    Multi paragraph text in .str files
    13 Posts 0 Posters 1.5k Views
      On 24/10/2016 at 01:57, xxxxxxxx wrote:
      in your resource file you'd use a STRING with CUSTOMGUI MULTISTRING. Additionally add the READONLY flag to mimic the static text behavior.
      Like so:
      STRING MY_PARAGRAPH { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }
      Inside of the string you can use the pipe symbol ("|") for newline.
        On 10/08/2017 at 18:53, xxxxxxxx wrote:
        Hi all,
        Andreas, is still valid the pipe symbol for the newline?
        Thanks in advance
        Renato
          On 11/08/2017 at 02:17, xxxxxxxx wrote:
          Hi Renato,
          I'm not aware of any changes on our end. But as you are asking, you are probably having problems with it?
            On 11/08/2017 at 09:21, xxxxxxxx wrote:
            Hi Andreas,
            yes, i'm trying to output some lines to:
            STRING MY_TEXT_INFO { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }
            adding the Pipe Symbol.. but the output is with pipe instead a newline:
            here the example:
            Grid Name: density - Grid Class: unknown | Grid Name: temperature - Grid Class: unknown | Grid Name: v - Grid Class: unknown |
            would be good to have:
              On 11/08/2017 at 18:07, xxxxxxxx wrote:
              If you create the string in your code, you need to use
              actual newlines.
                On 11/08/2017 at 19:49, xxxxxxxx wrote:
                Hi Niklas, what do you mean with "actual newline" ?
                I tried to construct my string with '\n' without luck.
                  On 12/08/2017 at 17:59, xxxxxxxx wrote:
                  I'm sorry... but maybe too hot in the brain.
                  Thanks all for your time 🙂
                    On 14/08/2017 at 08:49, xxxxxxxx wrote:
                    just for future readers, as it might not be completely clear: When setting a multi-line string parameter via code, one needs to use newline '\n' to add additional lines. While in the string file it is the pipe symbol '|'.
                    I will add this information also to one of the code examples.
                      On 14/08/2017 at 09:57, xxxxxxxx wrote:
                      Thanks Andreas 🙂
                        On 25/08/2017 at 11:56, xxxxxxxx wrote:
                        I was just giving this a try in a c4d_strings.str stringtable. I get the string with the Pipe symbol still in
                        the text (using GeLoadString in Python), rather than it being replaced by a newline. Does this only work
                        in C++ or in description/dialog stringtables?
                        Thanks!
                          On 29/08/2017 at 08:20, xxxxxxxx wrote:
                          Hi Niklas,
                          indeed GeLoadString() does not care for line wraps, neither in C++ nor in Python.
                          A small helper function could look like this:
                          static String GeLoadStringUpd(Int32 id)
                          	Int32 i;
                          	String str = GeLoadString(id);
                          	for (i = str.GetLength() - 1; i >= 0; i--)
                          		if (str[i] == '|')
                          			str.Delete(i, 1);
                          			str.Insert(i, GeGetLineEnd());
                          	return str;
                            On 30/08/2017 at 02:31, xxxxxxxx wrote:
                            for me, \u000d works to create a line break in a str file.
