    Basic PyGenerator plugin Please
    26 Posts 0 Posters 21.4k Views
      On 13/10/2011 at 22:09, xxxxxxxx wrote:
      The Python Generator object evaluates the code within c4d.plugins.ObjectData.GetVirtualObjects().
      You just have to copy paste your code from the Python Generator to your Python Plugin, as if the GetVirtualObjects() Method was your main function.
      from c4d.plugins import ObjectData
      class MyObjectPlugin(ObjectData) :
        def GetVirtualObjects(self, op, hh) :
            " Overrides c4d.plugins.ObjectData.GetVirtualObjects() "
            # paste your code here for example:
            return c4d.BaseObject(c4d.Ocube)
        On 14/10/2011 at 17:12, xxxxxxxx wrote:
        Hm.
        I can use GetVirtualObjects() and I now get a visible object.
        If I create a BaseObject like Ocube it is recognized by ie a Cloner.
        How ever if a create a Osplineobject or SplineObject (and set
        it's points where I want them) I also get a visible object, -but-
        it is not seen as a spline by a Cloner or an AlignToSpline Tag.
        It -is- recognized by a SweepNurb.
        Running MakeEditable or CurrentStateToObject I do get the correct
        spline in return.
        ok, so looking at the Py_DoubleCircle example it does not
        use GetVirtualObjects() but GetContour() instead.
        And it is seen by Cloner etc.
        But what is it in that example that makes that happen?
        When I use my "functional" spline code I don't get any errors
        but no spline is generated. Doing MakeEditable I get
        a Null Object in return.
        What is it in GetContour that is important?
        My plugin is based on the Py example and all I do
        is create a simple spline with no settings at all,
        no Draw, Handles or anything.
          On 14/10/2011 at 17:18, xxxxxxxx wrote:
          Oh, the reason why I'm trying the Object Plugin way
          is that the setup is running using the Python Generator Object
          and it has the same issue that a returned spline is not seen
          by Cloners, AlignToSpline etc.
            On 15/10/2011 at 10:20, xxxxxxxx wrote:
            is it?
            put in PyGenerator and make editable
              spl = c4d.SplineObject(2,0)
              spl.SetPoint(0,c4d.Vector(0.0))
              spl.SetPoint(1,c4d.Vector(0.0,1000.0,0.0,))
              spl.Message(c4d.MSG_UPDATE)
              return spl
              On 15/10/2011 at 14:52, xxxxxxxx wrote:
              Hi Ilya.
              I need to have the PyGenerator seen as a spline by a Cloner etc.
              -without- making it editable the same way as a cube generated
              in the PyGenerator is seen by a Cloner.
              The PyDoubleCircle example manage that and I can't figure out why.
                On 15/10/2011 at 16:22, xxxxxxxx wrote:
                In C++. We need to use the " virtual SplineObject* GetContour() " method. As part of the class.
                If it's left out. The spline does not even draw.
                This does not seem to be the case in python.
                Per the C++ SDK. GetContour() is used for generating splines.
                AFAIK. It's not needed to generate other types of objects.
                This is just a wild guess.
                But it looks like the way the python version is ported from C++ is allowing us to generate splines in python without using GetContour(). Which might be a bad practice.
                My guess is that this is not the  "proper"  way to build a spline generator.  And will cause things like the Align-to-Spline tag not to work with it.
                This is just a wild guess based on my experience with it in C++.
                  On 16/10/2011 at 02:56, xxxxxxxx wrote:
                  Hello Lennart
                  I try to put spl-pygen object, clonner draw it normally, without returning of base object(make editable) as described.
                  At more complex code, pyGen was failed at drawing of object if it is in clonner/or mo-object.
                  Also try Nux95's DrawApi helpers, thanks a'lot to Niklas!
                  Niklas, can you make sample with DrawLines if it-s possible, i some ago apply at sample project...but lost it....
                    On 16/10/2011 at 09:43, xxxxxxxx wrote:
                    Maybe I need to be even more clear 🙂
                    Make a PyGenerator generating a spline.
                    ie return c4d.BaseObject(c4d.Osplinecircle)
                    Then put the PyGenerator in a Cloner as Object source
                    does not allow me to clone stuff on the PyGenerator
                    as the Cloner does not see the PyGenerator as a spline.
                    Put the PyDoubleCircle in the Cloner instead as Object source
                    and I can clone.
                    The issue really comes down to that I can't see what in
                    the PyDoubleCircle example that makes it work.
                    (Other than it's using GetContour() )
                      On 16/10/2011 at 10:22, xxxxxxxx wrote:
                      seems it's not possible, if only add optionally new functions as presenting of PyGen like splineObj...like checkbox with GetContour dependecy
                        On 16/10/2011 at 18:42, xxxxxxxx wrote:
                        Update. I've actually got it working (as a plugin), stripping down the
                        PyDoubleCircle example bit by bit..
                        I'll post the barebone working code this week with a new question
                        as it became a new issue how handle updating it.
                        My guess it's about GetCache(), Get/SetDirty(), all new
                        territory for me.
                        Thanks till later!
                        Lennart
                          On 24/10/2011 at 07:59, xxxxxxxx wrote:
                          Hello
                          There is interesting and unstable(need to glue to matrix of obj) test
                          http://imageshack.us/photo/my-images/153/cstotest.jpg/
                            On 24/10/2011 at 09:04, xxxxxxxx wrote:
                            That's a good twist, adding the Cloner link via the script, nice.
                            Don't need to do the CSTO either really.
                            Lennart
                              You're right! Thanks a'lot.
                              I played with M.Zabiegly's pointcloud's sample(big thanks to his xpresso tutorials), trying to get cache from procedural objects(Lennart, i make same 3d fashion sample as you did) and try to apply same CSTO.
                              For CSTO and additional py-snippets i want to say Thanks to Sebastien, Niklas, Scott...
                                On 26/10/2011 at 08:40, xxxxxxxx wrote:
                                I have question is this function replicate GetContour() - BaseObject.GetRealSpline ?
                                  On 26/10/2011 at 11:14, xxxxxxxx wrote:
                                  Not really I'm afraid.
                                  But I've come a long way linking Cloners, MoSplines etc
                                  from within the plugin as per the example you show earlier.
                                  This way basically any virtual object within the generator
                                  can be picked.
                                    I'm sorry, haven't ever read this post before. 😊
                                    Can you explain more what 'ya need ?
                                    PS: My latest achievement in the DrawApi module. (Animations) 😉
                                    http://www.screenr.com/mQLs
                                      On 19/11/2011 at 23:44, xxxxxxxx wrote:
                                      Hallo
                                      I mean your previous work as Python Draw Helper(sample with bd, draw polygon triangle with coloring)
                                      your GUI development is wonderful!!!!
                                        On 20/11/2011 at 02:20, xxxxxxxx wrote:
                                        Ah I thought you were talking about 2d GUI, thats why I postet the video. 😂
                                        Thanks !
                                        And what was your problem, now ? ^^
                                          On 21/11/2011 at 10:51, xxxxxxxx wrote:
                                          thanks, i have not any, pass it 😉 or return TRUE
                                            On 22/11/2011 at 03:59, xxxxxxxx wrote:
                                            Why not try the Py-DoubleCircle example from the Python SDK?
