    Basic PyGenerator plugin Please
    26 Posts 0 Posters 22.2k Views
      On 16/10/2011 at 09:43, xxxxxxxx wrote:
      Maybe I need to be even more clear 🙂
      Make a PyGenerator generating a spline.
      ie return c4d.BaseObject(c4d.Osplinecircle)
      Then put the PyGenerator in a Cloner as Object source
      does not allow me to clone stuff on the PyGenerator
      as the Cloner does not see the PyGenerator as a spline.
      Put the PyDoubleCircle in the Cloner instead as Object source
      and I can clone.
      The issue really comes down to that I can't see what in
      the PyDoubleCircle example that makes it work.
      (Other than it's using GetContour() )
        On 16/10/2011 at 10:22, xxxxxxxx wrote:
        seems it's not possible, if only add optionally new functions as presenting of PyGen like splineObj...like checkbox with GetContour dependecy
          On 16/10/2011 at 18:42, xxxxxxxx wrote:
          Update. I've actually got it working (as a plugin), stripping down the
          PyDoubleCircle example bit by bit..
          I'll post the barebone working code this week with a new question
          as it became a new issue how handle updating it.
          My guess it's about GetCache(), Get/SetDirty(), all new
          territory for me.
          Thanks till later!
          Lennart
            On 24/10/2011 at 07:59, xxxxxxxx wrote:
            Hello
            There is interesting and unstable(need to glue to matrix of obj) test
            http://imageshack.us/photo/my-images/153/cstotest.jpg/
              On 24/10/2011 at 09:04, xxxxxxxx wrote:
              That's a good twist, adding the Cloner link via the script, nice.
              Don't need to do the CSTO either really.
              Lennart
                You're right! Thanks a'lot.
                I played with M.Zabiegly's pointcloud's sample(big thanks to his xpresso tutorials), trying to get cache from procedural objects(Lennart, i make same 3d fashion sample as you did) and try to apply same CSTO.
                For CSTO and additional py-snippets i want to say Thanks to Sebastien, Niklas, Scott...
                  On 26/10/2011 at 08:40, xxxxxxxx wrote:
                  I have question is this function replicate GetContour() - BaseObject.GetRealSpline ?
                    On 26/10/2011 at 11:14, xxxxxxxx wrote:
                    Not really I'm afraid.
                    But I've come a long way linking Cloners, MoSplines etc
                    from within the plugin as per the example you show earlier.
                    This way basically any virtual object within the generator
                    can be picked.
                      On 18/11/2011 at 09:20, xxxxxxxx wrote:
                      Also try Nux95's DrawApi helpers, thanks a'lot to Niklas!
                      Niklas, can you make sample with DrawLines if it-s possible, i some ago apply at sample project...but lost it....
                      I'm sorry, haven't ever read this post before. 😊
                      Can you explain more what 'ya need ?
                      PS: My latest achievement in the DrawApi module. (Animations) 😉
                      http://www.screenr.com/mQLs
                        On 19/11/2011 at 23:44, xxxxxxxx wrote:
                        Hallo
                        I mean your previous work as Python Draw Helper(sample with bd, draw polygon triangle with coloring)
                        your GUI development is wonderful!!!!
                          On 20/11/2011 at 02:20, xxxxxxxx wrote:
                          Ah I thought you were talking about 2d GUI, thats why I postet the video. 😂
                          Thanks !
                          And what was your problem, now ? ^^
                            On 21/11/2011 at 10:51, xxxxxxxx wrote:
                            thanks, i have not any, pass it 😉 or return TRUE
                              On 22/11/2011 at 03:59, xxxxxxxx wrote:
                              Why not try the Py-DoubleCircle example from the Python SDK?
                                On 22/11/2011 at 05:42, xxxxxxxx wrote:
                                Hi Jack. That's what I did. But the issue turned out to be the cache.
                                As it only refresh itself internally and not from changes of external input.
                                I started another thread about that but it's not totally solved other than the workarounds mentioned there (link from within the script/code)
                                https://developers.maxon.net/forum/topic/6070/6249_getcontour-refresh-or-uncache-how
                                Lennart
                                  On 22/11/2011 at 18:33, xxxxxxxx wrote:
                                  Oh, sorry. I just see in your initial posting that you did that.
                                  I should read more carefully.
