxxxxxxx wrote:
                    Thanks Andreas 🙂
                      On 25/08/2017 at 11:56, xxxxxxxx wrote:
                      I was just giving this a try in a c4d_strings.str stringtable. I get the string with the Pipe symbol still in
                      the text (using GeLoadString in Python), rather than it being replaced by a newline. Does this only work
                      in C++ or in description/dialog stringtables?
                      Thanks!
                        On 29/08/2017 at 08:20, xxxxxxxx wrote:
                        Hi Niklas,
                        indeed GeLoadString() does not care for line wraps, neither in C++ nor in Python.
                        A small helper function could look like this:
                        static String GeLoadStringUpd(Int32 id)
                        	Int32 i;
                        	String str = GeLoadString(id);
                        	for (i = str.GetLength() - 1; i >= 0; i--)
                        		if (str[i] == '|')
                        			str.Delete(i, 1);
                        			str.Insert(i, GeGetLineEnd());
                        	return str;
                          On 30/08/2017 at 02:31, xxxxxxxx wrote:
                          for me, \u000d works to create a line break in a str file.
