    Null object dimensions
    25 Posts 0 Posters 14.6k Views
      On 12/09/2012 at 07:39, xxxxxxxx wrote:
      here a function I wrote.
      Note that it is not recursive - if you have a Null as a child it won't work properly.
      What it does is go through every points of every object in the group and save the min and max in global coordinates.
      # get min and max points of a group in global coordinates
      def getMinAndMaxPoints(nullObj) :
        if (nullObj.GetType() != c4d.Onull) :
            #no group
            children = [nullObj]
            children = nullObj.GetChildren()
        groupPos = c4d.Vector(0)
        groupSize = Vector(0)
        groupMinPoint = Vector(0)
        groupMaxPoint = Vector(0)
        start = True
        for child in children:
            mat = child.GetMg()
            globalPos = mat.off
            points =  child.GetAllPoints()
            for point in points:
                #print(point + globalPos)
                point = point + globalPos
                if start == True:
                    start = False
                    groupMinPoint = Vector(point)
                    groupMaxPoint = Vector(point)
                    if groupMinPoint.x > point.x:
                        groupMinPoint.x = point.x
                    if groupMinPoint.y > point.y:
                        groupMinPoint.y = point.y
                    if groupMinPoint.z > point.z:
                        groupMinPoint.z = point.z
                    if groupMaxPoint.x < point.x:
                        groupMaxPoint.x = point.x
                    if groupMaxPoint.y < point.y:
                        groupMaxPoint.y = point.y
                    if groupMaxPoint.z < point.z:
                        groupMaxPoint.z = point.z
                #end else
            #end for points
        #end for child
        dico = dict()
        dico["max"] = groupMaxPoint
        dico["min"] = groupMinPoint
        return dico
      Alex
        On 12/09/2012 at 09:18, xxxxxxxx wrote:
        @Al3D: Thanks for your code. But this comes with the huge overhead of iterating over each point of
        each object. GetRad() and GetMp() call ObjectData::GetDimension() which does not necessarily iterate
        over each point in the mesh. On a cube for example, for GetRad(), it would just return the half of its
        size (PRIM_LEN_CUBE) instead of iterating over each point it has generated. Also, when using your
        technique, you could easily hit generator objects.
        I'm so sure there is a better technique, but the only one that comes into my mind is to convert the
        bounding-box retrieved by GetRad() and GetMp() into an 8 point cube, multiply each point with the
        matrix and then check each point. Is there a better way to do it?
        Niklas
          On 12/09/2012 at 11:09, xxxxxxxx wrote:
          csto objs(hierarchy) -> join()   🙂
          Lennart
            On 12/09/2012 at 12:03, xxxxxxxx wrote:
            @tca: Do you mean for converting the generators? 🙂
            Well, I actually don't like the idea of using this method at all. In my current project I need to know the
            BB size in a Tag. This kinda "brute-force" computation would be done every time the tag was
            executed. I could live with that if it would be once or so :X
            -Nik
              On 12/09/2012 at 13:27, xxxxxxxx wrote:
              The computation actually is very negligible up to rather decent setups.
              One trick is to strip all tags on the returned csto/Cached hierarchy but
              variable tags (the invisibles, points etc) before running the join command.
              The other to run/store some base check data, like hierarchy count, sum
              of vectors or whatever i.e. as well as compare time.
              Just an idea anyhow, that I use at times anyway 🙂
              Lennart
                On 13/09/2012 at 06:20, xxxxxxxx wrote:
                Hey guys,
                I created a AABBox class for another thread, but expanded it to allow you to add additional objects (cumulative bounding box).  It's in C++, but you're welcome to use/convert it if it's any use...
                // AABBox Class - An implementation of an "Axis Aligned Bounding Box" class
                // This implementation actually builds a OBB (Oriented Bounding Box) to use as the
                // source for generating the AABB.
                // As implemented, if the object is an instance of a PointObject, it uses the
                // (Global-space) points of the object as the OBB.
                // If it's not a PointObject, it generates a BBox (8-point cube) out of the min/max
                // extents of the object (again in Global-space) to use as the OBB.
                // The class also has provisions for generating a bounding box for a combination of
                // multiple objects, as well as a simple collision-detection routine.
                class AABBox
                private:
                  Vector    m_bbMin;
                  Vector    m_bbMax;
                  Bool    m_init;
                  void GetAABBox(BaseObject *op, Vector *pMin, Vector *pMax);
                  Vector GetMin(void)                        { return m_bbMin; }
                  Vector GetMax(void)                        { return m_bbMax; }
                  Bool CollidesWith(BaseObject *op);
                  void AddObject(BaseObject *op);
                  void Init(BaseObject *op = NULL);
                  AABBox(BaseObject *op);
                  AABBox(void) {    m_init = false; }
                  ~AABBox(void) {}
                AABBox::AABBox(BaseObject *op)
                  this->Init(op);
                void AABBox::Init(BaseObject *op)
                  m_init = false;
                  m_bbMin = Vector();
                  m_bbMax = Vector();
                  if( !op )    return;
                  this->GetAABBox(op, &m_bbMin, &m_bbMax);
                  m_init = true;
                void AABBox::AddObject(BaseObject *op)
                  if( !op )    return;
                  if( !m_init )
                      this->Init(op);
                  else
                      // first store the old values...
                      MinMax mm;
                      mm.Init(m_bbMin);
                      mm.AddPoint(m_bbMax);
                      // then add new object...
                      mm.AddPoint(m_bbMin);
                      // and determine new extents...
                      m_bbMin = mm.GetMin();
                      m_bbMax = mm.GetMax();
                void AABBox::GetAABBox(BaseObject *op, Vector *pMin, Vector *pMax)
                  Matrix opgm = op->GetMgn();
                  MinMax mm;
                  // With this implementation, if the BaseObject being passed in is an instance of a PointObject,
                  // then the OBB will be built from the actual Global-space points... this take longer if there
                  // are more than 8 points, but gives a tighter fitting AABBox.  If this is too slow, you can
                  // get rid of this top part and just always do 8 points, below.
                  // to see the difference in using the actual points and the 8 point box, see the image on the
                  // second page of this article: http://www.gamasutra.com/view/feature/3426/when_two_hearts_collide_.php
                  if( op->IsInstanceOf(Opoint) )
                      const Vector *pPoints = ToPoint(op)->GetPointR();
                      LONG i, numPoints = ToPoint(op)->GetPointCount();
                      mm.Init();
                      for(i=0; i<numPoints; i++)
                          mm.AddPoint(*pPoints * opgm);
                          pPoints++;
                  else
                      // ...otherwise, generate an 8 point OBB from the Global-space extent vectors
                      *pMin = op->GetMp() - op->GetRad(); // Bounding-Box minimum extents (Local-space)
                      *pMax = op->GetMp() + op->GetRad(); // Bounding-Box maximum extents (Local-space)
                      // bottom
                      mm.Init(*pMin * opgm);
                      mm.AddPoint(Vector(pMin->x, pMin->y, pMax->z) * opgm);
                      mm.AddPoint(Vector(pMax->x, pMin->y, pMax->z) * opgm);
                      mm.AddPoint(Vector(pMax->x, pMin->y, pMin->z) * opgm);
                      // top
                      mm.AddPoint(*pMax * opgm);
                      mm.AddPoint(Vector(pMax->x, pMax->y, pMin->z) * opgm);
                      mm.AddPoint(Vector(pMin->x, pMax->y, pMin->z) * opgm);
                      mm.AddPoint(Vector(pMin->x, pMax->y, pMax->z) * opgm);
                  // convert to AABBox (described by min/max extent vectors)
                  *pMin = mm.GetMin();
                  *pMax = mm.GetMax();
                //    GePrint(op->GetName()+" bbMin: "+utVecToString(*pMin)+" bbMax: "+utVecToString(*pMax));
                Bool AABBox::CollidesWith(BaseObject *op)
                  if( !m_init )    return false;
                  Vector bbMin; // Bounding-Box minimum extents
                  Vector bbMax; // Bounding-Box maximum extents
                  this->GetAABBox(op, &bbMin, &bbMax);
                  Bool xlap, ylap, zlap;
                  if( bbMin.x < m_bbMax.x && bbMax.x > m_bbMin.x )    xlap = true;    else xlap = false;
                  if( bbMin.y < m_bbMax.y && bbMax.y > m_bbMin.y )    ylap = true;    else ylap = false;
                  if( bbMin.z < m_bbMax.z && bbMax.z > m_bbMin.z )    zlap = true;    else zlap = false;
                  // output for testing purposes - delete or comment out it not needed
                  String slap = op->GetName();
                  slap += " xlap: ";                slap += xlap ? "true" : "false";
                  slap += " ylap: ";                slap += ylap ? "true" : "false";
                  slap += " zlap: ";                slap += zlap ? "true" : "false";
                  slap += " BBox Collision: ";    slap += (xlap && ylap && zlap) ? "true" : "false";
                  GePrint(slap);
                  return (xlap && ylap && zlap);
                // simple testing routine... builds AABBox from first object in scene (actually,
                // whatever object you pass to it), then tests for collisions with all other
                // (root level) objects below it in scene (but doesn't really do anything with
                // the results)
                void BBoxTest(BaseObject *op)
                  if( op )
                      AABBox aabb(op);
                      BaseObject *op2 = op->GetNext();
                      LONG collisions = 0;
                      while( op2 )
                          collisions += aabb.CollidesWith(op2);
                          op2 = op2->GetNext();
                // simple testing routine to recursively walk the heirarchy, adding each object to
                // the AABBox, to generate a single / cumulative bounding box.
                void AccumulateBBox(AABBox *aabb, BaseObject *op)
                  if( !aabb )    return;
                  while(op)
                      aabb->AddObject(op);
                      AccumulateBBox(aabb, op->GetDown());
                      op = op->GetNext();
                ...I didn't include any code to call the bottom two test routines, but it should be pretty straight-forward.  Note that you can also get the min/max vectors from the AABBox (which would be in Global-space).
                Cheers.
                  On 13/09/2012 at 06:33, xxxxxxxx wrote:
                  Giblet, you made my day. Thank you very very much! 🍺
                  I actually need C++, I was just prototyping in Python. 🙂
                  -Niklas
                    On 13/09/2012 at 06:37, xxxxxxxx wrote:
                    Someone mentioned Generators (and Deformers and such)... I hadn't really looked into that, so you might still need to add code to ctso some objects, etc.  Alternatively, you might just doc->Polygonize() first and use that (ctso on the entire doc).
                      On 14/09/2012 at 08:15, xxxxxxxx wrote:
                      Hei folks,
                      in case someone needs it: Here's the working version of the above scene-file using Giblets method (but using GetRad()/GetMp() only!!)
                      -Niklas
                        On 14/09/2012 at 11:46, xxxxxxxx wrote:
                        Thanks - it's neat seeing it (working and) ported to Python :). Did you try the full object point-transform method?
                          Do you mean calculating the bounding-box of point-objects from its points? No. Because,
                          1. I'm pretty sure GetDimension() does this internally for polygon-objects.
                          2. For splines, the curves could exceed the bounding box defined only by the points.
                          -Nik
                            On 14/09/2012 at 13:17, xxxxxxxx wrote:
                            ...1. I'm pretty sure GetDimension() does this internally for polygon-objects.
                            Hmm...
                            • Load your scene, delete the 2 cubes.
                            • Add a "Tube" object.
                            • Switch to Front view.
                            • Rotate the Tube 30deg or so clockwise.
                            • Make it editable (turn it into a Polygon Object).
                            • Grab a point and (in Move mode), pull the point up (at that angle).
                            • Observe that the top of the BBox is no longer 'tight' on the object (across the top/right sides).
                              ...doing the point-transform method would tighten that box back up (if you needed that).
                              On 26/06/2015 at 01:43, xxxxxxxx wrote:
                              Oh i think this would solve my problem with this
                              https://developers.maxon.net/forum/topic/6903/7745_eventadd-doesnt-update-c4d
                              Not the topic the solution from NiklasR, but The Python c4d file is 404 missing, here.
                              Anyhow does somebody have a multiple objects boundingbox Python Script Snippet?
                              Kind regards
                              mogh
