    questions about GetDDescription [SOLVED]
    19 Posts 0 Posters 1.8k Views
      On 04/11/2014 at 11:38, xxxxxxxx wrote:
      Hi Andreas,
      I think with your reply I'm getting closer to what I need !Smile[URL-REMOVED]
      I'm creating a node based material system for my render engine, this material system will have also a tree view representation, this tree view should be able to do "right click" , then add nodes depending on the right click menu
      I think you got now an idea about what I'm after, any simple example of GeUserArea and CustomGUI would be appreciated, plus your guidelines 😉
        On 04/11/2014 at 13:37, xxxxxxxx wrote:
        I'll extend the asynctest SDK example tomorrow morning to have a small popup menu.
          On 04/11/2014 at 23:00, xxxxxxxx wrote:
          Mohamed,
          in SDK examples AsyncTest.cpp add the following enumeration for some menu IDs (code for R15+) :
          enum
            MY_POPUP_ID_FIRST = FIRST_POPUP_ID,
            MY_POPUP_ID_SUBMENU,
            MY_POPUP_ID_SUBMENU_FIRST,
          Then in Bool SDKGradientArea::InputEvent(const BaseContainer& msg) add the following as last else if:
              else if (chn == BFM_INPUT_MOUSERIGHT)
                BaseContainer bcPopupMenu;
                BaseContainer bcSubmenu;
                Int32 mx = msg.GetInt32(BFM_INPUT_X); // of course you can use mouse position to have popup menu be position sensitive
                Int32 my = msg.GetInt32(BFM_INPUT_Y);
                Global2Local(&mx, &my);
                Local2Screen(&mx, &my);
                // instead of building the menu everytime, you may better have a prepared container ready
                bcPopupMenu.SetString(MY_POPUP_ID_FIRST, "First menu entry");
                bcSubmenu.SetString(1, "A submenu");
                bcSubmenu.SetString(MY_POPUP_ID_SUBMENU_FIRST, "Submenu entry");
                bcPopupMenu.SetContainer(MY_POPUP_ID_SUBMENU, bcSubmenu);
                const Int32 menuId = ShowPopupMenu(nullptr, mx, my, bcPopupMenu);
                switch (menuId)
                case MY_POPUP_ID_FIRST:
                  GePrint("Execute first popupmenu entry");
                  break;
                case MY_POPUP_ID_SUBMENU_FIRST:
                  GePrint("Execute first submenu entry");
                  break;
                case 0:
                  GePrint("Menu got canceled");
                  break;
                default:
                  DebugStop("Popup Menu: Forgot a new enum value?");
                // maybe use SendParentMessage() if need be
          The docs on this topic aren't that bad either: R16 SDK Docs: c4d_gui.h
            On 05/11/2014 at 02:54, xxxxxxxx wrote:
            thanks a lot Tongue , will test tonight and come back to you
              On 05/11/2014 at 14:25, xxxxxxxx wrote:
              Hi Andreas,
              I have checked it!! , it is a very interesting example 👏 , this is really very helpful, thanks again for your support, keep the good work up
                On 06/11/2014 at 02:13, xxxxxxxx wrote:
                just need to confirm about question ( 1-a , 1-b ) , I use this if statement in all created description, or no need at all? need some discussion about what happens here
                  On 06/11/2014 at 02:17, xxxxxxxx wrote:
                  Can you show me a piece of your code? Will make discussion easier.
                    On 06/11/2014 at 03:00, xxxxxxxx wrote:
                    it is the example LookAtCamera ,  LookAtCamera::GetDDescription(), all of the written description are created the same way with a check for performance, need to understand how this works, if there is no specific explanation , is it safe to do the same with all created description? (so I just write them the same way and forget about them) , or this is written in specific situations
                      On 06/11/2014 at 03:43, xxxxxxxx wrote:
                      You mean the
                      if (!singleid ||...
                      part?
                      Yes, you should do it exactly like it is done in the lookatcamera example. As Niklas said, it's a performance optimization, in case C4D is asking for a single description only.
                        On 06/11/2014 at 04:13, xxxxxxxx wrote:
                        yes
                        ok thanks 🙂
                          On 17/11/2014 at 10:01, xxxxxxxx wrote:
                          sorry for asking again, but I found that I didn't know yet how to adjust the format of data "question (2)" , the above link that I posted was for Dialogs, didn't notice this, so hope you may reply with a simple example to question (2)
                          edit:I find that DESC_COLUMNS is doing the job, but what about putting stuff in an irregular way, like:
                          button1    button2    button3
                          button4
                          button5    button6
                          button7
                          edit2: I would love to know how to create something similar to this Dialog http://www.andrewnoske.com/wiki/Cinema_4D\_-\_my_C%2B%2B_plugins\_-\_add_text
                          in GetDDescription() , the combo box, the radio group, etc..
                            On 17/11/2014 at 12:10, xxxxxxxx wrote:
                            nvm, I find the solution here:
                            https://developers.maxon.net/forum/topic/7380/8990_getting-dynamically-added-long-cycle-string-value&KW=GetDDescription
                              On 17/11/2014 at 14:05, xxxxxxxx wrote:
                              Ah, you were too quick. I was just compiling an example for you...
                              Nevertheless glad you found your solution.
                                On 11/01/2016 at 05:14, xxxxxxxx wrote:
                                Hi Andreas,
                                as this is related to  ShowPopupMenu()
                                how to put icons in the menu?
