    Null object dimensions
    25 Posts 0 Posters 14.8k Views
      On 12/09/2012 at 12:03, xxxxxxxx wrote:
      @tca: Do you mean for converting the generators? 🙂
      Well, I actually don't like the idea of using this method at all. In my current project I need to know the
      BB size in a Tag. This kinda "brute-force" computation would be done every time the tag was
      executed. I could live with that if it would be once or so :X
      -Nik
        On 12/09/2012 at 13:27, xxxxxxxx wrote:
        The computation actually is very negligible up to rather decent setups.
        One trick is to strip all tags on the returned csto/Cached hierarchy but
        variable tags (the invisibles, points etc) before running the join command.
        The other to run/store some base check data, like hierarchy count, sum
        of vectors or whatever i.e. as well as compare time.
        Just an idea anyhow, that I use at times anyway 🙂
        Lennart
          On 13/09/2012 at 06:20, xxxxxxxx wrote:
          Hey guys,
          I created a AABBox class for another thread, but expanded it to allow you to add additional objects (cumulative bounding box).  It's in C++, but you're welcome to use/convert it if it's any use...
          // AABBox Class - An implementation of an "Axis Aligned Bounding Box" class
          // This implementation actually builds a OBB (Oriented Bounding Box) to use as the
          // source for generating the AABB.
          // As implemented, if the object is an instance of a PointObject, it uses the
          // (Global-space) points of the object as the OBB.
          // If it's not a PointObject, it generates a BBox (8-point cube) out of the min/max
          // extents of the object (again in Global-space) to use as the OBB.
          // The class also has provisions for generating a bounding box for a combination of
          // multiple objects, as well as a simple collision-detection routine.
          class AABBox
          private:
            Vector    m_bbMin;
            Vector    m_bbMax;
            Bool    m_init;
            void GetAABBox(BaseObject *op, Vector *pMin, Vector *pMax);
            Vector GetMin(void)                        { return m_bbMin; }
            Vector GetMax(void)                        { return m_bbMax; }
            Bool CollidesWith(BaseObject *op);
            void AddObject(BaseObject *op);
            void Init(BaseObject *op = NULL);
            AABBox(BaseObject *op);
            AABBox(void) {    m_init = false; }
            ~AABBox(void) {}
          AABBox::AABBox(BaseObject *op)
            this->Init(op);
          void AABBox::Init(BaseObject *op)
            m_init = false;
            m_bbMin = Vector();
            m_bbMax = Vector();
            if( !op )    return;
            this->GetAABBox(op, &m_bbMin, &m_bbMax);
            m_init = true;
          void AABBox::AddObject(BaseObject *op)
            if( !op )    return;
            if( !m_init )
                this->Init(op);
            else
                // first store the old values...
                MinMax mm;
                mm.Init(m_bbMin);
                mm.AddPoint(m_bbMax);
                // then add new object...
                mm.AddPoint(m_bbMin);
                // and determine new extents...
                m_bbMin = mm.GetMin();
                m_bbMax = mm.GetMax();
          void AABBox::GetAABBox(BaseObject *op, Vector *pMin, Vector *pMax)
            Matrix opgm = op->GetMgn();
            MinMax mm;
            // With this implementation, if the BaseObject being passed in is an instance of a PointObject,
            // then the OBB will be built from the actual Global-space points... this take longer if there
            // are more than 8 points, but gives a tighter fitting AABBox.  If this is too slow, you can
            // get rid of this top part and just always do 8 points, below.
            // to see the difference in using the actual points and the 8 point box, see the image on the
            // second page of this article: http://www.gamasutra.com/view/feature/3426/when_two_hearts_collide_.php
            if( op->IsInstanceOf(Opoint) )
                const Vector *pPoints = ToPoint(op)->GetPointR();
                LONG i, numPoints = ToPoint(op)->GetPointCount();
                mm.Init();
                for(i=0; i<numPoints; i++)
                    mm.AddPoint(*pPoints * opgm);
                    pPoints++;
            else
                // ...otherwise, generate an 8 point OBB from the Global-space extent vectors
                *pMin = op->GetMp() - op->GetRad(); // Bounding-Box minimum extents (Local-space)
                *pMax = op->GetMp() + op->GetRad(); // Bounding-Box maximum extents (Local-space)
                // bottom
                mm.Init(*pMin * opgm);
                mm.AddPoint(Vector(pMin->x, pMin->y, pMax->z) * opgm);
                mm.AddPoint(Vector(pMax->x, pMin->y, pMax->z) * opgm);
                mm.AddPoint(Vector(pMax->x, pMin->y, pMin->z) * opgm);
                // top
                mm.AddPoint(*pMax * opgm);
                mm.AddPoint(Vector(pMax->x, pMax->y, pMin->z) * opgm);
                mm.AddPoint(Vector(pMin->x, pMax->y, pMin->z) * opgm);
                mm.AddPoint(Vector(pMin->x, pMax->y, pMax->z) * opgm);
            // convert to AABBox (described by min/max extent vectors)
            *pMin = mm.GetMin();
            *pMax = mm.GetMax();
          //    GePrint(op->GetName()+" bbMin: "+utVecToString(*pMin)+" bbMax: "+utVecToString(*pMax));
          Bool AABBox::CollidesWith(BaseObject *op)
            if( !m_init )    return false;
            Vector bbMin; // Bounding-Box minimum extents
            Vector bbMax; // Bounding-Box maximum extents
            this->GetAABBox(op, &bbMin, &bbMax);
            Bool xlap, ylap, zlap;
            if( bbMin.x < m_bbMax.x && bbMax.x > m_bbMin.x )    xlap = true;    else xlap = false;
            if( bbMin.y < m_bbMax.y && bbMax.y > m_bbMin.y )    ylap = true;    else ylap = false;
            if( bbMin.z < m_bbMax.z && bbMax.z > m_bbMin.z )    zlap = true;    else zlap = false;
            // output for testing purposes - delete or comment out it not needed
            String slap = op->GetName();
            slap += " xlap: ";                slap += xlap ? "true" : "false";
            slap += " ylap: ";                slap += ylap ? "true" : "false";
            slap += " zlap: ";                slap += zlap ? "true" : "false";
            slap += " BBox Collision: ";    slap += (xlap && ylap && zlap) ? "true" : "false";
            GePrint(slap);
            return (xlap && ylap && zlap);
          // simple testing routine... builds AABBox from first object in scene (actually,
          // whatever object you pass to it), then tests for collisions with all other
          // (root level) objects below it in scene (but doesn't really do anything with
          // the results)
          void BBoxTest(BaseObject *op)
            if( op )
                AABBox aabb(op);
                BaseObject *op2 = op->GetNext();
                LONG collisions = 0;
                while( op2 )
                    collisions += aabb.CollidesWith(op2);
                    op2 = op2->GetNext();
          // simple testing routine to recursively walk the heirarchy, adding each object to
          // the AABBox, to generate a single / cumulative bounding box.
          void AccumulateBBox(AABBox *aabb, BaseObject *op)
            if( !aabb )    return;
            while(op)
                aabb->AddObject(op);
                AccumulateBBox(aabb, op->GetDown());
                op = op->GetNext();
          ...I didn't include any code to call the bottom two test routines, but it should be pretty straight-forward.  Note that you can also get the min/max vectors from the AABBox (which would be in Global-space).
          Cheers.
            On 13/09/2012 at 06:33, xxxxxxxx wrote:
            Giblet, you made my day. Thank you very very much! 🍺
            I actually need C++, I was just prototyping in Python. 🙂
            -Niklas
              On 13/09/2012 at 06:37, xxxxxxxx wrote:
              Someone mentioned Generators (and Deformers and such)... I hadn't really looked into that, so you might still need to add code to ctso some objects, etc.  Alternatively, you might just doc->Polygonize() first and use that (ctso on the entire doc).
                On 14/09/2012 at 08:15, xxxxxxxx wrote:
                Hei folks,
                in case someone needs it: Here's the working version of the above scene-file using Giblets method (but using GetRad()/GetMp() only!!)
                -Niklas
                  On 14/09/2012 at 11:46, xxxxxxxx wrote:
                  Thanks - it's neat seeing it (working and) ported to Python :). Did you try the full object point-transform method?
                    Do you mean calculating the bounding-box of point-objects from its points? No. Because,
                    1. I'm pretty sure GetDimension() does this internally for polygon-objects.
                    2. For splines, the curves could exceed the bounding box defined only by the points.
                    -Nik
                      On 14/09/2012 at 13:17, xxxxxxxx wrote:
                      ...1. I'm pretty sure GetDimension() does this internally for polygon-objects.
                      Hmm...
                      • Load your scene, delete the 2 cubes.
                      • Add a "Tube" object.
                      • Switch to Front view.
                      • Rotate the Tube 30deg or so clockwise.
                      • Make it editable (turn it into a Polygon Object).
                      • Grab a point and (in Move mode), pull the point up (at that angle).
                      • Observe that the top of the BBox is no longer 'tight' on the object (across the top/right sides).
                        ...doing the point-transform method would tighten that box back up (if you needed that).
                        On 26/06/2015 at 01:43, xxxxxxxx wrote:
                        Oh i think this would solve my problem with this
                        https://developers.maxon.net/forum/topic/6903/7745_eventadd-doesnt-update-c4d
                        Not the topic the solution from NiklasR, but The Python c4d file is 404 missing, here.
                        Anyhow does somebody have a multiple objects boundingbox Python Script Snippet?
                        Kind regards
                        mogh
