    Unicode characters
    12 Posts 0 Posters 1.4k Views
      On 19/11/2012 at 10:39, xxxxxxxx wrote:
      Thanks.
      As always a clear and fast answer!
        On 20/11/2012 at 04:24, xxxxxxxx wrote:
        Sorry, not yet completely clear.
        The following works:
        self.AddChild(MY_1SELCONTINENT, CUSTOM, u"\u00C5land (Finland)")
        This works too:
        finland = u"\u00C5land (Finland)"
        self.AddChild(MY_1SELCONTINENT, CUSTOM, finland)
        This, of course, does not work:
        self.AddChild(MY_1SELCONTINENT, CUSTOM, ufinland)
        What I want.
        I read in all variables, for example finland = "\u00C5land (Finland)"
        How to display this in my GUI?
          How do you read ufinland  string variable? I think you could use unicode() Python built-in function.
          EDIT: Ok, I see you have finland but adding 'u' before doesn't do anything because it only works with string literals. ufinland is a new variable. So you should call unicode(finland) instead.
            On 20/11/2012 at 08:34, xxxxxxxx wrote:
            Sorry, that does not work.
                  self.AddChild(MY_1SELCONTINENT, CUSTOM, unicode(finland))
            It display in the field: \u00C5land (Finland)
              On 20/11/2012 at 10:00, xxxxxxxx wrote:
              Do you read Unicode strings from a file? You should then decode them to utf-8:
              input = open('unicode.txt')
              finland = input.read()
              print finland.decode('utf8')
                On 20/11/2012 at 13:27, xxxxxxxx wrote:
                I tried following script, but it does not work it still displays:"\u00C5land (Finland)" and not the first unicode character.
                coding: UTF-8
                from c4d import gui
                unicode.txt contains one line:
                      print "finland utf8: ", finland.decode('utf8')
                      gui.MessageDialog(finland)
                  This is because the unicode file should contain "Ã…land (Finland)", not "\u00C5land (Finland)".
                  Here's the code I used:
                  # coding: UTF-8
                  # If you specify UTF-8 encoding, you then don't need to replace Ã… by \u00C5 in your code
                  # See string literal below
                  from c4d import gui
                  def WriteUnicode() :
                      utf8_string = u"Ã…land (Finland)".encode('utf8')
                      output = open('unicode.txt', 'w')
                      output.write(utf8_string)
                      output.close()
                  def ReadUnicode() :
                      utf8_string = input.read()
                      print utf8_string.decode('utf8')
                      WriteUnicode()
                      ReadUnicode()
                    On 21/11/2012 at 02:08, xxxxxxxx wrote:
                    Ok, clear.
                    However, the input I read from the files uses "\u00C5land (Finland)"
                    I use the Cinema 4d file \CINEMA 4D R13\modules\advanced render\sky\res\cities.csv
                    So, how to read that file and display it properly?
                      Ok, clear.
                      Ok, I finally found the solution 🙂.
                      We have to decode the string with  unicode_escape codec to produce a string that is suitable as raw Unicode literal in Python source code (u'' does this directly with literals).
                      Here's the code:
                      print finland # Stored as '\\u00C5land' (double escape)
                      print finland.decode('unicode_escape')
                      And this code is the same than:
                      print finland
                        On 21/11/2012 at 07:26, xxxxxxxx wrote:
                        Thank you very much.
                        Appreciate the patience and willing to solve it.
