    h2 set path/environment variables
    17 Posts 0 Posters 2.2k Views
      On 15/10/2015 at 01:28, xxxxxxxx wrote:
      while of course you can go down the environment variable road, you could also simply use the os.system() road with a properly formatted path.
      a) I'd recommend not to use backslash (\) as directory separator. In Python you can use the normal slash as well under Windows. This has the advantage, that the slash does not need to be escaped. So instead of 'C:\\dir\\walter.exe' you can simply use 'C:/dir/walter.exe'.
      b) In order to use spaces in filepaths, Windows expects the path to be enclosed in quotation marks. Then your path looks like so (note that the quotation marks have to be escaped using the backslash) : '"C:/dir with space/walter.exe"'
      So in your case: os.system('"C:/Program Files (x86)/..."')
        On 15/10/2015 at 01:35, xxxxxxxx wrote:
        Yes, and putting everything between quotes solved the issue.
        So instead of cd c:\program files
        cd "c:\program files"
        Thanks, pim
          On 15/10/2015 at 07:22, xxxxxxxx wrote:
          strange
          i made test with such code all is ok
          import os, sys, subprocess
            pr32 = os.environ['ProgramFiles(x86)'] # get enviro var
            b = pr32 + '/opera/opera.exe'
            subprocess.Popen(b)
          >> b if printed is C:\Program Files (x86)/opera/opera.exe
            On 15/10/2015 at 07:28, xxxxxxxx wrote:
            As Ilya said, you should definitely do it using the subprocess module.
              On 15/10/2015 at 08:29, xxxxxxxx wrote:
              WOW this is so helpful guys , nice and thanks for sharing guys. But any tread on Reg..Key that can help? or its the same.
                On 15/10/2015 at 09:01, xxxxxxxx wrote:
                Ok, I used os.system.
                Shall test it with the examples given.
                Thanks, Pim
                  On 16/10/2015 at 00:54, xxxxxxxx wrote:
                  On the Mac I get an error OSError: [Errno 2] No such file or directory.
                  It complains about .../python.2.6/subprocess.py" line 1126 in_execute _child.
                  I did not yet tested it on a pc.
                  On the Mac I am using R16.047.
                  -Pim
                    -Pim
                    hi
                    I test at windows os, example for opera(web browser, if installed).
                    I have question, have you rules what enviro to use? i mean this:
                    import os, platform, sys
                    if platform.system().lower().startswith('win') : # winos
                      pass
                    elif platform.system().lower().startswith('dar') : # macos
                      pass
                    under pass - your functions with vars
                      On 16/10/2015 at 01:45, xxxxxxxx wrote:
                      Yes, I use
                      if c4d.GeGetCurrentOS() == c4d.GE_WIN:
                        windows ...
                        mac ...
                        On 16/10/2015 at 01:59, xxxxxxxx wrote:
                        argh, sorry, i'm with code from my studying of scons(exescons)
                        can post what targets of mac os you want, maybe mac users will help you
                          On 16/10/2015 at 02:09, xxxxxxxx wrote:
                          This is the command I want to give on the Mac:
                          /Applications/cloud_ui/ccl --help
                          I tested subprocess.Popen on the pc and it works ok.
                          Just like os.system.
                          What is the difference between os.system and subprocess.Popen?
                          -Pim
                            On 16/10/2015 at 02:15, xxxxxxxx wrote:
                            mmm, you need also shell commands or args for app
                            take look - https://docs.python.org/2/library/subprocess.html#popen-constructor
                              On 16/10/2015 at 07:00, xxxxxxxx wrote:
                              Any input on my subprocess.Popen issue?
                              On a pc, I got the same error message.
                                On 16/10/2015 at 08:03, xxxxxxxx wrote:
                                I got it now working.
                                Here an example on the pc, generating a tasklist and checking if a process is running.
                                    ps= subprocess.Popen(r'tasklist.exe', shell=True, stdout=subprocess.PIPE)
                                    output = ps.stdout.read()
                                    ps.stdout.close()
                                    ps.wait()
                                    if ("cloud_ui" in output) :
                                        print "found"
                                        print "not found"
