    Multi paragraph text in .str files
    13 Posts 0 Posters 1.4k Views
      On 21/10/2016 at 05:12, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hello.
      Can I have a text paragraph as STATICTEXT in a NodeData plugin ?
      I have tried using \n but it doesn't work.
      Thank you.
        On 24/10/2016 at 01:57, xxxxxxxx wrote:
        in your resource file you'd use a STRING with CUSTOMGUI MULTISTRING. Additionally add the READONLY flag to mimic the static text behavior.
        Like so:
        STRING MY_PARAGRAPH { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }
        Inside of the string you can use the pipe symbol ("|") for newline.
          On 10/08/2017 at 18:53, xxxxxxxx wrote:
          Hi all,
          Andreas, is still valid the pipe symbol for the newline?
          Thanks in advance
          Renato
            On 11/08/2017 at 02:17, xxxxxxxx wrote:
            Hi Renato,
            I'm not aware of any changes on our end. But as you are asking, you are probably having problems with it?
              On 11/08/2017 at 09:21, xxxxxxxx wrote:
              Hi Andreas,
              yes, i'm trying to output some lines to:
              STRING MY_TEXT_INFO { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }
              adding the Pipe Symbol.. but the output is with pipe instead a newline:
              here the example:
              Grid Name: density - Grid Class: unknown | Grid Name: temperature - Grid Class: unknown | Grid Name: v - Grid Class: unknown |
              would be good to have:
                On 11/08/2017 at 18:07, xxxxxxxx wrote:
                If you create the string in your code, you need to use
                actual newlines.
                  On 11/08/2017 at 19:49, xxxxxxxx wrote:
                  Hi Niklas, what do you mean with "actual newline" ?
                  I tried to construct my string with '\n' without luck.
                    On 12/08/2017 at 17:59, xxxxxxxx wrote:
                    I'm sorry... but maybe too hot in the brain.
                    Thanks all for your time 🙂
                      On 14/08/2017 at 08:49, xxxxxxxx wrote:
                      just for future readers, as it might not be completely clear: When setting a multi-line string parameter via code, one needs to use newline '\n' to add additional lines. While in the string file it is the pipe symbol '|'.
                      I will add this information also to one of the code examples.
                        On 14/08/2017 at 09:57, xxxxxxxx wrote:
                        Thanks Andreas 🙂
                          On 25/08/2017 at 11:56, xxxxxxxx wrote:
                          I was just giving this a try in a c4d_strings.str stringtable. I get the string with the Pipe symbol still in
                          the text (using GeLoadString in Python), rather than it being replaced by a newline. Does this only work
                          in C++ or in description/dialog stringtables?
                          Thanks!
                            On 29/08/2017 at 08:20, xxxxxxxx wrote:
                            Hi Niklas,
                            indeed GeLoadString() does not care for line wraps, neither in C++ nor in Python.
                            A small helper function could look like this:
                            static String GeLoadStringUpd(Int32 id)
                            	Int32 i;
                            	String str = GeLoadString(id);
                            	for (i = str.GetLength() - 1; i >= 0; i--)
                            		if (str[i] == '|')
                            			str.Delete(i, 1);
                            			str.Insert(i, GeGetLineEnd());
                            	return str;
                              On 30/08/2017 at 02:31, xxxxxxxx wrote:
                              for me, \u000d works to create a line break in a str file.
