    h2 set path/environment variables
    17 Posts 0 Posters 2.2k Views
      On 15/10/2015 at 01:35, xxxxxxxx wrote:
      Yes, and putting everything between quotes solved the issue.
      So instead of cd c:\program files
      cd "c:\program files"
      Thanks, pim
        On 15/10/2015 at 07:22, xxxxxxxx wrote:
        strange
        i made test with such code all is ok
        import os, sys, subprocess
          pr32 = os.environ['ProgramFiles(x86)'] # get enviro var
          b = pr32 + '/opera/opera.exe'
          subprocess.Popen(b)
        >> b if printed is C:\Program Files (x86)/opera/opera.exe
          On 15/10/2015 at 07:28, xxxxxxxx wrote:
          As Ilya said, you should definitely do it using the subprocess module.
            On 15/10/2015 at 08:29, xxxxxxxx wrote:
            WOW this is so helpful guys , nice and thanks for sharing guys. But any tread on Reg..Key that can help? or its the same.
              On 15/10/2015 at 09:01, xxxxxxxx wrote:
              Ok, I used os.system.
              Shall test it with the examples given.
              Thanks, Pim
                On 16/10/2015 at 00:54, xxxxxxxx wrote:
                On the Mac I get an error OSError: [Errno 2] No such file or directory.
                It complains about .../python.2.6/subprocess.py" line 1126 in_execute _child.
                I did not yet tested it on a pc.
                On the Mac I am using R16.047.
                -Pim
                  -Pim
                  hi
                  I test at windows os, example for opera(web browser, if installed).
                  I have question, have you rules what enviro to use? i mean this:
                  import os, platform, sys
                  if platform.system().lower().startswith('win') : # winos
                    pass
                  elif platform.system().lower().startswith('dar') : # macos
                    pass
                  under pass - your functions with vars
                    On 16/10/2015 at 01:45, xxxxxxxx wrote:
                    Yes, I use
                    if c4d.GeGetCurrentOS() == c4d.GE_WIN:
                      windows ...
                      mac ...
                      On 16/10/2015 at 01:59, xxxxxxxx wrote:
                      argh, sorry, i'm with code from my studying of scons(exescons)
                      can post what targets of mac os you want, maybe mac users will help you
                        On 16/10/2015 at 02:09, xxxxxxxx wrote:
                        This is the command I want to give on the Mac:
                        /Applications/cloud_ui/ccl --help
                        I tested subprocess.Popen on the pc and it works ok.
                        Just like os.system.
                        What is the difference between os.system and subprocess.Popen?
                        -Pim
                          On 16/10/2015 at 02:15, xxxxxxxx wrote:
                          mmm, you need also shell commands or args for app
                          take look - https://docs.python.org/2/library/subprocess.html#popen-constructor
                            On 16/10/2015 at 07:00, xxxxxxxx wrote:
                            Any input on my subprocess.Popen issue?
                            On a pc, I got the same error message.
                              On 16/10/2015 at 08:03, xxxxxxxx wrote:
                              I got it now working.
                              Here an example on the pc, generating a tasklist and checking if a process is running.
                                  ps= subprocess.Popen(r'tasklist.exe', shell=True, stdout=subprocess.PIPE)
                                  output = ps.stdout.read()
                                  ps.stdout.close()
                                  ps.wait()
                                  if ("cloud_ui" in output) :
                                      print "found"
                                      print "not found"
