    How to get a variable from plugin.tag
    15 Posts 0 Posters 1.8k Views
      On 16/03/2013 at 02:09, xxxxxxxx wrote:
      Hello spedler,
      thanks for reply. I know how to get my tag in python-tag and checking if its attached and so. The example is just an example.
      If it's an array (as you showed in your code) you'll have to make it available to other objects in some way.
      But thats what I want. I do not know anything about C++, so Ive to take a look what private means and getter/setter is.
      Is C++ -> public the same as Python -> global? If so, Im still not sure how to call the list/array from python tag.
      Thanks very much
      rown
        On 16/03/2013 at 02:46, xxxxxxxx wrote:
        It doesn't work with Python unfortunately. We do not have access to the NodeData of a plugin in
        Python, or better say we can not get the NodeData from a BaseList2D object! It would be possible
        with a bit of hacking, but it's not very "beautiful".
        You could exchange information via a Python module or a c4dtools.library.Library class. I do
        not recommend the first one. An example for the c4dtools Library to be put in your Python plugin
        file:
        # Python Plugin File
        import weakref
        import c4dtools
        class PluginTag(c4d.plugins.TagData) :
            op = None
            instances = []
            def Init(self, op) :
                self.instances.append(weakref.ref(self))
                self.list_ = []
                self.op = op
            def Free(self) :
                try:
                    self.instances.remove(weakref.ref(self))
                except ValueError:
                    pass
        class MyLibrary(c4dtools.library.Library) :
            class Meta:
                # Global unique identifier!
                name = 'my-super-duper-cool-library'
            def get_plugin_tags(self) :
                return PluginTag.instances[:]
        # Python Tag (or just somewhere else than the plugin file)
        import c4dtools
        lib = c4dtools.load_library('my-super-duper-cool-library')
        for data in lib.get_plugin_tags() :
            data = data() # dereference the weakref
            if not data:
                continue
            print data.list_
        Note that this only works when you place the c4dtools module somewhere the Python Interpreter
        can always find it, and not as a local distributed dependency as described in this article.
          On 16/03/2013 at 03:15, xxxxxxxx wrote:
          Hey Niklas,
          thank you very much. I´ll try your lines.
          But one other question. Is it easier/allowed to exchange information between NodeData(plugin.tag) and BaseData(command.tag)?
            On 16/03/2013 at 03:24, xxxxxxxx wrote:
            the most common approach would be messages for such a problem. both the sending
            and the recieving class would implement a message method and therefore had to be
            derived from a c4d class which implements such a method. but i have never tried this
            from a script (python-tag).
              Hi rown,
              yes it is allowed, but limited in Python. You can easily exchange data within C++ between the
              plugin classes.
              @Ferdinand:
              You can not send a Python object via messages (from Python). But actually.. it's a good idea. This
              would be possible to implement I think. Maybe they can add it for R15. 🙂
                On 16/03/2013 at 04:29, xxxxxxxx wrote:
                i am not talking about sending the instance, but his data, some arrays or whatever.
                and aside from that. the data contains pyobjects, not sure if i do understand pyobjects
                correctly, but aren't they meant to hold references to methods and such stuff too ?
                never went down very far this rabbit hole, sending some variables always has been
                enough for me.
                or i musunderstood this thread, i thought he has pluginclass a with member b. now he
                wants to read b from somewhere only knowing the gelistnode instance associated with
                his plugin.
                  On 16/03/2013 at 04:35, xxxxxxxx wrote:
                  Hi Ferdiand,
                  Holy Sh*t I really didn't know that was possible!
                  MY_MSG = 5000140436
                  class Test(c4d.plugins.ObjectData) :
                      def Message(self, op, msg, data) :
                          if msg == MY_MSG:
                              data.do_stuff()
                  class Foo(object) :
                      def do_stuff(self) :
                          print "Foo.do_stuff()"
                      op.Message(MY_MSG, Foo())
                  And you knew that? I always thought that was not possible (didn't try it out since now, though)!
                  That's so awesome! 😂
                    On 16/03/2013 at 04:44, xxxxxxxx wrote:
                    Seriously, is that in the documentation?! I never read it anywhere! From several reasons and
                    thinkings I concluded it would not be possible. I see, I should just have tried it out!
                    Anyway, rown, something like this should work then:
                    MSG_GIMMELIST = 10000234 # Unique Identifier from the Plugincafe!
                    class PlgTAG(plugins.TagData) :
                        list_ = []
                        def Init(self, node) :
                        def Message(self, node, type, data) :
                            if type == MSG_GIMMELIST:
                                data.value = self.list_
                        def AnyFunctionToDefineList(self, ... ) :
                            self.list_ =  ["Hello", 12.3, "Everybody"]
                    class ValueBox(object) :
                        def __init__(self, value=None) :
                            super(ValueBox, self).__init__()
                            self.value = value
                        tag = op.GetTag(c4d.Tplg)
                        box = ValueBox()
                        tag.Message(MSG_GIMMELIST, box)
                        print box.value
                    Best,
                    -Niklas
                      On 16/03/2013 at 05:05, xxxxxxxx wrote:
                      IT IS UNBELIEVABLE!!!
                      Thank you both very much! Thanks Devil for letting Niklas know that and thanks Niklas for letting me know how it works.
                      Greetings
                      rown
                        On 16/03/2013 at 05:09, xxxxxxxx wrote:
                        My thanks go to Ferdinand as well, I never would've known that if he wouldn't have told me. 🙂
                          On 16/03/2013 at 06:35, xxxxxxxx wrote:
                          lol, you are welcome. and no i didn't know it exactly, but i assumed it. yannick showed here
                          once how to unpack pyobject data from a message method, which led me to some reading
                          about the pyobject class.
