    Acccessing Inexclude Data
    21 Posts 0 Posters 12.2k Views
      On 11/03/2013 at 13:39, xxxxxxxx wrote:
      Hey everyone,
      I'm making a plugin with python. I'ts an objectData Plugin and i'm using .h and .res files for the dialog. I have inexclude lists in the dialog. I have no idea however how to access the objects which i drop into those lists. Also, i couldn't find out where to look in the documentation. I found in the c++ docs how to correctly set up my .h and .res file, but not how to then use that data with python. Neither in the python docs.
      Any help is appreciated!
        On 11/03/2013 at 14:29, xxxxxxxx wrote:
        c4d.InExcludeData it is all there. There also multiple threads here on PC dealing
        with the InExcludeData class. Nothing really out of the ordinary here. Only  thing
        worth mentioning is, that you should always construct an instance with an
        existing instance, otherwise funny things tend to happen, despite the fact the
        parameter is flagged optional in the docs.
          On 12/03/2013 at 01:11, xxxxxxxx wrote:
          Thanks! I am however still unable to get it done. I must mention at this point that i'm  a beginner.
          I have this . res file:
          CONTAINER Omlr
            NAME Omlr;
            INCLUDE Obase;
            GROUP ID_OBJECTPROPERTIES
                GROUP
                    BOOL DE_ACTIVATE {}
                    BUTTON VISUAL_REP {}
                IN_EXCLUDE LAYER_ONE_INEX  {}
                IN_EXCLUDE LAYER_TWO_INEX   {}
                IN_EXCLUDE LAYER_THREE_INEX   {}
          and this .h file:
          #ifndef _Oatom_H_
          #define _Oatom_H_
          enum
            Omlr                 = 1029977,
            DE_ACTIVATE            = 1000,
            VISUAL_REP            = 1001,
            LAYER_ONE_INEX        = 1002,
            LAYER_TWO_INEX        = 1003,
            LAYER_THREE_INEX    = 1004
          #endif
          If yomeone could tell me what code gets me an inexcludedata object with the objects droped in that list i would be really gratefull, because i just can't get it done Confused
          Aurel
            On 12/03/2013 at 01:21, xxxxxxxx wrote:
            this loops through the list.
            def someMethod(mypluginnode, document) :
            \> inExcludeList = mypluginnode[c4d.LAYER_ONE_INEX]
            \> for i in xrange(inExcludeList.GetObjectCount()) :
            \> > obj = inExcludeList.ObjectFromIndex(document, i)
              On 12/03/2013 at 01:57, xxxxxxxx wrote:
              Thanks! I think i kind of understand how to access things from the .res file. But i still can't get it to work, because i would like to trigger the printing of the inexclude list so to say with a button, in a Message function, which doesn't have op as a parameter (if any of this sounds wrong i'm sorry). Here is the code, hope it isn't too much of a bother:
              from c4d import gui, plugins, documents
              import os
              PLUGIN_ID = 1029977
              class MultiLayerRender(c4d.plugins.ObjectData) :
                def Execute(self, op, doc, bt, priority, flags) :
                  def printInEx(op, doc) :
                    inExcludeList = op[c4d.LAYER_ONE_INEX]
                    print inExcludeList
                def createTags(self, op, doc) :
                      self.printInEx(op, doc)
                    selection = doc.GetSelection()
                    tagID = 5637
                    for hostObject in selection:
                        existing = False
                        tags = hostObject.GetTags()
                        for tag in tags:
                            if tag.GetType() == tagID:
                                existing = True
                        if existing == False:
                            hostObject.InsertTag(c4d.BaseTag(tagID))
                def VisibilityOn(self) :
                    tagID = 5637
                        for tag in tags:
                                tag[c4d.COMPOSITINGTAG_SEENBYCAMERA] = True
                def VisibilityOff(self) :
                    tagID = 5637
                        for tag in tags:
                                tag[c4d.COMPOSITINGTAG_SEENBYCAMERA] = False
                def Message(self, node, type, data) :
                    # print "node: " + str(node)
                    if type == c4d.MSG_DESCRIPTION_COMMAND:
                          self.createTags(op, doc) # obviously "op" is not defined
                        # self.VisibilityOn()
                        # self.VisibilityOff()
                        print "type: " + str(type)
                        print "data: " + str(data)
                fn = os.path.join(dir, "res", "Icon.tif")
                bmp.InitWith(fn)
                result = plugins.RegisterObjectPlugin(
                    id = PLUGIN_ID,
                    str = "MultiLayerRender",
                    g = MultiLayerRender,
                    description ="Omlr",
                    info = c4d.OBJECT_GENERATOR,
                    icon =bmp
              All it gives me, is op is not defined. Including op in the Message parameters howvere doesn't work, i can't just add stuff there apparently.
              I tried figuring out what to do with the help of other threads and the docs but i'm apparently not too good at gathering info yet - couldn't get it solved at all.
              Hope this isn't completly wrong and thanks in advance!
              Aurel
                On 12/03/2013 at 02:02, xxxxxxxx wrote:
                self is the first parameter to every instance-bound method.
                printInEx(self, op, doc)
                  On 12/03/2013 at 02:05, xxxxxxxx wrote:
                  btw. I'm using this op parameter because in another plugin (LiveCaptureNull by Michael Auerswald) he uses op[LAYER_ONE_INEX] or whatever his .res entries are.
                    def Draw(self, op, drawpass, bd, bh) :
                        if drawpass == c4d.DRAWPASS_OBJECT:
                            if op[LIVECAPTURE_POS] == True or op[LIVECAPTURE_ROT] == True or op[LIVECAPTURE_SCA] == True:
                                o = op[LIVECAPTURE_LINK]
                                if o is not None:
                                    self.setKey(op, o.GetAbsPos(), o.GetAbsRot(), o.GetAbsScale())
                        return c4d.DRAWRESULT_OK
                    On 12/03/2013 at 02:19, xxxxxxxx wrote:
                    Thanks littledevil and NiklasR for your help so far!
                    Forgetting the self there was really stupid of me -.- however, that doesn't do the trick either. printInEx takes3 arguments (self, op, doc) so i need to call it with those three. In createTags however "op" is not defined. So i have to add it to the list of parameters it takes as well, right? -> createTags(self, op, doc) but then i have to call it with those arguments in the Message method, and
                    def Message(self, node, type, data, op, doc) :
                    gives me an ERROR:
                    TypeError: Message() takes exactly 6 arguments (4 given)
                    Is there a way to solve that?
                      On 12/03/2013 at 03:13, xxxxxxxx wrote:
                      gives me an ERROR:
                      yes and no. you could implement message with op and doc as optional parameters.
                      def Message(self, node, type, data, op = None, doc = None) :
                      But i guess that is not what you want, because c4d still won't know that you
                      expect 6 parameters and call the method with 4 parameters. the only difference
                      would be that python won't raise an error and you could call the method from your
                      code with 6 parameters.
                      but node and op are basically the same. so you can use node as a substiute.
                      and the document can be retrieved from node. with gelistnode.getdocument().
                        On 12/03/2013 at 03:32, xxxxxxxx wrote:
                        Thanks littledevil!
                        I made the following changes:
                          def Message(self, node, type, data, ) :
                                  self.printInEx(node)
                        And
                          def printInEx(self, node) :
                              myPluginNode = c4d.GeListNode.GetDocument(node)
                              print myPluginNode[c4d.LAYER_ONE_INEX]
                        That gives me the error:
                        AttributeError: 'module' object has no attribute 'LAYER_ONE_INEX'
                        I also tried using the ID which is 1002, no luck with that either. Could it be, that it doesn't find my .res or .h file or something?
                        Tahnks in advance!
                        Aurel
                          On 12/03/2013 at 03:39, xxxxxxxx wrote:
                          and just for the record, when overwriting methods inherited from c4d api classes the naming
                          of the parameters does not make any difference, only the order matters, because c4d does not
                          call the methods with their keywords. you could overwrite message also this way.
                          def Message(self, a, b, c) :
                          a(node) would be the the instance derived from gelistdnode of your plugin, a baseobject for
                          example. b(type) would be an integer and c(data) would be a basecontainer/pyobject.
                          python is pretty unique when it comes to method parameters. you could define message also
                          this way.
                          def Message(self, *args) :
                          def Message(self, *kwargs) :
                          both versions accept any amount of  parameters, the first one is non keyworded, the second
                          one is keyworded.
                          myclass.message((a)) # for *args
                          myclass.message((a,b)) # for *args
                          myclass.message((a,b,c)) # for *args
                          myclass.message({'node': a, 'type': b, 'data':c}) # for *kwargs
                            myPluginNode is a basedocument, the basedocument the instance of the gelistnode
                            attached to your pluginclass is attached to. therefore trying to read your inex list does
                            not make much sense, because the inex list is a member of your your plugin instance,
                            not of the document.
                            	if isinstance(node, c4d.GeListNode) :
                                  	doc = node.GetDocument()
                                  	print node[c4d.LAYER_ONE_INEX]
                              On 12/03/2013 at 05:03, xxxxxxxx wrote:
                              It works so far, except that it still doesn't find LAYER_ONE_INEX.
                              my code ATM:
                              Error:
                              File "'MLR.pyp'", line 62, in Message
                              File "'MLR.pyp'", line 22, in printInEx
                              NameError: global name 'LAYER_ONE_INEX' is not defined
                              If i change
                              to
                                    print doc[c4d.LAYER_ONE_INEX]
                              i get the error:
                              Do i have to specifically include stuff from Omlr.res / .h? I find it hard to believe that it can be this hard to get that inexclude data - I feel like i'm doing something fundamentaly wrong.
                              EDIT:
                              I just noticed that
                              Doesn't make much sense, because i don't need the document for that, sorry bout that ;/
                              Aurel
                                On 12/03/2013 at 05:14, xxxxxxxx wrote:
                                have you initialized your attribute ? most customedatatypes have to be initialized, otherwise
                                they won't work.
                                  On 12/03/2013 at 05:26, xxxxxxxx wrote:
                                  I GOT IT!!
                                  It's just that I, being a beginner and all, thought that it's supposed to be
                                  node[c4d.the name from the .h file]
                                  but it's actualy
                                  node[c4d.the ID associated with the name from the .h file]
                                  so i first had to define LAYER_ONE_INEX = 10002 in the .pyp file XD
                                  Sorry to bother you with such basic problems and THANK you a lot 😉
                                  Aurel
                                    I GOT IT!!
                                    but it's actualy
                                    Aurel
                                    you have to init your attribute as i wrote. read c4d.plugins.NodeData.Init()
                                    and c4d.plugins.NodeData.InitAttr() you do not have to define the ID in your
                                    py file again.
                                      On 12/03/2013 at 05:45, xxxxxxxx wrote:
                                      Allright, i will do that! btw. As an obviously pretty expirienced plugin creator, what's in your oppinion the best way of becoming better and understanding the general concept behind cinema? because i would have never thought of looking in those places:
                                      c4d.plugins.NodeData.Init() and c4d.plugins.NodeData.InitAttr()
                                      And i most of the time find the plugins more confusing than helping ;(
                                      Aurel
                                        On 12/03/2013 at 07:55, xxxxxxxx wrote:
                                        i don't think there is any easy way to learn the c4d api, but it is easier than it might look
                                        on the first glance. simply read the documenation. i started with scripts and added stuff
                                        as i needed it. you should know and understand the basic principles of oo-programming,
                                        when you to start writing plugins for c4d (polymorphism and so on).
                                        those are the most important classes/modules in the python api. >> means read also any
                                        class which inherits from this class.
                                        c4d.Matrix
                                        c4d.Vector
                                        c4d.BaseTime
                                        c4d.BaseContainer
                                        c4d.C4dAtom (>>)
                                        c4d.documents.BaseDocument
                                        c4d.plugins.BaseData (>>)
                                        c4d.utils
                                        when you know these you have pretty much the basic tools to write plugins.
                                          On 12/03/2013 at 16:46, xxxxxxxx wrote:
                                          Here's some utility functions and examples how I deal with an In/Ex list in an ObjectData plugin and button presses and UI updates.  These are methods in that ObjectData derived class (i.e., my plug-in). Some is pseudo so don't literally try and use this.  More to see how another person approaches it.
                                              def __init__(self, node, op) :
                                                  node.InitAttr(op, c4d.InExcludeData, [c4d.YOUR_INEX_HERE])
                                          CALLED WHENEVER A BUTTON IS PRESSED
                                          def HandleButton(self, id, op) :
                                                  """Make an if statement to do something depending on DescID"""
                                                  #SAMPLE: if id['id'][0].id == 2008: self.__dropdowngrey = False
                                                  #if id['id'][0].id == c4d.NAMELISTBUTTON: self.__NAMEPRINTFUNCTION(op)
                                          CALLED WHENEVER AN ATTRIBUTE CHANGES
                                          def UpdateChange(self, op) :
                                                  """Any time a user changes an attribute this gets called"""
                                                  print 'someone changed a user doodad'
                                          RECEIVE MESSAGES FROM C4D
                                          def Message(self, op, type, data) :
                                          #Check for button press to call HandleButton function
                                                  if type == c4d.MSG_DESCRIPTION_COMMAND: self.HandleButton(data, op)
                                                  #Check for any attribute changes to call UpdateChange function
                                                  if type == c4d.MSG_DESCRIPTION_CHECKUPDATE: self.UpdateChange(op)
                                          def \__NAMEPRINTFUNCTION(self, op) :
                                          	list = op[c4d.YOUR_INEX_HERE]
                                          	for i in xrange(list.GetObjectCount()) :
                                          		#get the object, then get the name and print it
                                            one is keyworded.
                                            For the completeness: This is not correct. kwargs is short for "keyword arguments" and using them
                                            in an "arguments" context is a bit confusing.
                                            def func(*args, **kwargs) :
                                                pass
                                            To pass arguments for *args and **kwargs, you can pass them like any other arguments. You
                                            wouldn't need the *args and **kwargs arguments in the examples you've mentioned.
                                            def func_1(args, kwargs) :
                                                print args
                                                print kwargs
                                            def func_2(*args, **kwargs) :
                                                print args
                                                print kwargs
                                            func_1((3, 4, 5), {'node': op, 'data': data})
                                            func_2(3, 4, 5, node=op, data=data)
                                            args = (3, 4, 5)
                                            kwargs = {'node': op, 'data': data}
                                            All four function-calls will print the exactly same output here.
