    h2 set path/environment variables
    17 Posts 0 Posters 1.8k Views
      On 15/10/2015 at 08:29, xxxxxxxx wrote:
      WOW this is so helpful guys , nice and thanks for sharing guys. But any tread on Reg..Key that can help? or its the same.
        On 15/10/2015 at 09:01, xxxxxxxx wrote:
        As Ilya said, you should definitely do it using the subprocess module.
        Ok, I used os.system.
        Shall test it with the examples given.
        Thanks, Pim
          On 16/10/2015 at 00:54, xxxxxxxx wrote:
          On the Mac I get an error OSError: [Errno 2] No such file or directory.
          It complains about .../python.2.6/subprocess.py" line 1126 in_execute _child.
          I did not yet tested it on a pc.
          On the Mac I am using R16.047.
          -Pim
            -Pim
            hi
            I test at windows os, example for opera(web browser, if installed).
            I have question, have you rules what enviro to use? i mean this:
            import os, platform, sys
            if platform.system().lower().startswith('win') : # winos
              pass
            elif platform.system().lower().startswith('dar') : # macos
              pass
            under pass - your functions with vars
              On 16/10/2015 at 01:45, xxxxxxxx wrote:
              Yes, I use
              if c4d.GeGetCurrentOS() == c4d.GE_WIN:
                windows ...
                mac ...
                On 16/10/2015 at 01:59, xxxxxxxx wrote:
                argh, sorry, i'm with code from my studying of scons(exescons)
                can post what targets of mac os you want, maybe mac users will help you
                  On 16/10/2015 at 02:09, xxxxxxxx wrote:
                  This is the command I want to give on the Mac:
                  /Applications/cloud_ui/ccl --help
                  I tested subprocess.Popen on the pc and it works ok.
                  Just like os.system.
                  What is the difference between os.system and subprocess.Popen?
                  -Pim
                    On 16/10/2015 at 02:15, xxxxxxxx wrote:
                    mmm, you need also shell commands or args for app
                    take look - https://docs.python.org/2/library/subprocess.html#popen-constructor
                      On 16/10/2015 at 07:00, xxxxxxxx wrote:
                      Any input on my subprocess.Popen issue?
                      On a pc, I got the same error message.
                        On 16/10/2015 at 08:03, xxxxxxxx wrote:
                        I got it now working.
                        Here an example on the pc, generating a tasklist and checking if a process is running.
                            ps= subprocess.Popen(r'tasklist.exe', shell=True, stdout=subprocess.PIPE)
                            output = ps.stdout.read()
                            ps.stdout.close()
                            ps.wait()
                            if ("cloud_ui" in output) :
                                print "found"
                                print "not found"
