    GetContour() refresh or uncache? How?
    21 Posts 0 Posters 18.9k Views
      On 03/02/2012 at 08:00, xxxxxxxx wrote:
      Any news? Still waiting ...
      maxx
        On 03/02/2012 at 08:44, xxxxxxxx wrote:
        Hi maxx,
        this seems to work well. However, it is not really satisfying using that hack..
        http://www.file-upload.net/download-4083773/GetContour.zip.html
        Cheers, Niklas!
          On 04/02/2012 at 09:09, xxxxxxxx wrote:
          Hi maxx,
          Cheers, Niklas!
          Hy nux, thanx for Code. But as you say, its not really satisfying. As tcastudios wrote, doing this will have severe performance drawbacks ...
          André
            On 04/04/2012 at 05:41, xxxxxxxx wrote:
            So we have reason to believe that there is no Cache to release for GetContour()
            in a similar manner as one can do with GetVirtualObjects() by not returning
            a HierarchyHelp ?
            Lennart
              On 04/04/2012 at 07:23, xxxxxxxx wrote:
              I contacted the developers on this issue.
                On 04/04/2012 at 08:47, xxxxxxxx wrote:
                Great, thanks Yannick.
                Lennart
                  On 10/04/2012 at 07:27, xxxxxxxx wrote:
                  Here's the information I got from the developers.
                  Splines created though GetContour() are cached. To make this frame dependent CheckDirty() can be overloaded to set the object dirty if a certain condition has changed:
                  class TestSplineData(plugins.ObjectData) :
                      def __init__(self) :
                          self.lastFrame = doc.GetTime().GetFrame(doc.GetFps())
                      def CheckDirty(self, op, doc) :
                          print "CheckDirty()"
                          frame = doc.GetTime().GetFrame(doc.GetFps())
                          if frame != self.lastFrame:
                              self.lastFrame = frame
                              op.SetDirty(c4d.DIRTYFLAGS_DATA)
                      def GetContour(self, op, doc, lod, bt) :
                          print "GetContour()"
                          return c4d.BaseObject(c4d.Ospline)
                  This should only be done if absolutely necessary though, otherwise the spline (and all depending objects) will be rebuilt for every single view-redraw.
                    On 10/04/2012 at 08:13, xxxxxxxx wrote:
                    Thank you very much,Yannick! That is a big step in the right direction.
                    I will try to get all In/Excl objects within the CheckDirty() because that is
                    the "core" issue I have. The generator should update on the list's object's
                    dirty status.
                    I'll report how a get (or don't get! it working.
                    Lennart
                      On 10/04/2012 at 10:46, xxxxxxxx wrote:
                      YES YES! I'm so happy that this is solved, thanks a lot.
                      I've posted the important parts of one plugin I'm working with.
                      It needs to get dirty info from objects in a In/Excl List so I
                      simply could loop them and check the sum against the stored dirty sum.
                      Then to bypass the potential problems using GetActiveDocument() (for not active document)
                      I simply treat the current frame as a dirty (Long) value and include it in
                      the dirty sum!
                      Could not be happier!
                      Lennart
                      splineGLIDE
                      Copyright: tcastudios 2012
                      Written for CINEMA 4D R13.+
                      Modified Date: 2012xxxx
                      import os
                      import webbrowser as w
                      from c4d import plugins, utils as u, bitmaps, Vector as v, documents
                      from c4d.utils import SplineHelp, SplineLengthData
                      PLUGIN_ID = 1028358 # PLUGIN ID registered by tcastudios. IF YOU MAKE ANY EDITS YOU MUST GET A NEW PLUGIN ID FROM plugincafe.com!!
                      DIRTYSUM = 1027373 # Unique ID from plugincafe.com registered by tcastudios.com (PCLUSTER_MEMO)
                      class sGLIDE(plugins.ObjectData) :
                           """splineGLIDE Generator"""
                           def Init(self, sglide) :
                                data = sglide.GetDataInstance()
                                data.SetReal(c4d.SG_MIX,1.0) # Mix Float
                                data.Set etc……
                           def CheckDirty(self,op,doc) :
                                obc        = op.GetDataInstance()
                                dirtysumbc = obc.GetContainer(DIRTYSUM)
                                dlist      = obc.GetData(c4d.SG_SOURCES) #InExclude List objects to get dirty from
                                lcount     = dlist.GetObjectCount()
                                checksum = doc.GetTime().GetFrame(doc.GetFps()) # Use frame as a dirty integer (Long)
                                for d in xrange(lcount) :
                                     checksum += dlist.ObjectFromIndex(None ,d ).GetDirty(c4d.DIRTY_DATA|c4d.DIRTY_MATRIX |c4d.DIRTY_CHILDREN|c4d.DIRTY_CACHE|c4d.DIRTY_SELECT)
                                if (checksum != dirtysumbc.GetLLong(0)) :
                                     dirtysumbc.SetLLong(0,checksum)
                                     obc.SetData(DIRTYSUM,dirtysumbc)        # Store new checksum into Container
                           def Construct(self,sglide) :
                                sbc        = sglide.GetDataInstance()
                                myfader    = sbc.GetReal(c4d.SG_MIX)
                                myetc      = sbc.Get etc etc
                                myspline   =
                                myspline   = c4d.BaseObject(c4d.Ospline)
                                # code that do things with spline from In/Excl List objects
                                return     myspline
                           def GetContour(self, sglide, doc, lod, bt) :
                                return self.Construct(sglide)
                          path, file = os.path.split(__file__)
                          bmp = bitmaps.BaseBitmap()
                          bmp.InitWith(os.path.join(path, "res", "splineGLIDE.tif"))
                          splineGLIDELoaded = plugins.RegisterObjectPlugin(id=PLUGIN_ID,
                                          str="splineGLIDE",
                                                      g=sGLIDE,
                                                      description="splineGLIDE",
                                                      icon=bmp,
                                                      info=c4d.OBJECT_GENERATOR | c4d.OBJECT_ISSPLINE )
                          if splineGLIDELoaded:
                              print 'splineGLIDE v1 Loaded'
                      edit: Don't need to set checksum again for the op.
                        On 06/09/2012 at 09:37, xxxxxxxx wrote:
                        I've been struggling with this in C++ just a few seconds ago. I'm so happy I remembered this thread. 🙂
                        I couldn't find this information in the C++ docs as well. Especially because CheckDirty() is listed under methods for Modifier objects, it didn't appear to me that I need to override this method.
                        -NIklas
