    Unicode characters
    12 Posts 0 Posters 1.2k Views
      On 19/11/2012 at 07:07, xxxxxxxx wrote:
      How to display unicode UTF-8 characters in a menu field?
      E.g. I want to display "\u00C5land (Finland)", which display a capital A with a small 0 above it.
      I have added # coding: UTF-8 to my python code, but nothing happens.
        On 19/11/2012 at 09:24, xxxxxxxx wrote:
        In Python, you just need to put 'u' before the string literal: u"\u00C5land (Finland)". Strings in CINEMA fully use Unicode characters.
          On 19/11/2012 at 10:39, xxxxxxxx wrote:
          Thanks.
          As always a clear and fast answer!
            On 20/11/2012 at 04:24, xxxxxxxx wrote:
            Sorry, not yet completely clear.
            The following works:
            self.AddChild(MY_1SELCONTINENT, CUSTOM, u"\u00C5land (Finland)")
            This works too:
            finland = u"\u00C5land (Finland)"
            self.AddChild(MY_1SELCONTINENT, CUSTOM, finland)
            This, of course, does not work:
            self.AddChild(MY_1SELCONTINENT, CUSTOM, ufinland)
            What I want.
            I read in all variables, for example finland = "\u00C5land (Finland)"
            How to display this in my GUI?
              How do you read ufinland  string variable? I think you could use unicode() Python built-in function.
              EDIT: Ok, I see you have finland but adding 'u' before doesn't do anything because it only works with string literals. ufinland is a new variable. So you should call unicode(finland) instead.
                On 20/11/2012 at 08:34, xxxxxxxx wrote:
                Sorry, that does not work.
                      self.AddChild(MY_1SELCONTINENT, CUSTOM, unicode(finland))
                It display in the field: \u00C5land (Finland)
                  On 20/11/2012 at 10:00, xxxxxxxx wrote:
                  Do you read Unicode strings from a file? You should then decode them to utf-8:
                  input = open('unicode.txt')
                  finland = input.read()
                  print finland.decode('utf8')
                    On 20/11/2012 at 13:27, xxxxxxxx wrote:
                    I tried following script, but it does not work it still displays:"\u00C5land (Finland)" and not the first unicode character.
                    coding: UTF-8
                    from c4d import gui
                    unicode.txt contains one line:
                          print "finland utf8: ", finland.decode('utf8')
                          gui.MessageDialog(finland)
                      This is because the unicode file should contain "Ã…land (Finland)", not "\u00C5land (Finland)".
                      Here's the code I used:
                      # coding: UTF-8
                      # If you specify UTF-8 encoding, you then don't need to replace Ã… by \u00C5 in your code
                      # See string literal below
                      from c4d import gui
                      def WriteUnicode() :
                          utf8_string = u"Ã…land (Finland)".encode('utf8')
                          output = open('unicode.txt', 'w')
                          output.write(utf8_string)
                          output.close()
                      def ReadUnicode() :
                          utf8_string = input.read()
                          print utf8_string.decode('utf8')
                          WriteUnicode()
                          ReadUnicode()
                        On 21/11/2012 at 02:08, xxxxxxxx wrote:
                        Ok, clear.
                        However, the input I read from the files uses "\u00C5land (Finland)"
                        I use the Cinema 4d file \CINEMA 4D R13\modules\advanced render\sky\res\cities.csv
                        So, how to read that file and display it properly?
                          Ok, clear.
                          Ok, I finally found the solution 🙂.
                          We have to decode the string with  unicode_escape codec to produce a string that is suitable as raw Unicode literal in Python source code (u'' does this directly with literals).
                          Here's the code:
                          print finland # Stored as '\\u00C5land' (double escape)
                          print finland.decode('unicode_escape')
                          And this code is the same than:
                          print finland
                            On 21/11/2012 at 07:26, xxxxxxxx wrote:
                            Thank you very much.
                            Appreciate the patience and willing to solve it.
