    Null object dimensions
    25 Posts 0 Posters 14.7k Views
      On 12/09/2012 at 09:18, xxxxxxxx wrote:
      @Al3D: Thanks for your code. But this comes with the huge overhead of iterating over each point of
      each object. GetRad() and GetMp() call ObjectData::GetDimension() which does not necessarily iterate
      over each point in the mesh. On a cube for example, for GetRad(), it would just return the half of its
      size (PRIM_LEN_CUBE) instead of iterating over each point it has generated. Also, when using your
      technique, you could easily hit generator objects.
      I'm so sure there is a better technique, but the only one that comes into my mind is to convert the
      bounding-box retrieved by GetRad() and GetMp() into an 8 point cube, multiply each point with the
      matrix and then check each point. Is there a better way to do it?
      Niklas
        On 12/09/2012 at 11:09, xxxxxxxx wrote:
        csto objs(hierarchy) -> join()   🙂
        Lennart
          On 12/09/2012 at 12:03, xxxxxxxx wrote:
          @tca: Do you mean for converting the generators? 🙂
          Well, I actually don't like the idea of using this method at all. In my current project I need to know the
          BB size in a Tag. This kinda "brute-force" computation would be done every time the tag was
          executed. I could live with that if it would be once or so :X
          -Nik
            On 12/09/2012 at 13:27, xxxxxxxx wrote:
            The computation actually is very negligible up to rather decent setups.
            One trick is to strip all tags on the returned csto/Cached hierarchy but
            variable tags (the invisibles, points etc) before running the join command.
            The other to run/store some base check data, like hierarchy count, sum
            of vectors or whatever i.e. as well as compare time.
            Just an idea anyhow, that I use at times anyway 🙂
            Lennart
              On 13/09/2012 at 06:20, xxxxxxxx wrote:
              Hey guys,
              I created a AABBox class for another thread, but expanded it to allow you to add additional objects (cumulative bounding box).  It's in C++, but you're welcome to use/convert it if it's any use...
              // AABBox Class - An implementation of an "Axis Aligned Bounding Box" class
              // This implementation actually builds a OBB (Oriented Bounding Box) to use as the
              // source for generating the AABB.
              // As implemented, if the object is an instance of a PointObject, it uses the
              // (Global-space) points of the object as the OBB.
              // If it's not a PointObject, it generates a BBox (8-point cube) out of the min/max
              // extents of the object (again in Global-space) to use as the OBB.
              // The class also has provisions for generating a bounding box for a combination of
              // multiple objects, as well as a simple collision-detection routine.
              class AABBox
              private:
                Vector    m_bbMin;
                Vector    m_bbMax;
                Bool    m_init;
                void GetAABBox(BaseObject *op, Vector *pMin, Vector *pMax);
                Vector GetMin(void)                        { return m_bbMin; }
                Vector GetMax(void)                        { return m_bbMax; }
                Bool CollidesWith(BaseObject *op);
                void AddObject(BaseObject *op);
                void Init(BaseObject *op = NULL);
                AABBox(BaseObject *op);
                AABBox(void) {    m_init = false; }
                ~AABBox(void) {}
              AABBox::AABBox(BaseObject *op)
                this->Init(op);
              void AABBox::Init(BaseObject *op)
                m_init = false;
                m_bbMin = Vector();
                m_bbMax = Vector();
                if( !op )    return;
                this->GetAABBox(op, &m_bbMin, &m_bbMax);
                m_init = true;
              void AABBox::AddObject(BaseObject *op)
                if( !op )    return;
                if( !m_init )
                    this->Init(op);
                else
                    // first store the old values...
                    MinMax mm;
                    mm.Init(m_bbMin);
                    mm.AddPoint(m_bbMax);
                    // then add new object...
                    mm.AddPoint(m_bbMin);
                    // and determine new extents...
                    m_bbMin = mm.GetMin();
                    m_bbMax = mm.GetMax();
              void AABBox::GetAABBox(BaseObject *op, Vector *pMin, Vector *pMax)
                Matrix opgm = op->GetMgn();
                MinMax mm;
                // With this implementation, if the BaseObject being passed in is an instance of a PointObject,
                // then the OBB will be built from the actual Global-space points... this take longer if there
                // are more than 8 points, but gives a tighter fitting AABBox.  If this is too slow, you can
                // get rid of this top part and just always do 8 points, below.
                // to see the difference in using the actual points and the 8 point box, see the image on the
                // second page of this article: http://www.gamasutra.com/view/feature/3426/when_two_hearts_collide_.php
                if( op->IsInstanceOf(Opoint) )
                    const Vector *pPoints = ToPoint(op)->GetPointR();
                    LONG i, numPoints = ToPoint(op)->GetPointCount();
                    mm.Init();
                    for(i=0; i<numPoints; i++)
                        mm.AddPoint(*pPoints * opgm);
                        pPoints++;
                else
                    // ...otherwise, generate an 8 point OBB from the Global-space extent vectors
                    *pMin = op->GetMp() - op->GetRad(); // Bounding-Box minimum extents (Local-space)
                    *pMax = op->GetMp() + op->GetRad(); // Bounding-Box maximum extents (Local-space)
                    // bottom
                    mm.Init(*pMin * opgm);
                    mm.AddPoint(Vector(pMin->x, pMin->y, pMax->z) * opgm);
                    mm.AddPoint(Vector(pMax->x, pMin->y, pMax->z) * opgm);
                    mm.AddPoint(Vector(pMax->x, pMin->y, pMin->z) * opgm);
                    // top
                    mm.AddPoint(*pMax * opgm);
                    mm.AddPoint(Vector(pMax->x, pMax->y, pMin->z) * opgm);
                    mm.AddPoint(Vector(pMin->x, pMax->y, pMin->z) * opgm);
                    mm.AddPoint(Vector(pMin->x, pMax->y, pMax->z) * opgm);
                // convert to AABBox (described by min/max extent vectors)
                *pMin = mm.GetMin();
                *pMax = mm.GetMax();
              //    GePrint(op->GetName()+" bbMin: "+utVecToString(*pMin)+" bbMax: "+utVecToString(*pMax));
              Bool AABBox::CollidesWith(BaseObject *op)
                if( !m_init )    return false;
                Vector bbMin; // Bounding-Box minimum extents
                Vector bbMax; // Bounding-Box maximum extents
                this->GetAABBox(op, &bbMin, &bbMax);
                Bool xlap, ylap, zlap;
                if( bbMin.x < m_bbMax.x && bbMax.x > m_bbMin.x )    xlap = true;    else xlap = false;
                if( bbMin.y < m_bbMax.y && bbMax.y > m_bbMin.y )    ylap = true;    else ylap = false;
                if( bbMin.z < m_bbMax.z && bbMax.z > m_bbMin.z )    zlap = true;    else zlap = false;
                // output for testing purposes - delete or comment out it not needed
                String slap = op->GetName();
                slap += " xlap: ";                slap += xlap ? "true" : "false";
                slap += " ylap: ";                slap += ylap ? "true" : "false";
                slap += " zlap: ";                slap += zlap ? "true" : "false";
                slap += " BBox Collision: ";    slap += (xlap && ylap && zlap) ? "true" : "false";
                GePrint(slap);
                return (xlap && ylap && zlap);
              // simple testing routine... builds AABBox from first object in scene (actually,
              // whatever object you pass to it), then tests for collisions with all other
              // (root level) objects below it in scene (but doesn't really do anything with
              // the results)
              void BBoxTest(BaseObject *op)
                if( op )
                    AABBox aabb(op);
                    BaseObject *op2 = op->GetNext();
                    LONG collisions = 0;
                    while( op2 )
                        collisions += aabb.CollidesWith(op2);
                        op2 = op2->GetNext();
              // simple testing routine to recursively walk the heirarchy, adding each object to
              // the AABBox, to generate a single / cumulative bounding box.
              void AccumulateBBox(AABBox *aabb, BaseObject *op)
                if( !aabb )    return;
                while(op)
                    aabb->AddObject(op);
                    AccumulateBBox(aabb, op->GetDown());
                    op = op->GetNext();
              ...I didn't include any code to call the bottom two test routines, but it should be pretty straight-forward.  Note that you can also get the min/max vectors from the AABBox (which would be in Global-space).
              Cheers.
                On 13/09/2012 at 06:33, xxxxxxxx wrote:
                Giblet, you made my day. Thank you very very much! 🍺
                I actually need C++, I was just prototyping in Python. 🙂
                -Niklas
                  On 13/09/2012 at 06:37, xxxxxxxx wrote:
                  Someone mentioned Generators (and Deformers and such)... I hadn't really looked into that, so you might still need to add code to ctso some objects, etc.  Alternatively, you might just doc->Polygonize() first and use that (ctso on the entire doc).
                    On 14/09/2012 at 08:15, xxxxxxxx wrote:
                    Hei folks,
                    in case someone needs it: Here's the working version of the above scene-file using Giblets method (but using GetRad()/GetMp() only!!)
                    -Niklas
                      On 14/09/2012 at 11:46, xxxxxxxx wrote:
                      Thanks - it's neat seeing it (working and) ported to Python :). Did you try the full object point-transform method?
                        Do you mean calculating the bounding-box of point-objects from its points? No. Because,
                        1. I'm pretty sure GetDimension() does this internally for polygon-objects.
                        2. For splines, the curves could exceed the bounding box defined only by the points.
                        -Nik
                          On 14/09/2012 at 13:17, xxxxxxxx wrote:
                          ...1. I'm pretty sure GetDimension() does this internally for polygon-objects.
                          Hmm...
                          • Load your scene, delete the 2 cubes.
                          • Add a "Tube" object.
                          • Switch to Front view.
                          • Rotate the Tube 30deg or so clockwise.
                          • Make it editable (turn it into a Polygon Object).
                          • Grab a point and (in Move mode), pull the point up (at that angle).
                          • Observe that the top of the BBox is no longer 'tight' on the object (across the top/right sides).
                            ...doing the point-transform method would tighten that box back up (if you needed that).
                            On 26/06/2015 at 01:43, xxxxxxxx wrote:
                            Oh i think this would solve my problem with this
                            https://developers.maxon.net/forum/topic/6903/7745_eventadd-doesnt-update-c4d
                            Not the topic the solution from NiklasR, but The Python c4d file is 404 missing, here.
                            Anyhow does somebody have a multiple objects boundingbox Python Script Snippet?
                            Kind regards
                            mogh
