    Connect 2 output ports of xpresso [CLOSED]
    19 Posts 0 Posters 2.4k Views
      On 04/07/2015 at 10:45, xxxxxxxx wrote:
      Again me
      Sample code, execute at any c4d object, problem that ports do not connect (24 pos./line) :
        global vecoutp
        obj = doc.GetActiveObject()
        tag = doc.GetActiveTag()
        if not tag:
            tag = c4d.BaseTag(c4d.Texpresso)
            obj.InsertTag(tag)
        nm = tag.GetNodeMaster()
        xg = nm.GetRoot()
        print "pass 1"
        for i in xrange(xg.GetOutPortCount()) :
            port = xg.GetOutPort(i)
            print port, port.GetName(xg), port.GetMainID()
        bbox = nm.CreateNode(nm.GetRoot(),c4d.ID_OPERATOR_BOX,None, 0, 0)
        nm.InsertFirst(xg, bbox)
        if not xg.GetOutPort(0) :
            vecoutp = xg.AddPort(c4d.GV_PORT_OUTPUT, 536870935)
        c = vecoutp.Connect(bbox.GetOutPort(0)) # <<<<< not connect
        print vecoutp, vecoutp.GetName(xg), vecoutp.GetMainID()
        print bbox.GetOutPort(0), bbox.GetOutPort(0).GetName(bbox), bbox.GetOutPort(0).GetMainID()
        print c
        print "pass 2"
        xg.Redraw()
        nm.Message(c4d.MSG_UPDATE)
        On 05/07/2015 at 23:31, xxxxxxxx wrote:
        Has python for c4d such limit now? Or possible to do another way?!
          On 06/07/2015 at 05:09, xxxxxxxx wrote:
          Nodes are laying in same nodemaster
          GvPort.Connect`( _port_ )
           **Note Remember, the nodes of the ports have to be in the same` GvNodeMaster`, otherwise the connection fails.**
          Also i trying to make clone of tag/Nodemaster and do versa - fails
            On 06/07/2015 at 07:20, xxxxxxxx wrote:
            Hi Ilya,
            I'm afraid, this currently a limitation in Python. As you need to connect two out-ports inside the Xgroup, this does currently not work (same for the input side as well).
            I'm currently checking with development, if there are workarounds.
              On 06/07/2015 at 07:29, xxxxxxxx wrote:
              Hello Andreas
              Thank you! I will wait.
              I also will test such code with c++ port. Maybe need to port code to CAPI if will be success
                On 06/07/2015 at 11:26, xxxxxxxx wrote:
                I test this CAPI snippet(write and execute at Remo c4d++ platform)
                There is interesting, it marks ports(arrows) but not show connections
                  BaseDocument *doc = GetActiveDocument();
                  BaseObject *obj = (BaseObject * ) doc->GetActiveObject();
                  if(!obj) return FALSE;
                  XPressoTag *xTag = (XPressoTag* )obj->GetTag(Texpresso, 0);
                  if(!xTag) return FALSE;
                  GvNodeMaster *nm = xTag->GetNodeMaster();
                  GvNode *n1 = nm->GetRoot();
                  GvPort *p1 = n1->AddPort(GV_PORT_OUTPUT, 536870935, GV_PORT_FLAG_IS_VISIBLE, TRUE);
                  GvNode *n2 = nm->CreateNode(nm->GetRoot(), ID_OPERATOR_BOX, NULL, 0, 0);
                  GvPort *p2 = n2->GetOutPort(0);
                      if (p1 && p2)
                      GvNode *n1u = NULL;
                      GvNode *n2u = NULL;
                      GvPort *p1u = NULL;
                      GvPort *p2u = NULL;
                      if (nm->IsConnectionValid(n1, p1, n2, p2, n1u, p1u, n2u, p2u))
                        n2->AddConnection(n1, p1, n2, p2);
                  nm->Message(MSG_UPDATE);
                  EventAdd();
                http://oi61.tinypic.com/xmvhbk.jpg
                  On 07/07/2015 at 02:03, xxxxxxxx wrote:
                  Ok, found one method, i will make connected samples and store at HD or c4d content.
                    On 08/07/2015 at 01:01, xxxxxxxx wrote:
                    Hi
                    A few things are not as expected, so i remove flag solved at topic.
                    Andreas, any info about to break limit?
                      On 08/07/2015 at 01:34, xxxxxxxx wrote:
                      Hi Ilya,
                      actually I didn't mark this thread as solved, as I had no answer from the devs. Today it was acknowledged as a limitation. It is currently not possible to connect an output of a node to an output of the parent Xgroup in Python (same for input nodes). Unfortunately there seems to be no workaround. Sorry.
                      Regarding your C++ code and the missing connection. I think, you need to call AddConnection() for the other node involved. See this thread.
                        On 08/07/2015 at 02:01, xxxxxxxx wrote:
                        Hi Ilya,
                        I add tag to name of topic, thinking it was resolved.
                        I don't understand one thing in py-sdk, why need such checking - GvNode.IsGroupNode
                        About c++ snippet, i tried different ways and same result.
                        Also if it will be (x)group why need this https://developers.maxon.net/docs/Cinema4DCPPSDK/html/group___g_v___g_r_o_u_p.html
                          On 08/07/2015 at 13:05, xxxxxxxx wrote:
                          Andreas, you are right!!!
                          I did it by c++, i don't know what was wrong. After restarting of machine - it worked! (caches or anything else prevent it)
                          i change
                          to
                          n1->AddConnection(n1, p1, n2, p2);
                          i move to c++(maybe S.Rath will bring light to py-code). Solved. Thank you
                            On 09/07/2015 at 05:17, xxxxxxxx wrote:
                            Hi Ilya,
                            glad it worked in C++.
                            The developer feedback I talked about yesterday came from S. Rath. I'm afraid you will have to wait for a fix in C4D for this to work in Python.
                              On 09/07/2015 at 05:35, xxxxxxxx wrote:
                              Thanks a'lot.
                              R17? or will be sp4 for r16?
                              Anyway, please, close topic. I will port stuff to c++
                                On 28/07/2015 at 07:25, xxxxxxxx wrote:
                                Sorry that remind
                                Have you fixed this issue in 16.051 patch?
                                upd.
                                🤢 seems not
                                it cover several mysterious issue of nvdia 😠
                                  On 28/07/2015 at 07:48, xxxxxxxx wrote:
                                  Hi Ilya,
                                  you seem to have found out yourself. I would have left a note here, if the SP fixed this bug. Internally this bug has been addressed, but it was to late to get into the 16.051 update.
                                    On 28/07/2015 at 07:58, xxxxxxxx wrote:
                                    Anyway thanks.
                                    I see that developers back to work from vacation* 😉. If we got fix.
                                    * - You or someone from team pointed at this fact
                                      On 03/11/2015 at 07:48, xxxxxxxx wrote:
                                      This problem should be fixed in R17.
                                        Hello
                                        I forgot about this - i'm checking out of it > that's great - it works! Thanks a'lot 👏👍
                                        (please, do not brake it)😉
