    Activate Camera -A very simple question for a noob
    32 Posts 0 Posters 21.4k Views
      On 29/08/2011 at 02:01, xxxxxxxx wrote:
      1. How about doing it the other wey round ? Instead of loading the Scene to the Preset, load the Preset to the scene. (That was actually my intention with the naming of the variables).
      2. op[c4d.ID_USERDATA, id] # id: the id of the userdata entry
        On 29/08/2011 at 08:02, xxxxxxxx wrote:
        Here's how to Merge a .c4d file:
        import c4d, os
        from c4d import documents
          fn = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP) #Gets the desktop path
          path = os.path.join(fn,'MyFile.c4d')                #The actual .c4d file
          merge = documents.MergeDocument(doc, path, 1)
        Look up the other paths (C4D_PATH_DESKTOP, etc...)  you can use in the docs.
          On 29/08/2011 at 17:26, xxxxxxxx wrote:
          import c4d, os
          Thanks Scott, will try that asap. Ill let you know how i go.
          One thing I am still struggling with is how to setup that for loop with the user data. Like where do i need to specify the ID. and where do i put 'i' for an integer list type user data setup.
          Basically at the moment the user data integer list is set up so ...
          0=perspec using nux's little python script tag. (Thanks mate!)
          1=cam 1
          2=cam 2
          3=cam 3 etc...
          can you specify a for loop where i is between a range say 1-5 for example?
          I know Python integration is fairly new to c4d, but I am amazing how little true code examples there are on the net. Who can understand reading an SDK. Half of it isnt even in context. Just raw comands. And it's so brutal when it comes to debugging that somelike me has no chance to find what is wrong with the code.
          One thing i can say is how surprised I am of the support you guys have given me already. I know you think im lazy for asking for code, but I guess i learn faster with examples. And reverse engineering code rather than inventing it.
          Thanks all. 😄
            On 29/08/2011 at 19:21, xxxxxxxx wrote:
            Note: Using xrange() is more efficient and should always be used when you do not require a list.
            Edit: Made layout more nice. 🙂
              import c4d, os
              That worked and makes sense thank you.
              NUX; i'm going to attempt this for loop thing now from the documentation you posted. Will let you know when i fail...😂.
              Has anyone ever got Python to save the entire project including scene file and tex folder? 'Render Elements' does it, so i asked the creator how he did it and he said that there was no easy way. He had to gather all the information in the scene and collect files manually with his code. He basically rewrote the save project command in c4d. It was his understanding that saving a project could not be scriptable because it promts the user every time for a save path, meaning its useless for long loops etc. I would like my script to 'for loop' the scene x amount of times changing a user data entry each time, then save the entire project to it's own folder with it's name also being driven by a user data string variable.
              Saving a project through Python seems to be the next hurdle for me now.
              Thanks!
                Your image files are not allowed aparently. What layout are you refering to?
                  On 29/08/2011 at 21:06, xxxxxxxx wrote:
                  You cannot see the images ? 😢
                  Ehm, layout ? Do you mean websites ?
                  Actually, theese are the links:
                  Python Docs: http://docs.python.org/index.html
                  Xrange function: http://docs.python.org/library/functions.html?highlight=xrange#xrange
                  Range function: http://docs.python.org/tutorial/controlflow.html#the-range-function
                  for statement: http://docs.python.org/tutorial/controlflow.html#for-statements
                  Edit: Using the SaveDocument function works just fine and no dialog appears.
                  from c4d.documents import SaveDocument
                    SaveDocument(doc, 'C:\\foo.c4d', 1, c4d.FORMAT_C4DEXPORT)
                  You just have to make sure that the file-path is absolute, not relative.
                    Yeah mate I've got my head around that function now which is great.
                    However from the SDK there doesnt seem to be an option/flag to make it a 'SAVE PROJECT' function where the entire project folder is saved INCLUDING tex folder, GI files etc.
                    So I want to iterate the same function as when the user goes File/Save Project...
                    not sure if i made sense.
                      On 29/08/2011 at 21:58, xxxxxxxx wrote:
                      Is there something more than textures and GI files ?
                      Copying the GI files and textures is no problem. It does also seem like cinema 4d does recognize when textures are suddenly relative and no more absolute.
                      Use this function to save as a project, It should work jsut fine.
                      import  c4d
                      from    os.path         import abspath, dirname, split, join, exists, basename, isabs
                      from    os              import makedirs, mkdir
                      from    shutil          import copytree, copy
                      def SaveProject(doc, path) :
                        pah         = abspath(path)
                        ndir_, name = split(path)
                        ndir_       = join(ndir_, name[:name.rfind('.')])
                        if not exists(ndir_) :
                            makedirs(ndir_)
                        new_illum   = join(ndir_, 'illum')
                        new_tex     = join(ndir_, 'tex')
                        dir_    = doc.GetDocumentPath()
                        if dir_:
                            illum   = join(dir_, 'illum')
                            if exists(illum) :
                                copytree(illum, new_illum)
                            tex     = join(dir_, 'tex')
                            if exists(tex) :
                                copytree(tex, new_tex)
                        for i, texture in doc.GetAllTextures() :
                            if not isabs(texture) : continue
                            copy(texture, join(new_tex, basename(texture)))
                        SaveDocument(doc, join(ndir_, name), 0, c4d.FORMAT_C4DEXPORT)
                      # example:
                      SaveProject(doc, 'C:\\foo.c4d')
                        On 29/08/2011 at 22:44, xxxxxxxx wrote:
                        Absolute genius Nux, and that was quick too! You saved me ages! 🍺
                        Im sure a lot of readers will find this particularly useful too!
                        Thanks mate.
                        PS. does the \\ in the filename denote multiplatform? Would this work on a mac for instance? Thanks again.
                          On 29/08/2011 at 23:32, xxxxxxxx wrote:
                          Here is something interesting. For some reason this doesnt bring in my one material for the 3Dcam.c4d scene. It is definately there in the file. I've tried flags but it doesnt make a difference...mmm
                          import c4d, os
                            path = os.path.join(fn,'3Dcam.c4d')                #The actual .c4d file
                            merge = documents.MergeDocument(doc, path, 1 )
                          EDIT: Wait, replacing the merge = documents.MergeDocument(doc, path, 1 ) to  merge = documents.MergeDocument(doc, path, 3 )seemed to work. 🙂
                            The backslash is a character indicating a special character in a string on almost any programmin language. Using \\ defines a simple \. Using \n defines a newline, a tab, etc..
                            You should use IDs instead of numbers, but i couldn't find that numer to be a 'SCENEFILETER_XX' ID. Sounds weird. May you check the function with the IDs to see which one does work for you ? See the documentation for the IDs under MergeDocument. Thanks. 😉
                            Np 😉
                              On 30/08/2011 at 07:50, xxxxxxxx wrote:
                              Read this thread about escape characters:https://developers.maxon.net/forum/topic/5838/5896_saving-files-without-the-file-browser
                              Mac's and PC's use different escapes.
                              That might be the reason why the guy who made render elements was having troubles.
                                [/QUOTE
                                ah i see. thanks dude.
                                PS. I am trying this code to simply change the viewport resolution, not working...mmm
                                 renderData = document.GetActiveRenderData()
                                 renderData[c4d.RDATA_XRES] = 1024
                                 renderData[c4d.RDATA_YRES] = 576
                                 document.SetActiveRenderData(renderData)
                                thanks
                                  On 30/08/2011 at 20:55, xxxxxxxx wrote:
                                  I recall reading another thread where someone was also having problems with it.
                                  I can't remember if he was a mac user or not.
                                  It's never given me any trouble on the PC platform:
                                    renderData = doc.GetActiveRenderData()
                                    renderData[c4d.RDATA_XRES] = 200
                                    renderData[c4d.RDATA_YRES] = 200
                                  Works fine for me.
                                    On 30/08/2011 at 23:02, xxxxxxxx wrote:
                                    Yeah spot on Scott, cheers.
                                    So if i want to change the render savefilename or multipass filename based upon a user data variable, is this a similar procedure? Does this apply to document scale as well. I want to know how i can change the document scale to cm before i import my file with the script.
                                    Cheers. Its coming together.
                                      On 30/08/2011 at 23:31, xxxxxxxx wrote:
                                      k, scratch most of that. Im mostly stuggling to find what class controls the document scale/fps etc.
                                      EDIT: Looking though the Base.Document reveals other things like min time, preview time FPS etc but no document scale (cm/mm) etc...
                                        On 31/08/2011 at 02:15, xxxxxxxx wrote:
                                        Ok guys, so i am writing a script using your code which basically puts a multi-cam project to a renderfarm with one click. IT makes x number project folders with each c4d containing different active cameras (using Xpresso).
                                        I am just getting into the loop part to change the selected camera BEFORE it calls the SaveProject() function which Nux was so kind to provide. The script at the moment creates the folders correctly, but it is not changing the user data which in turn should be changing the active camera. I am sure its a simple syntax error and the way im getting the user data. Help? The User data ID which controls the selected camera is #17.
                                        Thanks. PS. once this is sorted id like to be able to get the filename and renderfarm path dynamically from a string/dir user data. This is easy i suspect once someone clues me in on how i have skrewed up the currect code...
                                        Thanks guys.
                                        import  c4d
                                        from    c4d.documents   import LoadDocument, SaveDocument, GetActiveDocument, InsertBaseDocument
                                          pah         = abspath(path)
                                              makedirs(ndir_)
                                          if dir_:
                                              if exists(illum) :
                                              if exists(tex) :
                                        # example:
                                        #SaveProject(doc, 'C:\\foo.c4d')
                                        def SaveLoop() :
                                          doc          = GetActiveDocument()
                                          selectedcam  = op[c4d.ID_USERDATA, 17] # id: the id of the userdata entry
                                          for i in xrange(8) :
                                              # ... Change whatever you want
                                              selectedcam = i
                                              SaveProject(doc, r'D:\Scene_cam0' + str(i) + '.c4d')
                                        SaveLoop()
                                          On 31/08/2011 at 03:25, xxxxxxxx wrote:
                                          You missunderstood how getting and setting of data and variable works.
                                          This doesn't assign the actual userdata entry to 'selectedcam', it does assign it's value.
                                            op[c4d.ID_USERDATA, 17] = i
                                          is the right code.
                                          Again, I recommend you to read the tutorial in the documentation. It's a fundamental base for the knowledge you need for programming.
                                            On 31/08/2011 at 04:11, xxxxxxxx wrote:
                                            Ok . Thanks anyway for all your help along the way.
