    Unicode characters
    12 Posts 0 Posters 1.4k Views
      On 19/11/2012 at 09:24, xxxxxxxx wrote:
      In Python, you just need to put 'u' before the string literal: u"\u00C5land (Finland)". Strings in CINEMA fully use Unicode characters.
        On 19/11/2012 at 10:39, xxxxxxxx wrote:
        Thanks.
        As always a clear and fast answer!
          On 20/11/2012 at 04:24, xxxxxxxx wrote:
          Sorry, not yet completely clear.
          The following works:
          self.AddChild(MY_1SELCONTINENT, CUSTOM, u"\u00C5land (Finland)")
          This works too:
          finland = u"\u00C5land (Finland)"
          self.AddChild(MY_1SELCONTINENT, CUSTOM, finland)
          This, of course, does not work:
          self.AddChild(MY_1SELCONTINENT, CUSTOM, ufinland)
          What I want.
          I read in all variables, for example finland = "\u00C5land (Finland)"
          How to display this in my GUI?
            How do you read ufinland  string variable? I think you could use unicode() Python built-in function.
            EDIT: Ok, I see you have finland but adding 'u' before doesn't do anything because it only works with string literals. ufinland is a new variable. So you should call unicode(finland) instead.
              On 20/11/2012 at 08:34, xxxxxxxx wrote:
              Sorry, that does not work.
                    self.AddChild(MY_1SELCONTINENT, CUSTOM, unicode(finland))
              It display in the field: \u00C5land (Finland)
                On 20/11/2012 at 10:00, xxxxxxxx wrote:
                Do you read Unicode strings from a file? You should then decode them to utf-8:
                input = open('unicode.txt')
                finland = input.read()
                print finland.decode('utf8')
                  On 20/11/2012 at 13:27, xxxxxxxx wrote:
                  I tried following script, but it does not work it still displays:"\u00C5land (Finland)" and not the first unicode character.
                  coding: UTF-8
                  from c4d import gui
                  unicode.txt contains one line:
                        print "finland utf8: ", finland.decode('utf8')
                        gui.MessageDialog(finland)
                    This is because the unicode file should contain "Ã…land (Finland)", not "\u00C5land (Finland)".
                    Here's the code I used:
                    # coding: UTF-8
                    # If you specify UTF-8 encoding, you then don't need to replace Ã… by \u00C5 in your code
                    # See string literal below
                    from c4d import gui
                    def WriteUnicode() :
                        utf8_string = u"Ã…land (Finland)".encode('utf8')
                        output = open('unicode.txt', 'w')
                        output.write(utf8_string)
                        output.close()
                    def ReadUnicode() :
                        utf8_string = input.read()
                        print utf8_string.decode('utf8')
                        WriteUnicode()
                        ReadUnicode()
                      On 21/11/2012 at 02:08, xxxxxxxx wrote:
                      Ok, clear.
                      However, the input I read from the files uses "\u00C5land (Finland)"
                      I use the Cinema 4d file \CINEMA 4D R13\modules\advanced render\sky\res\cities.csv
                      So, how to read that file and display it properly?
                        Ok, clear.
                        Ok, I finally found the solution 🙂.
                        We have to decode the string with  unicode_escape codec to produce a string that is suitable as raw Unicode literal in Python source code (u'' does this directly with literals).
                        Here's the code:
                        print finland # Stored as '\\u00C5land' (double escape)
                        print finland.decode('unicode_escape')
                        And this code is the same than:
                        print finland
                          On 21/11/2012 at 07:26, xxxxxxxx wrote:
                          Thank you very much.
                          Appreciate the patience and willing to solve it.
