    questions about GetDDescription [SOLVED]
    19 Posts 0 Posters 1.8k Views
      On 05/11/2014 at 14:25, xxxxxxxx wrote:
      Hi Andreas,
      I have checked it!! , it is a very interesting example 👏 , this is really very helpful, thanks again for your support, keep the good work up
        On 06/11/2014 at 02:13, xxxxxxxx wrote:
        just need to confirm about question ( 1-a , 1-b ) , I use this if statement in all created description, or no need at all? need some discussion about what happens here
          On 06/11/2014 at 02:17, xxxxxxxx wrote:
          Can you show me a piece of your code? Will make discussion easier.
            On 06/11/2014 at 03:00, xxxxxxxx wrote:
            it is the example LookAtCamera ,  LookAtCamera::GetDDescription(), all of the written description are created the same way with a check for performance, need to understand how this works, if there is no specific explanation , is it safe to do the same with all created description? (so I just write them the same way and forget about them) , or this is written in specific situations
              On 06/11/2014 at 03:43, xxxxxxxx wrote:
              You mean the
              if (!singleid ||...
              part?
              Yes, you should do it exactly like it is done in the lookatcamera example. As Niklas said, it's a performance optimization, in case C4D is asking for a single description only.
                On 06/11/2014 at 04:13, xxxxxxxx wrote:
                yes
                ok thanks 🙂
                  On 17/11/2014 at 10:01, xxxxxxxx wrote:
                  sorry for asking again, but I found that I didn't know yet how to adjust the format of data "question (2)" , the above link that I posted was for Dialogs, didn't notice this, so hope you may reply with a simple example to question (2)
                  edit:I find that DESC_COLUMNS is doing the job, but what about putting stuff in an irregular way, like:
                  button1    button2    button3
                  button4
                  button5    button6
                  button7
                  edit2: I would love to know how to create something similar to this Dialog http://www.andrewnoske.com/wiki/Cinema_4D\_-\_my_C%2B%2B_plugins\_-\_add_text
                  in GetDDescription() , the combo box, the radio group, etc..
                    On 17/11/2014 at 12:10, xxxxxxxx wrote:
                    nvm, I find the solution here:
                    https://developers.maxon.net/forum/topic/7380/8990_getting-dynamically-added-long-cycle-string-value&KW=GetDDescription
                      On 17/11/2014 at 14:05, xxxxxxxx wrote:
                      Ah, you were too quick. I was just compiling an example for you...
                      Nevertheless glad you found your solution.
                        On 11/01/2016 at 05:14, xxxxxxxx wrote:
                        Hi Andreas,
                        as this is related to  ShowPopupMenu()
                        how to put icons in the menu?
