    Bitmap in UserArea
    22 Posts 0 Posters 39.1k Views
      On 12/05/2013 at 02:00, xxxxxxxx wrote:
      I dot that in a InitValues event inside a class but not see it in the plugin.
        On 12/05/2013 at 02:21, xxxxxxxx wrote:
        Override the DrawMsg() method inside the GeUserArea. Do it there.
        Best,
        -Niklas
          On 12/05/2013 at 03:10, xxxxxxxx wrote:
          I use this option yesterday without any results. I think that not load this class in the plugin code.
          This is the code of my class:
          class Area(c4d.gui.GeUserArea) :
              def DrawMsg(self, x1, y1, x2, y2, msg) :
                  path=c4d.storage.GeGetC4DPath(c4d.C4D_PATH_LIBRARY)
                  archi= path + "\Joyeria\100.png"
                  bmp=c4d.bitmaps.BaseBitmap()
                  bmp.InitWith(path)
                  self.DrawBitmap(bmp,0,0,300,160,0,0,50,24,c4d.BMP_NORMAL)
                  self.Redraw()
          In the dialog class:
           def __init__(self, area) :
                  self.area = area
          In the CreateLayout, use AddUserArea y AttachUserArea for create the fields.
          In the CommadData class:
          class MyMenuPlugin(c4d.plugins.CommandData) :
              area = Area()
              dialog = None
              def Execute(self, doc) :
              # create the dialog
                 if self.dialog is None:
                    self.dialog = MiDialogo(self.area)
                 return self.dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID,defaultw=200, defaulth=150, xpos=-1, ypos=-1)
          def RestoreLayout(self, sec_ref) :
              # manage the dialog
                  return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
          Only show this parts of the entire code becuase it have more than 300 lines.
          Thanks.
            On 12/05/2013 at 03:13, xxxxxxxx wrote:
            Why do you call Redraw() in DrawMsg()? This will call DrawMsg() again. Also, load the bitmap once and
            draw it in DrawMsg(). The way you're doing it looks fine, try again with these changes.
            Best,
            -Niklas
              On 12/05/2013 at 03:21, xxxxxxxx wrote:
              Maybe not load the bitmap becuse the coords of the UserArea and the DrawBitmap not the same?
                On 12/05/2013 at 03:30, xxxxxxxx wrote:
                I resolve the problem. The AttachUserArea don´t have the AddUserArea ID.
                Now i have to scale the bitmap in the UserArea.
                Thanks for all.
                  On 12/05/2013 at 03:38, xxxxxxxx wrote:
                  .. and hopefully load the bitmap once only instead of everytime it needs to be drawn! 🙂
                  You're welcome.
                  Best,
                  -Niklas
                    On 12/05/2013 at 04:37, xxxxxxxx wrote:
                    With this code:
                         bmp.InitWith(archi)
                    The result path is: C:\PROGRAM FILES\MAXON\CINEMA 4D R14\library\Joyeria.bmp
                    Why?
                      On 12/05/2013 at 05:29, xxxxxxxx wrote:
                      You can't just use backslashes, since those are specific to the Windows OS. Try it like this:
                      archi = path + "Joyeria" + "100.png"
                      That may seem strange at first glance, but since every separate string is auto-cast to Filename, it does make sense.
                        as he is under windows he can, but there is the danger to trigger a control character if he uses
                        the strings the way he does. the way jack posted should not work imho.
                        archi= path + "\Joyeria\100.png" should be written in python as:
                        archi= path + r"\Joyeria\100.png" or
                        archi= path + "\\Joyeria\\100.png" or the best way
                        archi= os.path.join(path,"\Joyeria\100.png")
                        result = 'SomePath' + '\100' would become 'SomePath@' as \100 is the @ character.
                          On 12/05/2013 at 07:33, xxxxxxxx wrote:
                          Thanks littledevil, problem solved. Thumbs Up
                            We're in Python here, there's no Filename class like in C++. 🙂
                            archi = os.path.join(path, 'Joyeria', '100png')
                            Best,
                            -Niklas
                              On 12/05/2013 at 11:13, xxxxxxxx wrote:
                              I'm having an issue related to using images in the UA.
                              Rather than post a brand new thread. I think it would fit in here.
                              I can load an image file into my UA just fine.
                              But when I try to move the image when I press a button in the GeDialog class. The UA doesn't update properly.
                              The image does move. But it also leaves behind a ghost of where it was originally. And also one of the GeDialog buttons also pops up in the corner of the UA!!???
                              In other words. The UA freaks out. 😂
                              How do we make the UA update properly if we move the image?
                              Here is the entire plugin code:
                              import  c4d,os
                              from c4d import gui, plugins
                              class MyUA(c4d.gui.GeUserArea) :
                                bmp = None
                                xValue = 0               #Where to position the image in the UA
                                yValue = 0
                                def __init__(self) :
                                    dir, file = os.path.split(__file__)   #Gets the plugin's directory
                                    path = os.path.join(dir, "res")       #Adds the res folder to the directory to target the res folder
                                    image = path + "\myimage.png"         #Adds the image to the path
                                    self.bmp = c4d.bitmaps.BaseBitmap()   #Create an instance of the BaseBitmap class
                                    self.bmp.InitWith(image)              #Initialize it with the image
                                    self.OffScreenOn()                    #Helps to stabilize the bitmap drawing in the UA
                                    w = self.bmp.GetBw()
                                    h = self.bmp.GetBh()
                                    self.DrawBitmap(self.bmp, self.xValue, self.yValue, w, h, 0, 0, w, h, c4d.BMP_ALLOWALPHA)
                                    self.DrawBorder(c4d.BORDER_OUT, x1, y1, x2, y2)
                                def InputEvent(self, msg) :
                              class MyDialog(c4d.gui.GeDialog) :
                                ua = MyUA()                #Create a local class instance of the UserArea
                                def CreateLayout(self) :
                                    self.AddUserArea(2000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
                                    self.AttachUserArea(self.ua, 2000)
                                    self.AddButton(1000, c4d.BFH_CENTER, 80, 15, "Click Me")
                                    self.AddButton(1001, c4d.BFH_CENTER, 80, 15, "Close")
                                #This method initializes things when the plugin starts
                                def InitValues(self) :
                                def Command(self, id, msg) :
                                    if id==1000:
                                        self.ua.xValue = 100       #Moves the Bitmap image to another location
                                        self.ua.yValue = 100
                                        self.ua.LayoutChanged()    #<---Trying to solve UA image display problems...Not Working!!
                                        self.ua.Redraw()
                                    elif id==1001:
                                        self.Close()
                              ###### This class is only used to register the plugin...Don't change!!!#######
                              class BitmapUaExample(c4d.plugins.CommandData) :
                                dlg = None
                                ua = None
                                PLUGIN_ID   = 10000090 # TESTING ID ONLY!!!
                                ICON = None
                                    if not self.dlg: self.dlg = MyDialog()
                                    self.dlg.Open(c4d.DLG_TYPE_ASYNC, self.PLUGIN_ID)
                                def RestoreLayout(self, subid) :
                                    if not self.dlg:
                                    return self.dlg.Restore(self.PLUGIN_ID, subid)
                                @classmethod
                                def Register(myPlugin) :
                                    data = {
                                        "id":     myPlugin.PLUGIN_ID,
                                        "icon":   myPlugin.ICON,
                                        "str":    "Bitmap UA Example",
                                        "help":   "Some text that shows up at the bottom of the C4D UI",
                                        "info":   c4d.PLUGINFLAG_COMMAND_HOTKEY,
                                        "dat":    myPlugin(),
                                    c4d.plugins.RegisterCommandPlugin(**data)
                                BitmapUaExample.Register()
                                On 12/05/2013 at 11:38, xxxxxxxx wrote:
                                Hi Scott,
                                just draw the background color onto the rectangle. 😉
                                * before drawing the bitmap of course
                                self.DrawSetPen(c4d.COLOR_BG)
                                self.DrawRectangle(x1, y1, x2, y1)
                                Best,
                                Niklas
                                  On 12/05/2013 at 12:00, xxxxxxxx wrote:
                                  Still freaking out on me.
                                        self.DrawSetPen(c4d.COLOR_BG)        #Doesn't do anything :-(
                                    On 12/05/2013 at 12:49, xxxxxxxx wrote:
                                    Works fine here. Resize the dialog and the x position of the image will change.
                                    from c4d.gui import *
                                    from c4d.bitmaps import *
                                    class Area(GeUserArea) :
                                            super(Area, self).__init__()
                                            self.bmp = BaseBitmap()
                                            self.bmp.InitWith('C:/Users/niklas/Desktop/01.jpg')
                                            self.x = 0
                                            self.y = 0
                                            self.d = 1
                                            if self.x > 100:
                                                self.d = -1
                                            elif self.x <= 0:
                                                self.d = 1
                                            self.x += self.d
                                            w, h = self.bmp.GetSize()
                                            self.DrawBitmap(self.bmp, x1 + self.x, y1 + self.y,
                                    class Dlg(GeDialog) :
                                            self.ua = Area()
                                            self.AddUserArea(1000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
                                            self.AttachUserArea(self.ua, 1000)
                                    dlg = Dlg()
                                    dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE)
                                    remark: relatively dirty code, please don't use as reference for coding style.
                                    Best,
                                    -Niklas
                                      On 12/05/2013 at 13:23, xxxxxxxx wrote:
                                      Thanks Nik,
                                      Apparently. The UA doesn't work well with class member variables. Or at least not the way I'm using them.
                                      When I use a class member variable as the target variable for the DrawBitmap() method. The UA freaks out.
                                      Not sure why this happens. But there's probably a good reason for it.
                                        On 12/05/2013 at 13:26, xxxxxxxx wrote:
                                        Edit: Wait a sec, checking out the code you have posted. It freaks around here as well.
                                          On 12/05/2013 at 13:34, xxxxxxxx wrote:
                                          Ok so first of all: You should always draw a background color if what you can not assume what
                                          you are drawing fills the complete rectangle. The buffer is not simply all set to zero (black) but
                                          is left the way it is. You must fill it with the desired background color yourself.
                                          Second is: You can actually draw outside of the area because the dialog itself is drawn on the same
                                          buffer. You can clip the drawing by using SetClippingRegion(x1, y1, x2, y2)
                                                  self.SetClippingRegion(x1, y1, x2, y2)
                                          -Niklas
                                            On 12/05/2013 at 14:24, xxxxxxxx wrote:
                                            No worries. I've got it all worked out now.
                                            It just didn't like the way I was using the class member variables.
                                            Here's the working version. Just in case anyone needs it. Or is curious about it.
                                            When the GeDialog button is clicked. The image moves to a new position properly now.
                                            I also threw in some mouse position checking code.
                                            import  c4d,os
                                              xValue = 0           #These variables will set the position of the image
                                              yValue = 0
                                                  self.xValue = 5
                                                  self.yValue = 5
                                                  self.DrawSetPen(c4d.COLOR_BG)         #COLOR_BG is the image we load with DrawBitmap
                                                  self.DrawRectangle(x1, y1, x2, y2)    #Draws a rectangle and fills it with the image bitmap
                                                  w, h = self.bmp.GetSize()             #Gets the size values of the image
                                                  self.DrawBitmap(self.bmp, x1 + self.xValue, y1 + self.yValue, w, h, 0, 0, w, h, c4d.BMP_NORMAL | c4d.BMP_ALLOWALPHA)
                                                  self.DrawBorder(c4d.BORDER_ROUND, x1+5, y1+5, x2-5, y2-5)  #Draws a border around the UserArea
                                                  action = c4d.BaseContainer(c4d.BFM_ACTION)
                                                  action.SetLong(c4d.BFM_ACTION_ID, self.GetId())
                                                  while self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, msg) :    #While the left mouse button is held down
                                                      if msg.GetLong(c4d.BFM_INPUT_VALUE)==0: break
                                                      if msg[c4d.BFM_INPUT_DEVICE] == c4d.BFM_INPUT_MOUSE:
                                                          x, y = msg[c4d.BFM_INPUT_X], msg[c4d.BFM_INPUT_Y]
                                                          g2l  = self.Global2Local()
                                                          x += g2l['x']
                                                          y += g2l['y']
                                                      if msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSELEFT:
                                                          print x, y  #The mouse's X & Y pos inside the user area
                                                          action.SetLong(c4d.BFM_ACTION_INDRAG, True)
                                                          self.SendParentMessage(action)                    #Sends a message to the parent dialog that the mouse is dragging in the UA
                                                          self.Redraw()                                     #Redraw while the left mouse button is held down
                                                  action.SetLong(c4d.BFM_ACTION_INDRAG, False)
                                                  self.SendParentMessage(action)                            #Sends a message to the parent dialog that the mouse has stopped dragging in the UA
                                                  if id==1000:
                                                      self.ua.Redraw()
                                                  elif id==1001:
                                                      self.Close()
                                              dlg = None
                                              ua = None
                                              ICON = None
                                                  self.dlg.Open(c4d.DLG_TYPE_ASYNC, self.PLUGIN_ID, -1, -1, 400, 300)
                                                  if not self.dlg:
                                              @classmethod
                                                  data = {
                                                      "dat":    myPlugin(),
