    How to get a variable from plugin.tag
    15 Posts 0 Posters 2.1k Views
      On 15/03/2013 at 16:38, xxxxxxxx wrote:
      Hello Niklas,
      yes, you are right. The example isnt meaningful. Id like to do something like this:
      class PlgTAG(plugins.TagData) :
        list_ = []
        def Init(self, node) :
        def Message(self, node, type, data) :
        def AnyFunctionToDefineList(self, ... ) :
            self.list_ = ["Hello", 12.3, "Everybody"]
      PythonTag
        tag = The plugintag
        list_ = tag.GetTheListSomehow()
        Do stuff with list_
        On 16/03/2013 at 00:50, xxxxxxxx wrote:
        Your plugin tag must be attached to an object in the scene, it can't exist on its own. So in your python tag, you could do something like:
        * look for the first active object in the scene
        * check to see if it has your plugin tag attached to it
        * if it does, get the list
        How you get the list depends on what it is. If it's an InExclude list, you can get the tag's BaseContainer, then get the list from that. If it's an array (as you showed in your code) you'll have to make it available to other objects in some way. Then the python tag can get hold of the list and do whatever with it.
        It's easy in C++ but I'm not sure if the same method works in Python. In C++ you would probably make the array private, then provide getter/setter functions to let another object access it. Or do it the dirty way of just making the array public, then anything can access it but without any checks on the plugin's part as to what they do with it.
          On 16/03/2013 at 02:09, xxxxxxxx wrote:
          Hello spedler,
          thanks for reply. I know how to get my tag in python-tag and checking if its attached and so. The example is just an example.
          But thats what I want. I do not know anything about C++, so Ive to take a look what private means and getter/setter is.
          Is C++ -> public the same as Python -> global? If so, Im still not sure how to call the list/array from python tag.
          Thanks very much
          rown
            On 16/03/2013 at 02:46, xxxxxxxx wrote:
            It doesn't work with Python unfortunately. We do not have access to the NodeData of a plugin in
            Python, or better say we can not get the NodeData from a BaseList2D object! It would be possible
            with a bit of hacking, but it's not very "beautiful".
            You could exchange information via a Python module or a c4dtools.library.Library class. I do
            not recommend the first one. An example for the c4dtools Library to be put in your Python plugin
            file:
            # Python Plugin File
            import weakref
            import c4dtools
            class PluginTag(c4d.plugins.TagData) :
                op = None
                instances = []
                def Init(self, op) :
                    self.instances.append(weakref.ref(self))
                    self.list_ = []
                    self.op = op
                def Free(self) :
                    try:
                        self.instances.remove(weakref.ref(self))
                    except ValueError:
                        pass
            class MyLibrary(c4dtools.library.Library) :
                class Meta:
                    # Global unique identifier!
                    name = 'my-super-duper-cool-library'
                def get_plugin_tags(self) :
                    return PluginTag.instances[:]
            # Python Tag (or just somewhere else than the plugin file)
            import c4dtools
            lib = c4dtools.load_library('my-super-duper-cool-library')
            for data in lib.get_plugin_tags() :
                data = data() # dereference the weakref
                if not data:
                    continue
                print data.list_
            Note that this only works when you place the c4dtools module somewhere the Python Interpreter
            can always find it, and not as a local distributed dependency as described in this article.
              On 16/03/2013 at 03:15, xxxxxxxx wrote:
              Hey Niklas,
              thank you very much. I´ll try your lines.
              But one other question. Is it easier/allowed to exchange information between NodeData(plugin.tag) and BaseData(command.tag)?
                On 16/03/2013 at 03:24, xxxxxxxx wrote:
                the most common approach would be messages for such a problem. both the sending
                and the recieving class would implement a message method and therefore had to be
                derived from a c4d class which implements such a method. but i have never tried this
                from a script (python-tag).
                  Hi rown,
                  yes it is allowed, but limited in Python. You can easily exchange data within C++ between the
                  plugin classes.
                  @Ferdinand:
                  You can not send a Python object via messages (from Python). But actually.. it's a good idea. This
                  would be possible to implement I think. Maybe they can add it for R15. 🙂
                    On 16/03/2013 at 04:29, xxxxxxxx wrote:
                    i am not talking about sending the instance, but his data, some arrays or whatever.
                    and aside from that. the data contains pyobjects, not sure if i do understand pyobjects
                    correctly, but aren't they meant to hold references to methods and such stuff too ?
                    never went down very far this rabbit hole, sending some variables always has been
                    enough for me.
                    or i musunderstood this thread, i thought he has pluginclass a with member b. now he
                    wants to read b from somewhere only knowing the gelistnode instance associated with
                    his plugin.
                      On 16/03/2013 at 04:35, xxxxxxxx wrote:
                      Hi Ferdiand,
                      Holy Sh*t I really didn't know that was possible!
                      MY_MSG = 5000140436
                      class Test(c4d.plugins.ObjectData) :
                          def Message(self, op, msg, data) :
                              if msg == MY_MSG:
                                  data.do_stuff()
                      class Foo(object) :
                          def do_stuff(self) :
                              print "Foo.do_stuff()"
                          op.Message(MY_MSG, Foo())
                      And you knew that? I always thought that was not possible (didn't try it out since now, though)!
                      That's so awesome! 😂
                        On 16/03/2013 at 04:44, xxxxxxxx wrote:
                        Seriously, is that in the documentation?! I never read it anywhere! From several reasons and
                        thinkings I concluded it would not be possible. I see, I should just have tried it out!
                        Anyway, rown, something like this should work then:
                        MSG_GIMMELIST = 10000234 # Unique Identifier from the Plugincafe!
                            list_ = []
                                if type == MSG_GIMMELIST:
                                    data.value = self.list_
                        class ValueBox(object) :
                            def __init__(self, value=None) :
                                super(ValueBox, self).__init__()
                                self.value = value
                            tag = op.GetTag(c4d.Tplg)
                            box = ValueBox()
                            tag.Message(MSG_GIMMELIST, box)
                            print box.value
                        Best,
                        -Niklas
                          On 16/03/2013 at 05:05, xxxxxxxx wrote:
                          IT IS UNBELIEVABLE!!!
                          Thank you both very much! Thanks Devil for letting Niklas know that and thanks Niklas for letting me know how it works.
                          Greetings
                          rown
                            On 16/03/2013 at 05:09, xxxxxxxx wrote:
                            My thanks go to Ferdinand as well, I never would've known that if he wouldn't have told me. 🙂
                              On 16/03/2013 at 06:35, xxxxxxxx wrote:
                              lol, you are welcome. and no i didn't know it exactly, but i assumed it. yannick showed here
                              once how to unpack pyobject data from a message method, which led me to some reading
                              about the pyobject class.
