    Noise Functions
    33 Posts 0 Posters 17.6k Views
      On 05/06/2010 at 12:04, xxxxxxxx wrote:
      hmm. still getting some pretty funky results..   could it be because I am looping through all of the points and effecting each individual point?  is it possible to compare the result of a variable in one cycle of a loop to the result in the last cycle of a loop?
      ~Shawn
        On 05/06/2010 at 12:13, xxxxxxxx wrote:
        I assume I'll need a global variable for that..   do you think it would be more effective to catch the location of the last point that was modified in the global variable  and use that to adjust the position of the next point. make the mix function mix the distance between the last point and the current point?
        something like that?
        ~Shawn
          On 05/06/2010 at 12:14, xxxxxxxx wrote:
          you could try to use some smaller value for the noise functions. for example point _/100.. and see what happens. i'd use a slider for this value than, too...
            On 05/06/2010 at 12:21, xxxxxxxx wrote:
            ha, you are just too fast for my replies. however, i wouldnt care for that.. you have your base form and apply just some values to each point, so the form still stays similar to your original mesh. maybe you dont use a cube as a base, but a sphere with low polycount? maybe you apply some scale vector additionally so the object doesnt look so round anymore
              On 05/06/2010 at 12:22, xxxxxxxx wrote:
              well smaller numbers definitely help but still don't quite give me what I'm looking for.  I think I might need to compare the current point position with the last point position..     Maybe.,.    LOL
                On 05/06/2010 at 12:23, xxxxxxxx wrote:
                lol...   sorry I replied before you had a chance to again.  HAHA
                  On 05/06/2010 at 12:30, xxxxxxxx wrote:
                  if you use Mix with keeping more to your original point, say values between 0.5 and 1 for t, you should be able to get exactly that (in theory of course, since i'm not actually trying atm)
                    On 05/06/2010 at 12:37, xxxxxxxx wrote:
                    LOL..  yep you're right...   it worked/./   just had to do a little tweaking with the numbers..  Thanks a lot for your help ello.    I really appreciate you taking the time to help me.
                    ~Shawn
                      On 05/06/2010 at 12:39, xxxxxxxx wrote:
                      glad i am able sometimes 🙂
                        On 05/06/2010 at 12:45, xxxxxxxx wrote:
                        Hey while you're here do you know if it is safe to subdivide an object from within the GetVirtualObjects() method?
                        ~Shawn
                          On 05/06/2010 at 12:53, xxxxxxxx wrote:
                          i place my object inside  a hypernurbs (Osds) to do so, but i think you mean something other. it should be able by using CommandData
                          here is a snippet of how i used the optimize command on a polygon object.
                                if (op->GetType()==Opolygon)
                                    ModelingCommandData cd;
                                    cd.doc = doc;
                                    cd.op = op;
                                    BaseContainer bc;
                                    bc.SetReal(MDATA_OPTIMIZE_TOLERANCE, tolerance);
                                    bc.SetReal(MDATA_OPTIMIZE_POINTS, TRUE);
                                    bc.SetReal(MDATA_OPTIMIZE_POLYGONS, TRUE);
                                    bc.SetReal(MDATA_OPTIMIZE_UNUSEDPOINTS, TRUE);
                                    cd.bc = &bc;
                                    if(SendModelingCommand(MCOMMAND_OPTIMIZE, cd))
                                        cd.op->Message(MSG_UPDATE, NULL);
                                        BaseTag *phongTag = op->MakeTag(Tphong);
                                        BaseContainer *bc = phongTag->GetDataInstance();
                                        bc->SetBool(PHONGTAG_PHONG_ANGLELIMIT,TRUE);
                                        bc->SetReal(PHONGTAG_PHONG_ANGLE,ToRad(winkel));
                                    } else {
                                         GePrint("failed");
                          hope this makes sense 🙂
                          edit: in your case it'd be the MCOMMAND_SUBDIVIDE .. check the sdk for its parameters...
                            On 05/06/2010 at 12:59, xxxxxxxx wrote:
                            I was doing something simliar with
                            MCOMMAND_SUBDIVIDE_<_h4_>_
                            but for some reason it keeps crashiung on me when I try to do it.
                              On 05/06/2010 at 13:01, xxxxxxxx wrote:
                              hm.. did you set the parameters? i guess its some trial and error now, since i dont know why it crashes.
                                On 05/06/2010 at 13:03, xxxxxxxx wrote:
                                this is how I am attempting to subdivide
                                but it keeps crashing
                                		if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE))  //If HyperNURBS is checked
                                		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
                                		else
                                		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE);
                                		mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
                                	    mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE));
                                	//Subdivision Command
                                	SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
                                  On 05/06/2010 at 13:04, xxxxxxxx wrote:
                                  MAX_ANGLE is equal to pi   and subAMount is a real that the user can adjust.   🙂
                                    On 05/06/2010 at 13:11, xxxxxxxx wrote:
                                    try catching the crash with
                                    if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat))
                                    GePrint("done");
                                    else
                                    GePrint("failed");
                                    just to be on the safe side..
                                      On 05/06/2010 at 13:44, xxxxxxxx wrote:
                                      Here's my subdivision code now...
                                      Still crashing.
                                      //SUBDIVISION
                                      		Real subAmount;
                                      		subAmount = mcd2.bc->GetLong(SPACEROCK_SUBDIVISIONS);
                                      		mcd2.mode = MODIFY_ALL;
                                      		mcd2.doc = hh->GetDocument();
                                      		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
                                      			GePrint("done");
                                      			mcd2.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
                                      			mcd2.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
                                      			mcd2.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
                                      			SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2);
                                      		else
                                      			GePrint("failed");
                                      Any thoughts?
                                        On 05/06/2010 at 13:55, xxxxxxxx wrote:
                                        hey, dont call SendModelingCommand twice.. its already called in the if condition!
                                          On 05/06/2010 at 14:06, xxxxxxxx wrote:
                                          well.. that was a good thought and a good catch but unfortunately it's still crashing .. this one is a bit of a thorn today.  LOL
                                            On 05/06/2010 at 14:14, xxxxxxxx wrote:
                                            another thing could be worth a try, to set the Parameters for an extra BaseContainer like i did it in my example:
                                            BaseContainer bc;
                                                      cd.bc = &bc;
                                            and in the if (SendModelingCommand... call "cd.op->Message(MSG_UPDATE, NULL);"
                                            Oh, wait, i didnt see you setting mcd2.op to your object, maybe thats the main problem
