    Messages between objects [SOLVED]
    24 Posts 0 Posters 14.9k Views
      On 10/04/2015 at 00:34, xxxxxxxx wrote:
      Hi Yannick,
      I guess I was overhasty stating that your code is the solution.
      If you change an attribute of a primitiv in the link field it again wont work.
      Also if you grab the handels and scale the primitiv, the generator won´t reflect this.
      What else could be wrong?
      Sorry to bother you again.
      Best wishes
      Martin
        Are you checking the dirty on the linked primitive object and not on its cache?
          On 10/04/2015 at 01:04, xxxxxxxx wrote:
          Hi Yannick,
          this is driving me nuts, even if I differentiate the dirtytest within the GetGeom function and pass the value.
          I´m always one step behind the update.
          If you e.g. change a parameter of the primitiv numerically and press enter, nothing happens.
          Thanks in advance for your patience!
          Martin
          from c4d import utils, gui
          global dirtyCount
          dirtyCount = 0
          def GetLink(op) :
            udOK = False
            for udID, udBC in op.GetUserDataContainer() :
                if udID[1].id==1 and udID[1].dtype==c4d.DTYPE_BASELISTLINK:
                    udOK = True
                    break
            if not udOK:
                dialog = gui.MessageDialog("No appropriate UserData available! \n"
                                           "Please insert a linkfield \n"
                                           "and activate the generator again.",c4d.GEMB_OK)
                op[c4d.ID_BASEOBJECT_GENERATOR_FLAG] = False
                return None
            link = op[c4d.ID_USERDATA,1]
            if not link:return None
            if link.GetClassification()!=c4d.Obase:
                dialog = gui.MessageDialog("Please insert a valid object in the user data link!",c4d.GEMB_OK)
                return None
            return link
          def GetGeom(op) :
            geom = op
            dirty = op.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
            if not op.IsInstanceOf(c4d.Opolygon) :
                geom = op.GetCache()
            deform = geom.GetDeformCache()
            if deform:
                dirty = deform.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
                geom = deform
            return geom,dirty
            global dirtyCount
            if op[c4d.OPYTHON_OPTIMIZE] == True:
                dialog=gui.MessageDialog("Please uncheck Optimize Cache! \n"
                return c4d.BaseObject(c4d.Onull)
            link = GetLink(op)
            if not link: return c4d.BaseObject(c4d.Onull)
            geom,dirty = GetGeom(link)
            #custom dirty test with linked object
            #dirty = link.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
            if dirty != dirtyCount:
                dirtyCount = dirty
                op.SetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
            if not op.IsDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX) : return op.GetCache()
            #parent virtual object
            null = c4d.BaseObject(c4d.Onull)
            child = geom.GetClone()
            child.InsertUnder(null)
            return null
            On 10/04/2015 at 01:14, xxxxxxxx wrote:
            an additional note.
            This behaviour is again hierarchy dependend.
            If the primitiv is above the generator in the hierarchy everything works fine.
            If the primitiv is below it won´t
              On 10/04/2015 at 02:57, xxxxxxxx wrote:
              It works fine for me with polygon objects, primitives, deformers etc.
              2 notes on GetGeom() :
              op.GetDirty() is called twice in the case of a primitive.
              It would be better to add the dirty count from op.GetDirty() and deform.GetDirty().
              def GetGeom(op) :
                geom = op
                    ~~dirty = op.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)~~
                  if deform:
                      dirty = **dirty +** deform.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
                      geom = deform
                  return geom,dirty
                On 10/04/2015 at 04:13, xxxxxxxx wrote:
                Hi Yannick,
                thanks for the next optimization hint!
                But still, the problem with the primitiv exists.
                I decided to make a small video and an example file to show you what I was talking about.
                I´ll send you a PM.
                Thanks for your staying power!
                Best wishes
                Martin
                  On 10/04/2015 at 06:51, xxxxxxxx wrote:
                  Hi Martin,
                  Thanks for the example scene and video. I've been able to see the issue and reproduce it.
                  It's strange this only happens when editing the primitive attribute by hand and pressing enter.
                  I think the problem is with GetCache() in GetGeom(). The cache of the linked primitive object hasn't been updated yet when retrieving it.
                  The only way to obtain the updated polygonal representation of a primitive object is to call the current state to object command. This command rebuild the cache for the passed object if needed, and then clone the polygonal cache object for you.
                    On 10/04/2015 at 08:05, xxxxxxxx wrote:
                    Hi Yannick,
                    testing further I figured out that this not an update problem.
                    It´s a problem with what we a getting back from the generators link field.
                    Getting the cache with link.GetCache() from a parametric object within a linkfield
                    produces a polygon object within a python tag and a null object with every face as a child inside a generator object.
                    That seems like a buggy behaviour to me.
                    Could you please give it a try and confirm or counter my assumption?
                    Best wishes
                    Martin
                      I can't reproduce this strange behavior.
                      Have you tried the current state to object modelling command solution I explained in my previous post? It seems to work fine in all situations.
                      Also, please start a new topic if you have different questions than the initial one. This make it easier to follow the topic and search the forum.
                        On 10/04/2015 at 13:44, xxxxxxxx wrote:
                        The strange behaviour was gone after I started a new Cinema 4d session and built up a new scene.
                        Maybe a corruption in between development...
                        Yannick, I tried your current state to object suggestion, but then I won´t get a valid deform cache from the object nor the deformed polygon object.
                        With [c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE] set to False I should get a deformed object from current state to object.
                        Could you please post your solution?
                        I´m a little lost at the moment...
                        This thread is really not solved for me , sorry
                        Best wishes
                        Martin
                          On 13/04/2015 at 09:09, xxxxxxxx wrote:
                          Now it is solved,
                          the polygonal representation from the parametric object should be taken from current state to object.
                          (like Yannick suggested)
                          but the dirty state needs to be read from the cache.
                          Yannick, thanks!
                          Could you please explain why the cache hasn´t been updated ?
                          Best wishes
                          Martin
                          global dirtyCount
                          dirtyCount = 0
                          def GetLink(op) :
                            udOK = False
                                    udOK = True
                                    break
                            if not udOK:
                                return None
                                return None
                            return link
                          def GetGeom(op) :
                            geom = op
                                settings = c4d.BaseContainer()
                                settings[c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE] = False
                                settings[c4d.MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION] = True
                                settings[c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE] = False
                                polylist = utils.SendModelingCommand(command= c4d.MCOMMAND_CURRENTSTATETOOBJECT, list= [op.GetClone()], mode =c4d.MODELINGCOMMANDMODE_ALL, bc = settings,  doc= doc)
                                if not polylist : return None
                                geom = polylist[0]
                                if op.GetCache().GetDeformCache() :
                                    deform = op.GetCache().GetDeformCache()
                                    dirty = dirty + deform.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
                                    print dirty, "parametric deform"
                            if op.GetDeformCache() :
                                print dirty,"polygonal deform "
                                geom = deform
                            return geom,dirty
                            global dirtyCount
                            link = GetLink(op)
                            if not geom: return c4d.BaseObject(c4d.Onull)
                                dirtyCount = dirty
                            return null
                            On 13/04/2015 at 09:32, xxxxxxxx wrote:
                            The initial question for this topic has been solved: messaging between the generator and its linked object, more precisely getting the dirty state from the linked object (the original title of the topic isn't event not meaningful).
                            Please create a new thread for new questions.
                              On 13/04/2015 at 09:54, xxxxxxxx wrote:
                              Feel free to rename this thread to suit the topic, Yannick, no problem.
                              That´s all not that meaningful...enjoy your finishing time
                              martin
                                On 14/04/2015 at 06:19, xxxxxxxx wrote:
                                Hi Martin,
                                I'd really like to help you but we need to have an organized forum.
                                You can create a new topic with the current script for the Python generator, the issues with it and I'll be happy to help you 🙂.
