    Activate Camera -A very simple question for a noob
    32 Posts 0 Posters 18.9k Views
      On 29/08/2011 at 23:32, xxxxxxxx wrote:
      Here is something interesting. For some reason this doesnt bring in my one material for the 3Dcam.c4d scene. It is definately there in the file. I've tried flags but it doesnt make a difference...mmm
      import c4d, os
      from c4d import documents
        fn = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP) #Gets the desktop path
        path = os.path.join(fn,'3Dcam.c4d')                #The actual .c4d file
        merge = documents.MergeDocument(doc, path, 1 )
      EDIT: Wait, replacing the merge = documents.MergeDocument(doc, path, 1 ) to  merge = documents.MergeDocument(doc, path, 3 )seemed to work. 🙂
        On 30/08/2011 at 06:26, xxxxxxxx wrote:
        PS. does the \\ in the filename denote multiplatform? Would this work on a mac for instance? Thanks again.
        The backslash is a character indicating a special character in a string on almost any programmin language. Using \\ defines a simple \. Using \n defines a newline, a tab, etc..
        You should use IDs instead of numbers, but i couldn't find that numer to be a 'SCENEFILETER_XX' ID. Sounds weird. May you check the function with the IDs to see which one does work for you ? See the documentation for the IDs under MergeDocument. Thanks. 😉
        Np 😉
          On 30/08/2011 at 07:50, xxxxxxxx wrote:
          Read this thread about escape characters:https://developers.maxon.net/forum/topic/5838/5896_saving-files-without-the-file-browser
          Mac's and PC's use different escapes.
          That might be the reason why the guy who made render elements was having troubles.
            [/QUOTE
            ah i see. thanks dude.
            PS. I am trying this code to simply change the viewport resolution, not working...mmm
             renderData = document.GetActiveRenderData()
             renderData[c4d.RDATA_XRES] = 1024
             renderData[c4d.RDATA_YRES] = 576
             document.SetActiveRenderData(renderData)
            thanks
              On 30/08/2011 at 20:55, xxxxxxxx wrote:
              I recall reading another thread where someone was also having problems with it.
              I can't remember if he was a mac user or not.
              It's never given me any trouble on the PC platform:
                renderData = doc.GetActiveRenderData()
                renderData[c4d.RDATA_XRES] = 200
                renderData[c4d.RDATA_YRES] = 200
              Works fine for me.
                On 30/08/2011 at 23:02, xxxxxxxx wrote:
                Yeah spot on Scott, cheers.
                So if i want to change the render savefilename or multipass filename based upon a user data variable, is this a similar procedure? Does this apply to document scale as well. I want to know how i can change the document scale to cm before i import my file with the script.
                Cheers. Its coming together.
                  On 30/08/2011 at 23:31, xxxxxxxx wrote:
                  k, scratch most of that. Im mostly stuggling to find what class controls the document scale/fps etc.
                  EDIT: Looking though the Base.Document reveals other things like min time, preview time FPS etc but no document scale (cm/mm) etc...
                    On 31/08/2011 at 02:15, xxxxxxxx wrote:
                    Ok guys, so i am writing a script using your code which basically puts a multi-cam project to a renderfarm with one click. IT makes x number project folders with each c4d containing different active cameras (using Xpresso).
                    I am just getting into the loop part to change the selected camera BEFORE it calls the SaveProject() function which Nux was so kind to provide. The script at the moment creates the folders correctly, but it is not changing the user data which in turn should be changing the active camera. I am sure its a simple syntax error and the way im getting the user data. Help? The User data ID which controls the selected camera is #17.
                    Thanks. PS. once this is sorted id like to be able to get the filename and renderfarm path dynamically from a string/dir user data. This is easy i suspect once someone clues me in on how i have skrewed up the currect code...
                    Thanks guys.
                    import  c4d
                    from    c4d.documents   import LoadDocument, SaveDocument, GetActiveDocument, InsertBaseDocument
                    from    os.path         import abspath, dirname, split, join, exists, basename, isabs
                    from    os              import makedirs, mkdir
                    from    shutil          import copytree, copy
                    def SaveProject(doc, path) :
                      pah         = abspath(path)
                      ndir_, name = split(path)
                      ndir_       = join(ndir_, name[:name.rfind('.')])
                      if not exists(ndir_) :
                          makedirs(ndir_)
                      new_illum   = join(ndir_, 'illum')
                      new_tex     = join(ndir_, 'tex')
                      dir_    = doc.GetDocumentPath()
                      if dir_:
                          illum   = join(dir_, 'illum')
                          if exists(illum) :
                              copytree(illum, new_illum)
                          tex     = join(dir_, 'tex')
                          if exists(tex) :
                              copytree(tex, new_tex)
                      for i, texture in doc.GetAllTextures() :
                          if not isabs(texture) : continue
                          copy(texture, join(new_tex, basename(texture)))
                      SaveDocument(doc, join(ndir_, name), 0, c4d.FORMAT_C4DEXPORT)
                    # example:
                    #SaveProject(doc, 'C:\\foo.c4d')
                    def SaveLoop() :
                      doc          = GetActiveDocument()
                      selectedcam  = op[c4d.ID_USERDATA, 17] # id: the id of the userdata entry
                      for i in xrange(8) :
                          # ... Change whatever you want
                          selectedcam = i
                          SaveProject(doc, r'D:\Scene_cam0' + str(i) + '.c4d')
                    SaveLoop()
                      On 31/08/2011 at 03:25, xxxxxxxx wrote:
                      You missunderstood how getting and setting of data and variable works.
                      This doesn't assign the actual userdata entry to 'selectedcam', it does assign it's value.
                        op[c4d.ID_USERDATA, 17] = i
                      is the right code.
                      Again, I recommend you to read the tutorial in the documentation. It's a fundamental base for the knowledge you need for programming.
                        On 31/08/2011 at 04:11, xxxxxxxx wrote:
                        Ok . Thanks anyway for all your help along the way.
